BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30 retrofit IHKA to IHKA3 possible?
      03-23-2018, 11:53 AM   #67
larrylam646
larrylam646's Avatar
Drives: 2020 M340i xDrive
Originally Posted by larry_bml View Post
So this is good right?
Yes, I believe so.
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold
      03-23-2018, 02:22 PM   #68
larry_bml
larry_bml's Avatar
Romania
194
Drives: BMW F30 Sport Line 320ded
I can’t wait for spring to come, so I can test AC also. The only difference that I saw in other parts beside IHKA ECU and CLIMATE CONTROLS, is that the compressor is without magnetic cluch on LCI, but because I have automatic transmission witch also has without cluch compressor, I hope that it will start also.
      03-23-2018, 07:55 PM   #69
IK6SPEED
Drives: BMW M3 / AH3
Originally Posted by atzebmw View Post
Well, today I took the time to read out the sensors.
Look at the pictures.
What does a EU 335d have that uses solar power?
Function: Outside temperature
Status 2.50℃
Function: Ventilation temperature sensor
Status: not available
Function: Condensation sensor (bus)
Status: 51.00%
Function: Footwell temperature sensor
Function: Interior temperature sensor
Status: 10.00℃
Function: Refrigerant pressure
Status: 5.00 bar
Function: Coolant temperature
Statuses: 21.00℃
Function: Solar sensor left (Bus)
Status: 92.00 W/m^2
Function: Solar sensor right (Bus)
Status: 88.00 W/m^2
Function: Evaporator temperature sensor
Status: 2.00℃
Function: Additional coolant pump
      03-24-2018, 01:16 AM   #70
IK6SPEED
      03-24-2018, 04:02 AM   #71
larrylam646
Thank you IK6SPEED for the German translation and for the descriptions for the sensors.
I can confirm that the dual zone system contains two sensors each for the ventilation and footwell i.e. for the driver's and passenger's sides. I took an ohm meter to the pins on the IHKA3 connector (white) designated for these temperature sensors.
Larry
      03-24-2018, 04:31 AM   #72
larry_bml
larry_bml's Avatar
Romania
194
What was the result of ohm meter?
      03-24-2018, 02:18 PM   #73
IK6SPEED
So if I am reading through all this correctly, to recap, steps are:
1) Install IHKA3 Controller Unit
Known to work for mod:
64116820235
64119390099
64116842986
2) Install LCI Screen Display unit
3) move wire from pins on FEM A173*7B to pins on FEM A173*10B which is either not connected to any wires or connected to HU_NBT Professional with Navigation, if you have that option.
IHKA -> KCAN_H Pin 22 to Pin 34 FEM A173*7B
IHKA -> KCAN_L Pin 23 to Pin 33 FEM A173*7B
IHKA3 -> KCAN2_H Pin 22 to Pin 10 FEM A173*10B
IHKA3 -> KCAN2_L Pin 23 to Pin 11 FEM A173*10B
4) change car build date (Zeitkriterium) up to at least a 2015 Model Year (07/14) in VO.
5) update car to latest istep level
6) Performed a "TAL-Calculating" and then a "TAL-Processing" to update the IHKA3 BTLD, SWFL and CAFD files.
7) Run Rheingold to clear all warnings and errors before starting your vehicle.
8) Start vehicle and run it until the A/C LED stops blinking.
Did I miss any steps?
      03-24-2018, 06:11 PM   #74
larrylam646
Each of the sensors measured between 25-27. I did not take a look at the units on my meter but based on my research, it would have to be kohms.
      03-24-2018, 06:49 PM   #75
larrylam646
Known to work in mod:
64116820235
64119390099
See picture below. If 64119311850, a 2013 unit, is actually exchangeable retrospectively, is this swap actually needed? Is it just the wiring to the other bus that is key :
3) move wire from pins on FEM A173*7B to attach to pins on FEM A173*10B which are not in use. Wires are replaced, not bridged, correct?
4) change car build date upward to at least a 2015 Model Year
What coding needs to be done at this point (in detail please)?
Is the flash here just the istep flash in #5?
Hi IK6SPEED,
For my installation, please see my comments on some of the steps you presented:
1) I can confirm 64116842986 also works. When I initially installed this unit, I did not get heat. After installing 64119390099 and getting everything working, I reinstalled 64116842986 and to my surprise, it also worked.
Regarding your question, 64119311850 is IHKA. Yes '850 is exchangeable retrospectively but take a look up the list you attached. Notice 64119356004 (04/14) is "nonexchangeable retrospectively" and the start manufacturing date is consistent when the IHKA3 replaced the IHKA
So you would have to source '004 or newer controller.
3. My vehicle came with HU_NBT Nav Professional so A173*10B Pins 10& 11 were in use. I tapped into the K-CAN2 bus from the QuadLock Connector since it was easier for me to access.
4. I VO Coded IHKA3 using manufacturing dates 07/13 (closest to my 10/13 manufacturing date) and 07/14. I compared the two CAFD files and discovered no material differences between the two files.
I then generated a CAFD file using 07/15 and compared the CAFD file with 07/13, there were material differences so I chose to use the 07/14 CAFD.
5) Flash the IHKA3 to the latest FW. Note, the BTLD, SWFL and CAFD files for both of the IHKA3 I tested needed to be updated. No need to FDL Code the IHKA3 CAFD file to determine if your retrofit is working. Just VO Code the IHKA3 ECU after flashing.
