11-09-2022, 07:22 AM | #45 | |
Rep 424
Thanks for the part number - 28 bucks on FCPeuro, I am going to buy it and let it sit on the bench until I am in there again (Or it cracks ) |
dreaming.haze74.00 capt_slow556.00 |
11-09-2022, 12:23 PM | #46 |
Rep 1,805
Yes, and I'd say that all early to mid 2014 model years in hotter climates should plan for the coolant flange (and the harmonic balancer) soon.
For me the car has been quite flawless up to this point (145k miles!), so it's not excessive to say that a round of maintenance is worth it. If doing the coolant pipe/flange, I would say do the water pump and thermostat (with housing) at the same time.
11-09-2022, 01:52 PM | #47 |
Rep 80
Agreed on the Water Pump + Thermostat at the same time. I've already done my Thermostat last fall, but still plan to do the Water Pump here at 120k miles. will need to take the freshly installed EGR Cooler off to do the job, but feels worthwhile to get squared away.
11-09-2022, 10:12 PM | #48 | |
Rep 906
I see 120K as a great time to replace the flange, thermostat, water pump, coolant hoses, and coolant.
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World |
Enabled1410.00 |
11-10-2022, 08:55 AM | #49 |
Rep 80
Based on realoem - looks like 5 hoses that would need to be replaced. BMW is quite proud of them as well, total price would come out to $293 if ordering from bmwpartsdeal.com
https://www.realoem.com/bmw/enUS/sho...diagId=17_0634 |
11-18-2022, 12:32 PM | #50 | |
Rep 424
11-20-2022, 12:30 AM | #52 | |
Rep 906
Parts was about $150 and I DIY it. Dealer quoted the work at nearly $550!
FaRKle!4017.00 |
12-13-2022, 03:32 PM | #53 |
Rep 157
DO you have the correct part #s for the glow plugs
2018 328d
12-16-2022, 11:19 PM | #54 | |
Rep 906
Transmission UOA
I changed out all the drivetrain fluids at 62K. Then, sent a sample of the old transmission fluid to Blackstone for analysis. This is what they wrote:
12-18-2022, 03:29 PM | #55 |
Rep 1,805
12230035934
They're Bosch GLP5 But don't replace them until they throw a code. And this will be well over 150k miles.
ssf55638.00 |
12-18-2022, 06:10 PM | #56 |
Rep 157
OK thanks for the heads up. Are we not concerned with them getting stuck at that many miles? I have been proactive on my Mercedes OM642 diesel and things have worked out ok. I am on my 3rd set at 120K.
2018 328d
12-18-2022, 06:35 PM | #57 |
Rep 1,805
I long suspected that the ones getting stuck are from being replaced without thread paste or something to keep them from seizing.
I wouldn't disturb those threads in the head and wear them out ahead of time, as it would then require a lot of machine shop work. I guess there's a balance between changing them too often and potentially having them seize on you.
ssf55638.00 |
12-21-2022, 10:47 PM | #58 | |
Rep 80
If you order an OE Water Pump, there is no need to order Loctite 5970 sealant. The pump already has sealant applied. If you order OEM, then you'd need to have sealant at the ready. There is a small rubber pipe that comes off the water pump that I would also look towards replacing, but I can't find it within parts diagrams thus far. Once I do, I'll provide the PN. |
12-22-2022, 09:18 AM | #59 | |
Rep 424
How was this job - closing in on 140k and think being proactive on WP and thermostat might be smart |
12-22-2022, 10:07 AM | #60 | |
Rep 80
I would recommend removing that pipe rather than just moving things out of the way. Also I hadn't removed the EGR cooler. When removing / installing the EGR cooler, just leave the assembly a bit loose before snugging everything firmly down. Allows for more wiggle in installing the various pipes / fittings / etc. With just having had the EGR cooler replaced 2,000 miles prior, I didn't worry about replacing any seals / bolts. Also, when installing the thermostat housing / thermostat - it is a lot easier with two people vs. one to compress the thermostat with the housing. If you don't have two people - you just want to have the thermostat housing bolts threaded a thread or two on all three bolts, then slowly snug things down using the housing to compress the thermostat. |
12-22-2022, 11:17 AM | #61 | |
Rep 424
02-06-2023, 08:48 PM | #62 |
Rep 80
Following up on some additional preventative maintenance performed. Although I had just gotten into the coolant system previously, I decided to dive back in once more.
