BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Exhaust Valve Install Help. pls
proTUNING Freaks
      04-06-2021, 02:05 AM   #1
Jaylenp10
Drives: 2014 F30 335i
Hello I bought a used Armytrix exhaust for my 2014 f30 335i, it unfortunately didn't come with the valve controller. So I bought a universal one off ebay and cant figure out where to tap into a vacuum line at, or if there is a plugged accessory vacuum source that I can use. Every pdf tutorial is very vague and doesn't show what to properly do. Thank you.
Armytrix Exhaust Install PDF - https://www.armytrixusa.com/blog/wp-...ion-Manual.pdf
Universal Valve Controller - https://www.ebay.com/itm/283772412788
Insane435282.00
      04-06-2021, 06:02 AM   #2
Phantom10R
Drives: 2015 335i, 2015 X3 x35i
I believe ours are electric and not a vacuum... so idk
2015 335i xDrive 11.76 on stock turbo. (dragy) uphill!
2015 X3 x35i 12.96 catless w/bm3 stage 2 93 flash
IG: @N55David For pics and updates!
Youtube: @ n55david For videos or Racing etc
      04-08-2021, 08:37 AM   #3
Insane435
Insane435's Avatar
Drives: 435ix M Sport EWG
I have this setup.
Are you EWG or PWG? The install is different between the 2. If you are EWG you need this extra hose that allows you to tap vacuum off the brake booster hose.
I am actually selling the entire setup that includes this.
2014 EBII 435ix - OEM Front pipe + SSS2 + VRSF Race, Evolution Racewerks Downpipe - Chargepipe - Intercooler, Bootmod3 7.1, xHP Stage 3 Trans Tune, NGK 97506's, AFE Dry Filter, KW V1, Forgestar F14 19s, Pilot 4S, M Performance Brakes, M Power Pads
2011 BSM 328ix & 2018 LBB X4M40i
      04-08-2021, 07:08 PM   #4
Jaylenp10
I am EWG, would you be able to post of pic of where you tapped into it?
      04-08-2021, 08:16 PM   #5
Insane435
Insane435's Avatar
You need a part supplied by amrytrix. Its replaces the brake Booster vacuum line.
https://imgur.com/a/R4VnZU6
      04-09-2021, 06:49 PM   #6
Jaylenp10
Do you think I would be able to use the "T" that came with the kit and just tap into the brake booster line?
      04-15-2021, 08:39 AM   #7
Insane435
Insane435's Avatar
I would have to see the picture of the T. They provide a special part that has the right fittings on both ends. I suspect its some type of modified factory brake booster line.
exhaust, n55, valve