IK6SPEED4490.00
      03-24-2018, 07:23 PM   #76
IK6SPEED
Originally Posted by larrylam646 View Post
Hi IK6SPEED,
I do not even see that part number on attached list
Modified on my list
So simply add IHKA3 to VO and done?
I am told the aux coolant pump is showing no reading in your ISTA pic is the newer 2016 F3x (as well as the 2015 F8x) models have a newer aux pump that supplies this info to IHKA3.
Obviously, that has not been replaced on your vehicle. Of course as the 2015 F3x operates without it, it seems that is not needed for proper operation.
Attached is ISTA from 2015 M4 which shows status.
Sorry for the delay.
      03-24-2018, 07:53 PM   #77
IK6SPEED
While 2015 M4 shows no sensor value on the ISTA screen everyone else has posted, I have found it elsewhere.
Please check for it on your retrofits.
      03-24-2018, 07:57 PM   #78
larrylam646
See the list I attached from RealOEM:
I do know what you mean by "add IHKA3 to VO".
Just flash the IHKA3 to the latest version and then VO Code the IHKA3.
Larry
IK6SPEED4490.00
      03-24-2018, 08:06 PM   #79
IK6SPEED
Larry
VO is the vehicle order.
Assuming from your post you are adding IHKA3 (or adding a 3 to IHKA) in the VO and saving.
At least that is the way your post reads.
That’s why I am asking for clarification. To double check.
IHKA3 should not be available unless added to vehicle order.
Just as you changed 6WA in VO to 6WB when you added the digital speed/tach.
      03-24-2018, 08:12 PM   #80
larrylam646
When I was debug my initial install, I stumbled across the same test in Rheingold. Since I did not have any heat at the time, the temperatures did not change so I could not confirm whether the IHKA3 was actually connected to and reporting the temp sensor readings.
I will check tomorrow with my current install and report back.
Larry
      03-24-2018, 08:26 PM   #81
IK6SPEED
Hi IK6SPEED,
If you are asking if anyone has taken the display panel out of an LCI HVAC Controller and retrofitted it into a non-LCI HVAC Controller, I would think this would be more challenging than retrofitting the IHKA3 into an IHKA vehicle.
The display panels appear to be sufficiently different that I believe it is unlikely the LCI panel would be plug-and-play in the non-LCI HVAC Controller application. Just a guess since I have not disassembled and compared the two HVAC Controllers.
Larry
Just to update
Transplant of LCI Display to Pre-LCI unit failed
Of course that would have made it so much easier.
*sigh*
Past posts edited to reflect that path is not possible.
      03-24-2018, 09:09 PM   #82
larrylam646
My vehicle came factory installed with Automatic Climate Control (534) so the only modification I made to the VO was change the manufacturing date to 07/14 (by editing the FA file and changing "Zeitkriterium" to 0714).
After installing the IHKA3 , performed a "TAL-Calculating" and then a "TAL-Processing" to update the IHKA3 BTLD, SWFL and CAFD files.
That is it. Your LCI HVAC and IHKA3 should be operational after starting your vehicle and running it until the A/C LED stops blinking.
Forgot. one more step - Run Rheingold and clear all warnings and errors before starting your vehicle.
      03-24-2018, 09:14 PM   #83
larrylam646
Just to update
*sigh*
bravo for trying.
IK6SPEED4490.00
      03-24-2018, 10:28 PM   #84
larrylam646
Modified steps above. Are they correct now?
Did you check for 2 sensor temps in other area I posted?
Steps look fine.
It is 11pm in Ottawa at the moment. Will check tomorrow AM.
Update Mar 25th:
This AM I ran Rheingold and measured the Ventilation and Footwell Sensor temperatures and captured screen shots with the vehicle cold and warmed up. Please refer to attached pdf file.
I can confirm the IHKA3 does read the temperature sensors, as evidenced with the change in temperatures between cold and warmed up.
It would appear the IHKA3 retrofit works properly....
Larry
File Type: pdf Ventillation and Footwell Temp Sensor Measurements.pdf (830.7 KB, 294 views)
Last edited by larrylam646; 03-25-2018 at 09:27 AM.. Reason: Added screen shots of Ventilation and Footwell Temp Sensors
IK6SPEED4490.00
      03-25-2018, 08:24 PM   #85
IK6SPEED
Steps look fine.
Update Mar 25th:
Larry
Looks great!
Everything answered!
And sensors are working on other page!!!!!
      03-31-2018, 10:02 AM   #86
larry_bml
larry_bml's Avatar
Romania
194
And YES, I can confirm that IHKA3, can be retrofited on BMW F30 2012.
I just run the final test, and YES, everything is working.
IK6SPEED4490.00
      04-08-2018, 01:46 PM   #87
rflagg
Drives: F31
A quick question - my pre-LCI car currently has basic single-zone climate control with IHKA. What happens if I replace the panel with a pre-LCI dual-zone one? Would it still work to some extent or do I need to make the full IHKA3 retrofit right away? Just wondering since someone has probably tested it already.
      04-08-2018, 02:14 PM   #88
IK6SPEED
All or none
And if you depend on Dealer for any Service, the retrofit will cause major issues in future.
