| 10-12-2020, 03:46 PM | #1 |
Rep 3
Drag tire setup
Hey guys, new to the forum but not to the car or racing.
Currently I am running a MHD stage 2 e30 tune, XHP Stage 3, Intake, Catless Downpipe and a 3" exhaust. Currently I have been able to consistently hit 7.5's in the 1/8th but I have had to turn down my launch control torque so I am not giving a smoke show. I am currently on little 255/35/19's and pulling 1.8 60's. My next purchase is going to be a dedicated drag wheel and tire set up because a stage 2 HPFP and a GC is in the works. My question is a 2 part one: A. How do you disable the low tire warning that only allows you to be in comfort mode? B. I am going to run 17's so should I run a 275/40/17 or a 295? Any additional advice would be greatly appreciated. |
| 10-13-2020, 01:20 AM | #3 |
2JZ-GTE
3544
Rep 4,480
![]() I've heard you can code it out but have not seen the process. I use esys. You could re-calibrate the sensors at a lower psi or just have them removed when you have the tires changed. |
| 10-20-2020, 09:31 AM | #4 |
Cheapskate
4727
Rep 5,029
You won't fit a 295 and probably won't find a properly wide 17 for it. a 17x9 with 275 is your best bet but many people run 255 and hook well. It's more about the compound than the width.
| 10-20-2020, 02:41 PM | #5 |
Rep 686
Drives: Your mom crazy
Garage List 2020 BMW M340i CURRENT [10.00]
2003 BMW 330i RIP [10.00] 2011 BMW 335i SOLD [10.00] 2016 BMW 340i SOLD [10.00] 2020 BMW X3M RIP [10.00] |
Someone on the B58 Enthusiasts Facebook group made a post about working with a coder that removed the low tire pressure error. Search the group posts or post an ISO message asking who it was.
| 10-20-2020, 08:05 PM | #6 |
Rep 6,106
Mine doesn't have the physical TPMS, just the rotational check. I'd assume if you code out TPMS to the "ghetto" version that I have, your problem would go away.
| 11-20-2020, 03:46 PM | #7 |
Rep 3
| 11-21-2020, 01:13 AM | #8 | |
Built Motor F30 340i
436
Rep 260
Supr3me596.50 alpinweiss34089.50 |
| 11-21-2020, 10:31 AM | #9 | |
Rep 686
2020 M340i
DAW UF-X; Wagner intake manifold/port injection; ID1050xds; Precision Raceworks St2.5 LPFP ECUTEK; Wedge Performance E70 tune KW V2; BC Forged EH173 |
SC_B5X436.00 |
| 06-25-2022, 03:50 PM | #10 |
Rep 14
Drives: Bmw 340i
Hey what did you end up doing for your tire setup
| 06-26-2022, 03:01 AM | #11 |
![]() 716
Rep 1,691
If you will buy a dedicated set go for the smallest diameter possible for faster acceleration.
2018 RWD 340i 8AT | M Sport | Catless MPPSK | TU HPFP | Stock Turbo
Tunes: Self Tuned via MHD | Fuel: E50/92RON/87OCT Web APP: https://true-acceleration.app/ |
| 06-26-2022, 07:09 PM | #12 |
![]() 96
Rep 163
| 06-27-2022, 02:54 PM | #13 |
Rep 99
This is 275/40/R18 on Apex profile 3. Lowered on BC BR coils, I needed to have the fenders rolled because I was rubbing.
2016 340i xDrive | Pure 800 | Dorch S2 | XHP S3 | bm3 | F80 Paul 94 + Meth Custom Tune | CTS Intake | VRSF Catless DP | BMS Elite CP | Snow Perf VC50 + Dual CM7 CPI | BC Racing BR Coilovers | Apec ARC-8 + Hankook Ventus RS4 |
F30Pat2.00 |
| 06-27-2022, 04:57 PM | #14 | |
Novice
362
Rep 729
currently rn the car came with the classic 400m wheels from factory and for awhile I do not plan to get aftermarket rims. I was told I could run 265/35/18s in the rear but I want to know the maximum meatiest tires I can run for the rears and fronts without losing the performance benefits. currently rn I am running 255/40/18s in the back I believe and 225s in the front. michelin pilot super sports. |
| 08-01-2022, 02:25 PM | #15 | |
Rep 18
| 08-01-2024, 07:49 PM | #17 |
Charles B
158
Rep 111
Throw the wheels with TPMS in the trunk.
rusty_sojah113.50 |
| 08-02-2024, 01:48 AM | #18 |
Rep 570
so a few years back i had a FBO e93 that was getting a lot of wheel spin and someone local to me recommended i get a set of firestone firehawk indy 500's for the rear. I did and man did it make a noticeable difference. i was running 19's at the time and am now about to get another pair for my rears on my current 440i actually. I'm thinking Pilot Sports in the fronts for my current setup.
| 03-13-2025, 01:49 PM | #19 | |
Rep 70
| Bookmarks |
| Thread Tools | |
