01-10-2019, 03:36 PM | #23 |
Rep 14
04-24-2019, 03:01 PM | #24 |
Rep 25
Hey guys a quick question on the catless downpipes. How bad is the smell? I've heard that you can clearly smell burning oil going catless. Thoughts? experience?
04-24-2019, 03:04 PM | #25 |
Rep 3,680
Not bad at all in my experience. Only smell it outside the car or at a stop with windows down.
04-25-2019, 08:42 AM | #26 |
Rep 420
floridaorange10204.00 |
04-25-2019, 12:10 PM | #27 |
Rep 943
Drives: F30 328i Msport
On my n26 i took off the secondary cat, and it smells like rotten eggs now, not the most pleasant smell but bearable, problem is now I'm hesitant to go full on catless, fearing this rotten egg smell will gain a ton of strength. Also, it might be a sign of a failing cat, so might have to go catless regardless .
04-25-2019, 12:41 PM | #28 |
Rep 420
Catless n20 here. Its fine. There is zero rotten egg smell. You can only smell unburned gas fumes when you put your face right up to the exhaust tip, or just barely if the wind is blowing just right. Seriously I don't know why people are making this an issue lol.
04-25-2019, 01:14 PM | #29 |
Rep 1,045
I 'm getting a custom fabricated catless downpipe, the total cost including install is half of what any branded downpipe would cost. I mean, it's just a 4" plumbing pipe, I don't think any brand makes a difference in performance, a fabricated one will have the fittings and size identical to the OEM, so it's going to fit.
Mods: Dinan Tuned, Intake, Catless DP
04-25-2019, 04:29 PM | #30 | |
Rep 420
04-25-2019, 04:33 PM | #31 | |
Rep 3,680
CandyRedRC46242.00 |
04-26-2019, 09:48 AM | #32 |
Rep 1,045
Well, the fitting isn't an issue because its being welded on. I went to the shop and they quoted me $250CAD ($185USD) for fabrication and install so to me it was a no brainer
You have a point for the flex portion removed, I'll ask them if they can cut that off the OEM and weld it on
04-26-2019, 10:00 AM | #33 | |
Rep 5,457
Drives: F30
I dont believe they will weld the pipe directly to the turbo... and if they are planning that - I wouldnt let them... The two main reasons for a properly engineered aftermarket pipe are the TURBO SIDE connection and the flex-pipe portion. But in the end... it is just a hollow pipe. |
rjd_F302000.50 |
04-26-2019, 10:25 AM | #34 | |
Rep 1,045
sspade2466.00 |
04-29-2019, 08:12 AM | #36 |
Rep 3,680
Sounds like basically a more professional/refined way of gutting the cat.
04-29-2019, 04:40 PM | #37 |
Rep 891
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
Zanity731.00 floridaorange10204.00 |
04-29-2019, 06:15 PM | #38 |
Rep 3,680
04-29-2019, 08:02 PM | #39 |
Big Turbo Boys N Girls
327
Rep 579
Should just get the Circuit Werks downpipe. I had it for years till I went custom turbo. No issues and fitment was great. Pipe is a pipe! No need to spend loads of money on it.
2012 F30: G25-660 Bottom Mount Mani+ DP+ Intake, CSF FMIC, VRSF CP, Walbro 450 LPFP, PR Injection with AIC 4, S63TU Injectors, Tuned with BM3, ZF Race 4 Puck and Non SSA Pressure plate, Catless, 3.5" Quad Muffler, Custom Valved Bilstein B8 + H&R SS. Max 456 WHP - 452 WTRQ. Currently tuned down to 434 WHP and 362 WTRQ to save the rods.
05-01-2019, 12:03 PM | #40 |
Rep 1,045
exactly my thought, that's why i'm gutting the cat
05-05-2019, 07:22 PM | #41 | |
Rep 77
05-06-2019, 08:48 AM | #42 |
Rep 5,457
Drives: F30
Circuit Werks N26 catless
