      03-25-2023, 12:30 PM   #16391
amir77
Iraq
Drives: BMW-2018-540i
No. It means do as I wrote above. VO Code Kombi and ACSM with factory original FA.
could you do me a favor, can i get procedure steps of "VO Code Kombi and ACSM with factory original FA"?
thank you very much
      03-25-2023, 12:59 PM   #16392
shawnsheridan
shawnsheridan's Avatar
thank you very much
Load original FA, Right-click on ECU, select Code.
      03-25-2023, 01:20 PM   #16393
amir77
Iraq
how to get original FA?
      03-25-2023, 01:26 PM   #16394
shawnsheridan
If you never modified it, then it's original. If you modified it, change it back to how it was.
      03-25-2023, 03:23 PM   #16395
amir77
Iraq
Shawnsheridan
the process of VO code kombi and ACSM with factory original FA done successfully.
but the passenger seat belt alarm still not active.
after VO coding the seat belt values return back some not active as pictures 1, also i made changes to values to all active, but the issue is still.
any suggestion?
thank youName:  1.jpg
      03-25-2023, 04:04 PM   #16396
shawnsheridan
Shawnsheridan
any suggestion?
thank you
No idea. I have only disabled them, not enabled them.
      03-25-2023, 04:08 PM   #16397
amir77
Iraq
thank you very much
by the way i have DKOMBI (60) it is same as KOMBI?Name:  WeChat Image_20230326000627.jpg
      03-25-2023, 04:10 PM   #16398
shawnsheridan
Yes, that is 6WB version of Kombi.
      03-25-2023, 06:15 PM   #16399
amir77
Iraq
thank you very much for helping
      03-25-2023, 11:00 PM   #16400
amir77
Iraq
No. These should all be enabled from factory, and not require any coding. O would VO Code ACSM and Kombi with factory original unmodified FA.
after loaded the default values in both ACSM and KOMBI, i found the related values of "passenger seat-belt alarm are not active, this means, it is not by active by default, right? because i am sure there is no change done for VO.
my question is: what are values relates to seat-belt alarm in KOMBI, that may be change or active to solve my issue
thank you
      03-25-2023, 11:09 PM   #16401
shawnsheridan
thank you
There is just KOMBI => GURT_FOND_STATUS for the rear seat belt status icon. All you should need is in ACSM.
      03-25-2023, 11:19 PM   #16402
amir77
Iraq
can you check plz, correct values?
      03-25-2023, 11:21 PM   #16403
shawnsheridan
This is irrelevant for your issue. This is the number of back seat icons to display in the instrument cluster.
      03-25-2023, 11:30 PM   #16404
amir77
Iraq
appears in idrive screen, but i can not select (checkbox) any 1 from 3!!
      03-25-2023, 11:32 PM   #16405
amir77
Iraq
in instrument cluster appears only for driver seat-belt sign
      03-26-2023, 04:51 AM   #16406
Kalya
Ukraine
47
Drives: E82, F22, F30, F32, G30, ...
hello
does anybody know, how to make a delay in sunroof curtain closing on 2016 f31?
it always moves 1-2 cm while i`m closing the car
      03-27-2023, 12:10 AM   #16407
amir77
Iraq
hello all
any idea why this connector is unplugged?
what its function?
car: x5 2018
      03-30-2023, 07:28 AM   #16408
Ronankellyie
Drives: Bmw f30 330e
Hi Shawn, would you be so kind and send me the link for the latest e-sys, psdzdata, and launcher as well? Thank you
      03-30-2023, 08:09 AM   #16409
shawnsheridan
PM sent.
      03-30-2023, 03:39 PM   #16410
amir77
Iraq
hello, shawnsheridan
plz, i need :latest e-sys, psdzdata, and launcher.
thank you so much
      03-30-2023, 03:41 PM   #16411
shawnsheridan
thank you so much
PM sent.
      03-31-2023, 04:13 PM   #16412
balexy
Drives: F30 320i
Hi Shawn,
Could you please email me the latest e-sys, psdzdata lite and launcher for 2012 F30. Cheers!
