BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Best sounding n20 f30 exhaust
      10-07-2021, 01:01 PM   #1
gameson
Drives: 2015 BMW 320i N20
Just want to gauge opinion, what is the best exhaust sound for f30 n20?
I understand everyone taste is different.
For me personally, I don’t like that bang bang firecracker noise, so i like the smooth sound…
      10-07-2021, 04:17 PM   #2
drapzzy
drapzzy's Avatar
Drives: F82
2016 BMW 328i  [0.00]
its highly based on whatever you like but whats common usually is AWE catback with mid pipe and then they choose if they want to go catless or not from then, catless changes the cars tone. I have a muffler delete with primary catless dp, its loud but as a 16 year old bmw owner thats what i live for
      10-07-2021, 08:53 PM   #3
gameson
does a catless downpipe make the exhaust sound more high pitch?
      10-07-2021, 10:16 PM   #4
sqwinny
Drives: 2013 6MT 328i M Sport
Any muffler for a n20/335i/340i for the f chassis will fit.
I have the Active autowerk. It's louder than stock but still pretty quiet. I retrofitted the 335i/340i muffler instead of the 328i.
Something cool is someone is selling this for 50% the factory price. You can install this in your driveway with an exhaust clamp.
Active Autowerkes Axel Back 328i/328i xdrive https://f30.bimmerpost.com/forums/sh....php?t=1855341
This is N20, catless downpipe, removed resonator, Active Autowerks N55 335i rear muffler. It's really quiet all things considered. Stock air box here too. A little drone on the high way, but no drone if you don't get rid of the resonator. Stock turbo for this one. Yes the turbo spool is LOUD stock with an off the shelf tune stage 2 bootmod3.
Drive-up parking garage maybe 10-15 mph in 1st gear (6MT)
Drive-down same parking garage
MY13: TTE400 Stage 2 turbo, Spec Single Mass flywheel + Stage 3+ Clutch, FTP V2 Turbo Inlet, Evolution Racewerks Charge pipe + Boost pipe + Intercooler, Turbosmart Recirculating Diverter Valve, aFE grill scoop + aFE Magnum Force Cold Air Intake, B58 coil retrofit, eBay Downpipe, Active Autowerke muffler, DW400 LPFP, B58TU HPFP, M5 s63TU injectors, Bimmermilvs, e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block
sspade2463.00
      10-08-2021, 04:20 AM   #5
sspade
sspade's Avatar
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
No, just the opposite actually.
      10-08-2021, 08:48 AM   #6
mike@x-ph.com
mike@x-ph.com's Avatar
REMUS or active autowerke are perfect for daily drivers. They are balanced with a deep mid-range tone.
You can also add a downpipe for a more aggressive sound
https://x-ph.com/sale/
Phone number 702-494-9435
djacinto352.00
      10-08-2021, 11:33 AM   #7
BrysonDM
BrysonDM's Avatar
53
Drives: 2016 328I Xdrive MSport
Catless VRSF downpipe with Valvetronics F30 Muffler and K&N high flow filter is what I have. Isn't obnoxious but defs loud enough to get attention. Especially when you shift, get that braaap sound, and find the rev range from 1k-2.5k will net you some stock burbles and bangs that are a nice touch, and the increased turbo noises are a nice touch. You can DM me on Instagram if you want some audio clips. Same handle for pretty much everything - BrysonDM
      10-08-2021, 12:01 PM   #8
sspade
sspade's Avatar
Downpipe, resonator delete, drop in air filter and stock 320i muffler w/ Bootmod3 flash.
      10-09-2021, 08:40 PM   #9
snipagang
Drives: 2017 320i xdrive
are you stg 2? Hows the performance on the 320 stg 2?
      10-11-2021, 12:13 PM   #10
drapzzy
drapzzy's Avatar
Drives: F82
just saw this sorry but it makes the tone deeper and also adds a turbo sound around 700-1500 rpm
      10-12-2021, 12:22 AM   #11
Jag01cd1
Drives: bmw f30
Catless downpipe
Here is how my car sounds with catless downpipe + res delete
I am trying to make it a little more aggressive and deeper with the M performance exhaust. Any recommendations? Maybe add the res back?
https://youtu.be/Go8rcpXTzfg
https://www.youtube.com/watch?v=Go8rcpXTzfg&ab_channel=JaganathaChatooah
      10-12-2021, 07:01 AM   #12
johnung
You are talking about two different things. The exhaust sound, fullness, depth, tone comes from the internal exhaust engineering and design. It's the guts of the muffler. AWE is the best that I've heard. BMW MP exhaust sounds good too.
But the bangs, pops, burbles are programmed by the engine tune that you are running. BootMod3 has a whole dashboard to customize/program the way that you want it to sound. I ended up using BootMod3 to turn all that off, so I just hear the full deep sound of the exhaust system when I step on the gas.
Hope this helps!
