01-21-2020, 10:38 AM | #1 |
Rep 52
F31 iDrvie Controller Touch ECU Coding
I bought and installed a large iDrive controller
which was plug and play as suggested by others here. Recently I bought the touch ECU and the Y cable for connecting it all together in order to enable the touch feature and my question is can this be done via bimmercode via the expert mode? The car is F31 LCI 320d. Thanks in advance! |
01-24-2020, 08:22 AM | #5 | |
Rep 8
2016 f30 Lci 328i |
01-24-2020, 11:31 AM | #6 |
Rep 52
I got one on ebay, not sure of the forum protocol on posting
a link but the seller is audibmw1010 and description was "touch controller ECU Y splitter cable adapter" probably many others source too. Cable works as advertised, one little issue was a small plastic profile (cca 1mm) on the original harness that prevented smooth insert in the splitter, but this was solved by a few strokes of sanding paper, no major surgery. |