To note on anyone replacing the thermostat - ensure the ball valve is pointing downwards. Had to take mine back off to properly clock it after the previous install. Here's this noted in newtis: https://www.newtis.info/tisv2/a/en/f...drive/GzioCZ9d Another job was the OFHG. There are multiple gaskets and seals that need to be replaced with this job. Overall, not too terrible, but you need to remove the Intake Manifold to properly get at things. Parts: 11428516396 - Gasket between block and Oil Filter Housing 11428580681 - Gasket set (If replacing the full thermostat housing 11428507694 - set not needed) 11428580682 - Gasket set 11428511981 - Gasket set 17228511461 - O-rings for ATF Lines -> Cooler 11437794698 - Engine Dip Stick O-Ring Optional 11618517159 - Intake manifold seal / flaps (recommendation is to replace if taking manifold off, I replaced) 11127810707 - Coolant Flange / pipe (talked about this in previous posts, very accessible during this job) During the OFHG, Also replaced the Valve Cover Gasket. This job was more involved, but more so due to just being careful as you go. Be cautious of the injector return lines. The small brown clips should be approached with caution. Was able to get them off with 45" degree long reach pliers and patience. When taking out the Injectors, you should be able to remove these by hand with a little twist if anything. Replace the crush washers + use some good quality high temp grease on install. After getting everything put back together I did run through the injector bleed procedure in ISTA+. Parts: 11128511814 - Valve Cover Gasket 13532247156 - Injector Crush Washers Optional: 13537823408 - Injector return line (didn't have this on hand, but good to know just in case replacement is needed) Next up was some cracks noted on the Windshield cowl. Common failure over time and due to parking my car outside for most of its' life - it was time to replace. For this job, just ensure you have a tool to pop the plastic rivets out. By this point, you likely do. Parts: 51717258177 - Windshield Cowl And last on my preventative maintenance run was the Transfer Case Bushing. I had already replaced my motor mounts ~4k miles ago, so wanted to round out the fresh bushings. Job notes: For removal I used soapy water + a couple of pry bars to get leverage and remove the mount. For install, I used a tool from Konmen tools that is based on BMW Tool P/N: 221 040. I wasn't able to use the tool on the F31 chassis for removal due to space issues. Install though it worked perfectly. Just needed to get things started by hand -> get the tool to do the rest of the work. Parts: 22316786566 - Transfer Case Bushing 07119906978 - Through bolt for transfer case bushing 07119906050 - Nut for above bolt Optional: 22316788586 - Additional Rubber Buffer(mine was hard, so decided why not replace it) I've also gone through my full front suspension + steering trying to chase down a clunk noise coming from the drivers side - but that is another thread and still something I am chasing down. I figure after all this maintenance, It will be good to enjoy the next 60k miles with more basic maintenance + usage needs. |
02-07-2023, 09:13 AM | #63 |
Rep 424
I just completed a motor and transmission mount swap at 136k. Engine mounts were not leaking, but this is a 200k plus car for me so went ahead and did it. Saw no failures in rubber or mounts once removed, but NVH has decreased in the cabin which was a nice benefit. Throttle response feels better so I imagine the engine is shifting less under load. One thing to note is the transmission mounts were significantly compressed when compared to the new ones, so I am glad I replaced!
02-07-2023, 09:16 AM | #64 | |
Rep 424
Few questions - Did the intake have to be removed to do the OFHG? I cant tell if I am starting a leak from OFH or just spill a lot during oil changes... so probably doing this job soon. Also - any lessons learned from windshield cowl? On my list as well |
02-07-2023, 09:18 AM | #65 |
Rep 424
Let me know once you start this thread. I was chasing down the same driver side noise on my 328d. Only 45k on the replaced struts, hats, etc. I ended up replacing them again, but think the noise might have been from my motor mounts I replaced at the same time. Happy to chat through with you!
02-07-2023, 10:34 AM | #66 |
Rep 80
n00bkiller944 - For sure. Kinda fun to get into the DIY aspect of these cars. Frustrating at times, but worthwhile in the end with preventative maintenance.
I imagine there are ways to get around removing the intake manifold - but I would say it is recommended to just fully remove things. I had the same thoughts on the spills during oil changes, likely saw a build up on the lower portion of the cooler / housing. Worthwhile to just get into it and replace things. Here's the thread I've started up on this https://f30.bimmerpost.com/forums/sh....php?t=1987309 | haven't replaced the struts, but that would be the last item of a fresh front suspension / steering (post this it would be into axles / steering rack full replacement / etc). For you, I'd confirm if the clunk is there with the engine off. |
