08-26-2019, 12:51 PM | #1 |
Rep 36
Borla Exhaust - Death Rattle
Hello everyone.
I have a 2014 328i M Sport six speed. Long story short, I've really never loved this car, always wanted a three series but I've found it to be pretty boring. Thinking about what would make the car more engaging, for me it really came to sound, these cars are dead silent from the factory and wanting to make it more sporty, I purchased a Borla S-Type catback. Install was easy and it appears to be a well made piece. Cold start is extremely loud and sounds... well not good, but it's otherwise a nice exhaust. It's not super loud, no highway drone, but sounds great accelerating, just a deeper, more sporty rumble and offers some nice pops and burbles upon throttle lift. Now, onto my issue/question: the car now has a nasty rattle inside while accelerating. At idle or freeway speeds, it's quiet and fine. Accelerating in any gear, even under relatively light throttle, I experience a massive buzz. It sounds like the exhaust is contacting the heat shield on the bottom of the car and vibrating, it seems like it's coming from in the cabin near the tunnel bump on the floor of the back seat. I've lifted the car up several times, everything is tight, nothing is close to rubbing, I've even rotated a bunch of the sections to move them further from the car. It seems like it's really just the resonance of the exhaust rattling the heat shields. Anyone have any other ideas to try to reduce this? I am thinking of throwing in the towel, putting the stock system back on, and selling the car.
2014 328i M Sport Estoril Blue Six Speed - Daily
2003 Corvette 50 AE Six Speed - Track/Fun |
08-27-2019, 09:34 PM | #2 |
Rep 299
i reckon a good exhaust should would be able to sort you out.
i had a nasty rattle and vibration after a so called "tuner" installed my downpipe on my 435i. had an exhaust shop look it over and they found the "tuner" hadn't installed it properly. was making contact with some part of the car. so yes i think try a good exhaust shop and see. they might be an easy fix
2018 F30 BMW 340i M Sport
Injen EVO intake, OEM 437m rims, Catted VRSF dp, Magnaflow catback, Activ8 piggyback, Pedalbox. |
08-28-2019, 10:31 AM | #3 | |
Rep 36
08-30-2019, 11:00 AM | #4 |
Rep 36
Based on some other threads, I think this parking brake retaining clip is my issue: https://f30.bimmerpost.com/forums/sh...7#post25197687
I'm going to order the part from ECS for $9 and fingers crossed it'll fix the issue.
YNoDpstk!3.00 |
08-30-2019, 11:30 AM | #5 |
Rep 4,876
You definitely have it rubbing on something. I'd suspect your center tunnel brace.
And yes, it sounds like the car is about to fly apart in a very bad way.... |
08-30-2019, 11:40 AM | #6 |
Rep 241
I have the Borla Attack on my car and had a rattle which was coming from the mid-pipe touching the car where it bends over the brace. I re-adjusted the mid-pipe so that nothing was touching and made sure everything was tight. I have no further vibrations
BMW F06 M6 GC (Fun Ride)
BMW F15 M-Sport 35iXDrive (Family Ride) BMW F48 X1 (Wife's Ride) 96 Camry (Daily Ride) |
08-30-2019, 12:09 PM | #7 |
Rep 36
I actually took the brace off and went for a drive and it sounded exactly the same.
It sounds exactly like this guy's video from another thread:
08-30-2019, 01:24 PM | #8 |
Rep 33
I had the same issue, took it back same day of install to have it fixed. As others have said, it ended up being the mid-pipe vibrating in contact with the underbody. Once the car was on the lift, you could replicate the rattle by hand just shaking the exhaust pipe. The shop put an extra washer or two where the mid-pipe brace connects to the underbody to create more space. No issue after that.
08-30-2019, 02:17 PM | #9 | |
Rep 36
08-30-2019, 04:13 PM | #10 |
Rep 33
09-15-2019, 12:38 PM | #12 |
Rep 36
Well... it was the parking brake clip, I'm really glad I found that other thread.
The replacement was kind of a bitch, have to lower the exhaust, remove the heat shield, loosen the gas tank down to the driveshaft to remove it. The new clip was still plastic and flimsy... I reinforced with some zip ties, hopefully it doesn't break again, but so glad to have it resolved! I also replaced the spark plugs yesterday and seem to have eliminated a misfire code. That job was easy fortunately!
neonnblack139.00 jmg18694.00 |
09-15-2019, 01:49 PM | #13 |
Rep 2,665
I could tolerate that for about 10 seconds - then it would be straight back to the shop that installed it.
09-15-2019, 08:22 PM | #14 | |
Rep 302
09-16-2019, 08:03 AM | #15 | |
Rep 36
The car is certainly way more fun with the exhaust than its previous silent state.
09-16-2019, 04:50 PM | #17 | |
Rep 36
neonnblack139.00 |
09-19-2019, 10:12 AM | #18 | ||
Rep 302
09-19-2019, 11:45 AM | #19 |
Rep 36
Yep, that's the one. That nut in the center of it that holds it on is threaded onto a stud that also holds up the center of the gas tank, then it slides on... pretty self explanatory once you have the part and are in there... but kind of a pain.
09-19-2019, 12:07 PM | #20 | |
Rep 302
10-02-2019, 11:23 PM | #21 |
Rep 302
Boy that was a pain in the ass. Glad it's done though and quiet again.
I also took a picture just in case anyone comes across this post looking for more details. The red circle breaks, letting the two green circles (driveshaft and bowden cables) to touch while driving. Last edited by neonnblack; 10-02-2019 at 11:38 PM.. |
