01-10-2015, 07:27 PM | #1 |
Rep 1,749
logic 7 amp specs? stout enough to drive 4 ohm jehnerts?
I am trying to find more specs on the f30/f80 l9gic 7 amp as I'd like to try use it to run jehnert underseat woofers as on my e92 the individual audio amp ran jehnerts nicely even though the OEM woofers are 7 ohm and jehnert 4 ohm, it had no issue. This compared to the earthquake 4 ohm woofers my amp didn't kike. I suspect the jehnert is realistically a bit higher dynamic ohm than 4.
However is logic 7 stable to push jehnerts? How many watts is it sending to the woofers? |
01-11-2015, 01:18 AM | #2 |
Rep 12,996
HK in the F30/80 uses 7ohms OEM woofers as in the EPS.
You need to understand that using less than 7ohms in aftermarket woofers with the HK and the EPS OEM amp increases the possibility of damaging the OEM amp. |
01-11-2015, 11:02 AM | #4 | |
Rep 12,996
