09-18-2019, 02:20 AM | #1 |
Rep 6
2014 F31 automatic folding mirrors with press lock button on boot lid
Hello All,
I have a 2014 f31 328i with comfort access. There is a also close boot button and a close boot and lock car button on the boot lid So I have comfort access and coded both the following FEM_BODY => ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN = aktiv FEM_BODY => ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN = aktiv I also verified the following are set FEM_BODY => KOMFORTSCHLIESSUNG_FB = aktiv is Fob FEM_BODY => KOMFORTSCHLIESSUNG_PA = aktiv is Comfort Access Now my F31 would fold in the mirrors and close the windows with the key fob and comfort access. However when I open boot lid then press lock car button on boot lid, it just closed boot lid and locked door but side mirrors did not fold in automatically. Does anyone know what modules/parameters I need to change to get mirrors fold in when I press lock botton on boot lid? |
09-18-2019, 03:50 AM | #2 |
Rep 2,302
You can try to set the value KOMFORT_SCHLIESSEN to 00 (Original set to 0F=15 means 1,5seconds delay).
This is the time the button has to be pushed if the mirrors will fold in. If you set it to 00 there is no delay and the mirrors should fold in immediately. |
04-13-2024, 03:10 AM | #4 |
Rep 579
Drives: 2018 F48 X1 xDrive 18D
Running into the same problem, is there any code to make the mirrors auto fold in when using the trunk lid button?
