05-05-2020, 02:09 AM | #133 |
Rep 585
I see SC_B5X has posted a quick 100 - 200 time on the Dragy Leaderboard 6.70s, nice time, especially considering the DA of 1060m. Pure800, E50 MHD/Wedge 340i
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph |
05-05-2020, 11:20 AM | #134 |
Rep 242
Guys with temperatures(22C) go up my 100-200 times also i cant go under 9.5.Isnt that too slow for bm3 st2 ots.Car is xdrive with full options and 19wheels 265back 235front tyres.452 crank hp on the dyno with v2.0 here is log from 5th gear
https://www.bootmod3.net/log?id=5eae...0b4367fadfa721 Last edited by yokata; 05-05-2020 at 11:27 AM.. |
05-05-2020, 07:25 PM | #135 | |
Rep 585
If so, you are making 400 - 410 WHP, about 450 engine HP and the time is too slow, should be about 9.0 If rear tires are 265/30/19 and tire height of 25.5" you are only making about 365 - 375 WHP, weight dependent, and that would explain the time. What weight is your car with fuel and driver? Even with all options, car weight would be about 3860 lbs?
05-06-2020, 01:45 AM | #136 |
enthusiast
116
Rep 221
Finally, new time 11.5@119.2mph..... will share tomorrow- 1:44am now LOL
2018 340i x-drive 8AT - MP (Mission Performance) stg 3 DME tune, Xhp stg 3 EGS tune, catted AA downpipe, NGK plugs, E30 blend - 11.4@120mph. |
05-06-2020, 03:51 AM | #137 | |
Rep 508
quite low boost for a bootmod stage2, 1.18bar, I'm running 1.33 bar (not bm3 though) |
05-06-2020, 04:05 AM | #138 | |
Rep 242
05-06-2020, 07:30 AM | #139 | |
Rep 585
If you used to do 9.0s 100 - 200 and now you're going 0.5s slower something is not right. Boost seems a bit low relative to wastegate duty cycle after about 5700 RPM. Load Target stays high at close to 190 up top but Load Actual drops down to 154 by 6800 RPM. Do you have a catted down pipe or catless? If you have a catted system you may want to check your downpipe, it could be on the way out.
yokata156.00 |
05-06-2020, 07:35 AM | #140 | ||
Rep 242
05-07-2020, 06:34 PM | #141 |
enthusiast
116
Rep 221
Finally, found the time to post. Best time with Xhp stage 3 - 11.56@119 with 1.72 60ft which I was able to make it consistent 3 times. I'll stick with it considering my run-flats from the factory and heavy wheels (lease, so not changing anything ). And don't want to push more, I know I can practice to get 1.6 60ft but that's ok. Had cooler temps and 1/4 tank E30 blend (2gal E85/5.5gal 93 Shell).
The 1/4 mile runs: I've spent quite a bit of time evenings adjusting Xhp with limited choices (similar to Glemm) and found the best for my AWD as the following: 1. 10% set launch torque and 15% torque scaling after launch. No slippage, it just goes and heard a slight tire chirp 2. Shiftmap Editor set both D and S mode as After your Up-Shifts to -5% (1->2, 2->3, 3->4) the rest 0%. And After your Down-Shifts set to +5% only for 6->5, 7->6, and 8->7. 3. Adjusted Max RPM as shown 4. S Mode (Sport +) starting in S1 using launch control, let it auto shift 1st,2nd and 3rd gear at 6500-6600 range as set in max rpm, then manually ~6500rpm after. On the street: In Comfort/Sport (usually do drive Sport) I do like starting in 1st gear (D1) so take off in 2nd gear is OFF as I have experienced a hesitation in D2 and like D1 better. Overall the driving is great, shifts are perfect with Stage 3 with soft shift and stock shiftsmaps being off too. Very nice performance. So, both Oz thanks for suggesting Xhp and sharing experience, and Glemm also for additional details The car is amazing now.
05-07-2020, 07:09 PM | #142 | |
Rep 458
2019 M240i M Performance Edition / xDrive / ZF8 / BM3 Stg 2+ E30 / xHP Stg 3 / Dorch Stg 2 HPFP / Evolution Racewerks Catless Downpipe / MPPSK Exhaust / FTP Drop in Filter / FTP Intake Pipe / FTP Chargepipe / NGK 94201 Spark Plugs .022 / Michelin PS4S - 225/35/19 + 245/30/19
05-07-2020, 07:13 PM | #143 |
enthusiast
116
Rep 221
We can clean up and consolidate then but mod should do it. I can post later, sure.
05-07-2020, 07:15 PM | #144 |
Rep 458
You and Oz have now got me excited about playing around with my xHP some more. I went one step ahead and go xDelete so very interested to see what 100-200kmh and 60-130mph times will be with xdrive on and off.
boosted116.00 |
05-07-2020, 07:19 PM | #145 |
enthusiast
116
Rep 221
Great, yes you need to find what works best for you. I'm very happy overall with my both engine and trans tune.
05-07-2020, 08:45 PM | #146 |
Rep 1,363
You X-Drive guys are killing it. I think I'm probably running 11.50's now, but my 60' are likely 1.9x. Need to charge the Dragy and find out.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
05-14-2020, 03:54 AM | #147 | |
Rep 508
there's no chance to get 190 load with stock turbo at 6800rpm. bm3 just asks this, increases load/boost deviation tolerance and car gets what it gets. |
05-14-2020, 06:05 AM | #148 | |
Rep 55
yokata156.00 |
05-21-2020, 06:12 PM | #149 |
Rep 420
It was cool yesterday. + 8C. In my usual place, I was able to drive very quickly. In the tank 15% E85. The tank itself is full. The weight of the car with me is 1720kg. Map MHD 2 HPFP 102Ron. Time 100-200 7.55s. When I turned on JB4 Map 6 with Met, I drove 7.13s. This is the best time of this car!
M140IX. Turbo Pure 800 Cast.
05-21-2020, 06:20 PM | #150 | |
Rep 242
05-21-2020, 06:54 PM | #151 | |
Rep 585
Will you do Dragy quarter mile test again with meth? I'm sure it will be in the 10s with meth.
05-21-2020, 07:44 PM | #152 |
Rep 420
In the afternoon there is no way to drive 0-402m on that road. And at night it’s very cold for a good start. A little later, when it will be + 13 / 15C at night, I will definitely try in the same place. I am checking acceleration on a suspension bridge over a sea bay. There is always a wind blowing and cool. But 402m drive there is a problem. There is another place, but 40 km to go to it. Our city Vladivostok does not pamper us with good roads))
OzBMR574.50 |
05-21-2020, 08:33 PM | #154 |
Rep 1,363
That is beautiful. Where is it?
