10-23-2015, 07:54 PM | #1 |
Rep 5
Suggestions for DD/Autocross alignment please
I did use the search function 😀
I have a f30 328i (base car) H&R FSB and RSB 245-45-17 RE71 R's Otherwise stock. I'm new to BMW ( Autocrossed mustangs for years) What's a good spec to give my alignment shop? Thanks
2014 328i Base car, sleeper mode on
245/45/17 x 4 Re71 r's Turner / Afe Scorcher Turner / H&R Front and rear sway bars Turner Stainless Brake lines |
10-26-2015, 01:08 PM | #2 |
Rep 573
Drives: 2013 F30 335i 8SA M-Adaptive
Without additional hardware in the front, there's nothing to adjust but toe
Stock alignment has a little toe-in in the front and rear, for starters, zero out the toe in the front and rear then set the rear camber to -2 degrees That's about all you can do with the stock hardware |
11-09-2015, 01:42 PM | #3 | |
Rep 10,509
I'm not 100% sure on the zero rear toe. I personally would like some toe in and perhaps OP could track the car with stock settings to figure out preferences before making the initial alignment change |
11-12-2015, 08:48 AM | #4 | ||
Rep 573
If you want the rear to stay inside the front tires, keep the toe stock in the rear. If you want the rear to step out a bit, zero it out. |
