05-17-2020, 09:49 PM | #1 |
Rep 132
Drives: M4 6 Spd, X6 G06 30d, G22 420i
Hi everyone, hope you are all keeping safe during these difficult times.
My 428i idle's very very rough, almost like its about to stall. I'll give a little back story. I've been running Bootmod3 Stage 1 93oct for almost 10,000kms now all stock and around 5000kms with a catless downpipe and everything was working and driving like a charm. The car then was due for a major service at 65,000 kms with spark plugs oil change etc all required, everything was allgood till the car came up and eventually popped up with 'overdue 500kms' and i started the car one day and it was like it was about to stall. This happens everytime i come to a red light as well and go to a full stop, car is about to switch off, rpms are very rough. I took the car into BMW my service advisor told me that I did not need to remove the tune so I did not. They serviced the car but they didn't see anything wrong with the idle. Stupid if you ask me. As soon as I jumped back in the car started it, immediately I realised... Very stuttery rough start, and if you just tap the accelerator pedal a little and let go the car is almost about to turn off. What could be the issue? There is no codes that come up, but sometimes a transmission ESG error comes up code CF1531 when the vehicle is switched off after a tune update idk if thats normal. I'm really worried. Even flashed it back to stock, still the same problem... Please someone help!! Thank you Edit: guys could this be an engine knock?? Please see video
~ Sapphire Black M4 G82 Manual
~ Mineral White Metallic X6 G06 30d M Sport ~ Sapphire Black 420i G22 M Sport #savethemanuals |
05-17-2020, 10:35 PM | #2 |
Rep 1,217
I would start by checking the spark plug gap. Improperly gapped plugs will cause a rough idle...not to the extreme that you described but still worth checking.
bmwaddictt57.00 |
05-17-2020, 10:37 PM | #3 | |
Rep 132
Tags |
n20, rough idle, rough start, roughidle |
