12-10-2019, 05:36 PM | #1 |
Rep 39
Wagon: Rear Hatch Opening Issue
My 2016 F31 wagon rear hatch normally should open using the key fob, inside button or by putting my foot under the hatch. It does it only about one third the time. Closing isn't a problem.
There is a noise like it is unlocking but no movement. Again, it does work normally some of the time. I wonder if the 2 lift devices on the sides of the hatch can be adjusted. Is there a way for me to fix this issue? |
12-10-2019, 05:46 PM | #2 | |
Just Copacetic!
177
Rep 616
'01 X5 3.0 AlpWhite
'16 428i GC AlpWhite '19 230i MSptPkg AlpWhite |
12-10-2019, 05:51 PM | #3 |
Rep 8,942
Take it in. Mine did something similar but during extreme cold when the hydraulic stuff froze. Long story short all the mechanics back there ain't cheap.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
12-11-2019, 03:38 PM | #4 |
Rep 412
Have you checked to see if the glass hatch is securely closed? I’ve had this happen before only to find out I hadn’t closed the glass securely enough
Max |
12-12-2019, 01:20 PM | #5 |
Rep 39
Thanks for the replies. I tried 2 suggestions on another forum:
1. Rub silicone on the rubber seal 2. Adjust how far the hatch opens to its maximum height. Tested it this morning and so far this works. |
12-28-2019, 04:27 PM | #7 | |
poopycat
266
Rep 791
I'd open it and clean that area, and close firmly. Would take just a few minutes and it's free. |
12-29-2019, 10:08 AM | #8 |
Rep 39
12-30-2019, 03:24 PM | #9 |
Rep 39
02-18-2021, 05:05 PM | #11 |
Rep 39
The dealer suggested I replace the 2 lifters,(look like struts), that open the rear hatch. They couldn't find any code faults. They didn't know if that would work and wanted $1,600 to replace both. I checked and both parts are available online for about $500 but install requires quite a bit of labor. I decided it wasn't worth it and passed.
04-12-2022, 11:25 AM | #12 |
Rep 39
After years of having the hatch failing to open normally on my F31, it magically seems to be working normally now the last few months. I gave up on fixing this problem and I expect it to have the issue again... but, I'll enjoy it working now.
04-14-2022, 02:29 AM | #13 |
Great Teacher
1076
Rep 1,303
Drives: 06 e91 325ix
Most likely whatever grit/contamination etc was the issue is now finally gone and it will never happen again for the life of the car. finder coursed but that kind of oddball stuff happens.
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
