BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Using "Camber Correction" Hubs?
Studio RSR
      08-13-2019, 09:45 AM   #1
Littlebear
Drives: ...the Mods crazy.
Hello BMW Experts!
Has anyone put in these correction hubs to get a little front camber, instead of using the F80 LCA?
- I imagine the hubs come with wheel bearings. True?
- Why do the hubs have different names, ie: "Carrier" (stock), "Pivot Bearing" (correction, left), "Swivel Bearing" (correction, right)?
https://www.realoem.com/bmw/enUS/sho...diagId=31_0956
TIA! Murf
      08-13-2019, 01:15 PM   #2
Jvac
Drives: 2015 335i rwd
https://f30.bimmerpost.com/forums/sh...1090804&page=8
I just posted this in another thread last night. Looks like one guy polo08816 did do it but I don't know if he's still active on the forum.
      08-15-2019, 05:37 AM   #3
Littlebear
Thanks Jvac,
I'm in that thread; looks good.
Murf
      08-20-2019, 02:20 AM   #4
madriz
Drives: 440i f32
Could you put this plus the silentblock super pro or powerflex? How much camber would we earn?
      08-20-2019, 06:06 AM   #5
Polo08816
Drives: 2014 335i M Sport
Originally Posted by Littlebear View Post
Hello BMW Experts!
TIA! Murf
I have both the F80 LCAs and the camber correction hubs on my F30 335i RWD.
The hubs do not come with wheel bearings but if you have some decent mileage on your original bears it might not be a bad time just to replace it while you're in there.
As for the different names, just make sure it says "-30min" so you'll get more negative camber.
One thing to keep in mind about camber correction hubs is that it will change the angle of the wheel in relation to the strut so the inner edge of the tire will be slightly closer to the strut. Camber plates don't change that relative angle, however, camber plates aren't as good for daily driving compared to camber correction hubs.
      08-21-2019, 05:20 AM   #6
Littlebear
Thanks Polo,
I appreciate the feedback.
Yes, with the bearings coming in that big hub assembly, maybe my old bearings can be used. I was thinking hammer out the bearing, then the race....
New hub/bearings are ~$100. - $200. ea.
Did you do the work yourself?
Murf
      08-21-2019, 06:42 AM   #7
Polo08816
Thanks Polo,
Murf
I did the work myself.
I didn't bother to separate the old bearings from the old hub assembly. But it basically bolts to the hub assembly. An air chisel should be able to separate that pretty quickly.
      08-21-2019, 07:49 AM   #8
WolfGTI
WolfGTI's Avatar
Drives: '17 F22,15 E84 M Sport,02 R53
2017 BMW M240i  [0.00]
2002 MINI Cooper S  [0.00]
2015 BMW X1  [0.00]
I went the camber plate route on my daily driven M240i no issues drives 70 miles every day. That being said I would highly recommend you put in new bearings, not worth the little bit of $$$ saved to have to redo it if you experience bearing failure.
      08-21-2019, 09:54 AM   #9
Littlebear
So new bearings for you?
Murf
      08-21-2019, 12:00 PM   #10
AshlandTE87
Drives: 2015 335i M-Sport 6sp
I wonder why BMW makes camber correction hubs that induce additional positive camber? Along with the correction hubs, -30 min, there are ones offered for +30 min. Weird.........would it be for cars that are lowered big time?
      08-21-2019, 03:24 PM   #11
Polo08816
Murf
Yes, new bearings for me.
https://www.fcpeuro.com/BMW-parts/33...&b=5&d=3584&v=
I could have sworn that I used SKF bearings when I did mine because they were substantially less expensive than BMW bearings, but that doesn't seem to be the case right now.
Perhaps for the weirdos that want to install an aftermarket offroad lift kit on their BMWs. No idea.
      08-21-2019, 04:13 PM   #12
Littlebear
Furious Method found these Meyle hubs for $106. ea:
https://www.oembimmerparts.com/Searc...ch=31206876840
The correction carriers look to be over $275. ea.
Add a groovy bushing or two....
Murf
      09-12-2019, 03:33 PM   #13
MacklinUSOB
Drives: f30 328i 6MT Sport
They're for the folks in collision repair who have bent subframe mounting points to deal with but the insurance company wouldn't pay out to pull the motor to fix it at the source.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines |
Past: E36 328is & E38 740i
      09-13-2019, 05:50 AM   #14
Littlebear
If anyone sees these correction hubs for sale, pls post here or PM me!
Murf
      10-02-2019, 12:11 PM   #15
BMWILUVU
Drives: 340ix
How much effort is this DIY? It looks like alot.
      10-03-2019, 10:23 AM   #16
Polo08816
It's not too bad. If you've done the suspension before, you can easily do this.
      10-03-2019, 10:32 AM   #17
BMWILUVU
Drives: 340ix
Would I need to mess with the springs and struts like compress them?
      10-03-2019, 12:17 PM   #18
Polo08816
No.
BMWILUVU809.00
