BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Fuse box diagram
      12-03-2014, 02:01 PM   #23
exclusivo
exclusivo's Avatar
126
Drives: race car
Originally Posted by Lost Horizon View Post
Look at what your dashcam draws for amps. (Prly not much ~ 0.2A +/-.). The smallest fuse you may be able to get will likely be more that 1A, so use that size. You don't want the fuse to be too big, else if the wire to the dashcam shorts out, it may overheat the wire without blowing, depending on the gauge of the wire you use.
The main branch, of course, stays the same size. Make sure the wire gauge to that circuit is big enough to handle the main fuse size.
Thanks, gonna pick up some fuse taps this weekend.
      12-27-2014, 10:32 PM   #24
F30kma
Drives: F30
I have the blackvue 2channel dashcam on order and wondering which fuse location to best tap into when deciding to hardwire with a power kit (motopark multisafer) unit.
MY15 320 will arrive next month so just pre-planning ahead. Owner's manual mentions two fuse box location: engine compartment area and cargo area.
Most likely would use the fuse box in the cargo area for easy access/install.
      12-31-2014, 08:35 AM   #25
420wheels
Drives: 420
Hi lost horizon,
do you know where the 4 series horn fuse is? thanks
      12-31-2014, 09:36 AM   #26
Lost Horizon
Lost Horizon's Avatar
Drives: 435 MPPK+1970 XKE OTS
Looks like it's the second from the bottom left on the card, but it is marked as underside / service.. that would typically mean it has an inline fuse somewhere, but it's not a number on the fuse box..
The steering wheel has 48 & 55, but whether or not either one is the horn is not clear. The horn is not likely wired directly to the horn button, it likely goes thru a relay, so the draw will be less than 5 A at the wheel, which would fit that side of the circuit as 55. But that's a guess. The other side of the circuit is likely some inline fuse, but it's certainly not on the stuff printed on the card.
      01-29-2015, 02:17 PM   #27
MdW86
Drives: Bmw f30 320i 2012
Could anyone tell me what fuse is always on? Would like to use it for my dashcam with parking mode...
      01-29-2015, 02:26 PM   #28
CJ2
Drives: 2019 F90 M5
Lots of fuse assignment knowledge in this thread! Can someone tell me what fuse location is used for the colored ambient lighting on the door panel?
      01-29-2015, 03:30 PM   #29
Lost Horizon
The Lighter fuses should be.. I don't think they are timed, but you can check that by hand. That would be 66 and 69 in the front and 162 in the trunk.
      01-30-2015, 12:25 AM   #30
MdW86
The lighter is cut off after 10 minutes..
      04-22-2015, 04:26 AM   #31
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
Where and which fuse is for headlight washers?
      04-22-2015, 10:51 AM   #32
Lost Horizon
The 'Car-on-hoist' icon means it's not on the main fuse panel(s), which suggests that it is a dealer service item ... might be inline.
      05-11-2015, 03:06 PM   #33
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
Thanks for reply... But that would be crazy stupid, on all other BMWs it was normal fuse...
The thing is that I did all hardware retrofit, and now need to connect wiring though dont know where, to which box etc.
      05-23-2015, 04:03 PM   #34
GTATX
GTATX's Avatar
Drives: 2020 M8 Comp First Edition
Can anyone please help which fuse powers the amplifier in the car. I have a f10 but same fuse box and hifi system.
Found it guys fuse 185
      05-30-2015, 09:10 PM   #35
kyoko
kyoko's Avatar
42
Drives: F80, G01
2017 BMW M3  [0.00]
2018 X3 M40i  [0.00]
I'm hardwiring a dashcam (blackvue 650) in my car (f30) and using a powermagic pro. I heard there are some issues but it came as a bundle. I'm trying to see what the issues are.
But I've currently wired it into the following fuses.
161 (headlights) for the always on
162 (rear cig lighter) for the ACC+
That sound about right? Or should I look for something with less amps?
      12-21-2015, 09:23 PM   #36
ODBimmer
ODBimmer's Avatar
Drives: '15 320i xDrive Olive Drab
Did you ever find out what fuse the door lighting uses? I have been searching for weeks and my new lighting is finally coming in tomorrow and I would like to tap the fuse so the extra lighting turns on an off the same time as these lights. Thanks
      01-18-2017, 04:00 AM   #37
Musa129
Drives: BMW 120D Msport
Lost horizon do you know where I would be able to locate fuse 80 for the rear windscreen heating ? cant find it in the boot ?
      01-18-2017, 10:59 AM   #38
Lost Horizon
It looks like you have a 2017 120D.. The fuse maps I have are for an F32, if you look back up the thread. For the F32, Fuse 80 is located in the trunk (I guess that's the boot to you) wheel well*. Look on your fuse card to make sure it's in the same place.
      01-18-2017, 11:05 AM   #39
Musa129
It looks like you have a 2017 120D.. The fuse maps I have are for an F32, if you look back up the thread. For the F32, Fuse 80 is located under the trunk (I guess that's the boot to you) floor towards the back. Look on your fuse card to make sure it's in the same place.
I have a 2013 120D Msport and I have exactly the same fuse card as the one you posted located in the boot of the car. I am just trying to find the rear windscreen heater fuse.. I thought it was fuse 80 ?
      01-18-2017, 11:15 AM   #40
Lost Horizon
Sorry.. I saw you just joined in 2017. Leaping assumption. It looks like it is fuse 80 by the symbol. I corrected my email above on the location for fuse 80, which is by the battery, as I recall. I'm working off a phone in Hawaii, so that's my excuse and I'll stick with it. Does that help?
      01-19-2017, 05:40 AM   #41
Musa129
Hi Lost Horizon,
I couldnt find the fuse 80 in the boot (Trunk) I saw the fusebox underneath the floor panel in the boot but it was not matching up with the fuse card. Weird.
      01-19-2017, 11:13 AM   #42
Lost Horizon
Hi Lost Horizon,
Did you look in the wheel well panel in the boot? (i.e., problem solved?)
      10-25-2018, 09:18 PM   #43
chrisnguyen01
Drives: 2017 540xi
Which fuse number controls the daytime running light?
      10-26-2018, 02:08 AM   #44
Zanity
Zanity's Avatar
Drives: 428i
does any one know what the fuse # is for the rear camera and rear electronic module? My rear camera image turned upside down on the screen, its a known glitch, i want to pull the fuse to the REM abd camera to reset it.
Mods: Dinan Tuned, Intake, Catless DP
