03-20-2025, 03:55 AM | #4775 | |
![]() 638
Rep 1,492
Too much corrections.
2018 RWD 340i 8AT - M Sport - Catless MPPSK - TU HPFP Stock Turbo
Tunes: Self Tuned via MHD - Fuel: E50/92RON/87OCT https://datazap.me/u/ims/e45?log=0&data=4-23-36&solo=4 |
03-23-2025, 12:34 PM | #4776 |
![]() 638
Rep 1,492
03-25-2025, 11:12 AM | #4777 | |
![]() 123
Rep 253
G21 M340i XDrive Touring |
03-25-2025, 11:41 AM | #4778 |
![]() 638
Rep 1,492
Yup, stock turbo pretty much maxed out
![]() In this log I managed to reduce WGDC a little with even more boost: https://datazap.me/u/ims/e35-1?log=0...6&zoom=102-166
Tunes: Self Tuned via MHD - Fuel: E50/92RON/87OCT https://datazap.me/u/ims/e45?log=0&data=4-23-36&solo=4 Last edited by IMS-340C; 03-26-2025 at 08:53 AM.. |
03-25-2025, 04:54 PM | #4779 |
![]() 0
Rep 35
Hey guys,
Recently my 340xi has been acting weird on both E30 and 93 BM3 Stage 2 tunes. Poor throttle response, and I actually got a drivetrain error and had to limp home after a car show. I pulled codes thru BM3 and am constantly pulling “100001 Throttle valve, function: sticks briefly” and “100501 Throttle valve 2, function: stiff, too slow” I did 2 quick pulls in sport and the logs are below. BOOTMOD3 STAGE 2 93 LOGS Please let me know. If my motor is bound to blow I want to stop driving this POS lol Last edited by BeamChop; 03-25-2025 at 09:02 PM.. |
03-27-2025, 06:21 PM | #4780 |
Rep 5
Knock at WOT
Hey guys. Currently on a custom flex fuel tune from CD919. The car performs well in normal cruising and semi-WOT (50%ish throttle angle), but WOT has issues as of recently. When shifting gears at WOT the car will pull timing, and sometimes set off the Knock Detection. Can anyone help me out?
Car is currently on E50 (X85 Mixed with 100 Octane to get an E50 mix) pushing 500hp and 500 lb/ft of Torque on the stock turbo. Pure 800 turbo is coming in a week. Mods: VRSF Downpipe BM3 Flex Fuel Kit MST Cold Air Intake MAD Axle-Back Exhaust Log #1 w/ Knock: https://www.bootmod3.net/log?id=67db...02fb3bd428b927 Log #2 without Knock: https://www.bootmod3.net/log?id=67db...e26a0c627c36e3 EDIT: Figured out my turbo seals are going bad. Oil pressure dips as soon as boost is built and then overshoots once I let off. Car is also burning a quart of oil 2 weeks after changing my oil. Last edited by Anp0w; 03-30-2025 at 08:35 PM.. |
04-03-2025, 01:42 AM | #4781 |
Rep 4
Hey guys, I have just flashed MHD state 1 95ron, how do my logs look?
Worth trying the 98ron map? https://datazap.me/u/86daviesjk/m240...31&zoom=26-103 |
04-03-2025, 07:17 AM | #4782 | |
![]() 638
Rep 1,492
Looks very good, yeah you can give 98 a try.
04-04-2025, 05:11 AM | #4784 |
![]() ![]() 117
Rep 65
Drives: G01 X3 M40i
04-04-2025, 05:13 PM | #4785 | |
![]() 638
Rep 1,492
Timing corrections look good but fuel pressure dropping and ignition timing crashing.
04-04-2025, 09:13 PM | #4786 |
Rep 1
Unplugged the JB4 w BEF and flashed stage 1 93 MHD. Felt stronger. 93 shell and couple gallons of e85 — prob e20 or less. Can I just add more e85 to get rid of the corrections shown? These runs are 10 min after the flash — maybe it just has to adapt
I was low to mid 14 AFR w JB4 throughout. This is better but still high? https://*********************/graphs/l...2-10-03.46717/ https://*********************/graphs/l...2-09-22.46716/ |
04-07-2025, 03:13 AM | #4787 |
Rep 4
04-07-2025, 03:38 AM | #4788 | |
![]() 638
Rep 1,492
Looks great.
04-12-2025, 09:36 PM | #4790 |
![]() 2
Rep 16
https://datazap.me/u/oregano/stage-2...og=0&data=3-20
possible hpfp crash? moved to california and i needed to add e85, so i added 2 gallons. It looks fine in after the initial throttle stab though so idk. Stage 2 91 Last edited by Bondy; 04-12-2025 at 09:43 PM.. |
04-13-2025, 03:24 AM | #4791 | |
![]() 638
Rep 1,492
Yeah HPFP struggling, but at least timing corrections looking good.
04-13-2025, 06:16 PM | #4793 |
![]() 2
Rep 16
04-14-2025, 01:38 AM | #4794 |
![]() 638
Rep 1,492
If you reduce Ethanol you will get timing corrections and you will need to run Stage 1.
04-14-2025, 01:15 PM | #4795 | |
![]() 2
Rep 16
Edit*. Shouldn’t the e30 maps have less boost at lower rpm to keep the fuel pump ok? Last edited by Bondy; 04-14-2025 at 02:17 PM.. |
04-14-2025, 02:49 PM | #4796 |
![]() 638
Rep 1,492
Yes TU can handle it easily, it can push E42 at 22 psi or E50 at 18-20 psi.
