BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 340 AWE Exhaust + Midpipe Review
      02-03-2018, 04:59 PM   #23
3ToAgree
3ToAgree's Avatar
Drives: NA
Originally Posted by G.Newt View Post
Depends.. If you're coming from 335/340, it's not really worth it. The BMW BBK is 4-piston fronts/2-piston rear Brembos, + larger diameter drilled rotors. We already have 4-piston Brembo fronts. So I'm paying $3k+ for better rear brake calipers and upgraded rotors? Unless you track the car you won't notice much at all.
That's not far off. I did notice a difference with the larger rotors and different pads but you're right that the base BMW has a great set of brakes to start with. When it comes to appearance, no comparison. You can find that brake kit online for around $2k from dealers so not a bad deal especially if you install yourself.
      02-03-2018, 08:43 PM   #24
G.Newt
Drives: CT4-V Blackwing 6MT
I'd rather just get them powder coated for about $400-$500 with BMW decals lol. The yellows are usually on sale, but I really want the orange haha. No way I'm paying $2,400 for them though.
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed
DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2
      02-03-2018, 08:52 PM   #25
3ToAgree
3ToAgree's Avatar
Drives: NA
Still have those pygmy rotors though the rear calipers, even though still 2 piston, do look a bit different with the BBK
      09-12-2021, 05:57 AM   #26
Jdpfox
Drives: BMW 340i MSport
@ZTZ1010…great system. I just installed mine and I love it, especially after flashing to accommodate it. By any chance do you recall what the tip inlet diameter was. I got the 102 chromes based on availability but I don’t really like them.
      03-05-2025, 04:12 PM   #27
ra340to
Drives: 2018 340i
any difference between AWE vs Dinan midpipe both seemed to be made with T304 steel so guessing both are in same quality. Depending on which midpipe I get in future I may add their respective axle back exhaust.
Any feedback would be appreciated.
      03-10-2025, 11:36 AM   #28
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
AWE midpipe is resonated, its going to get you a cleaner tone
https://x-ph.com/sale/
Phone number 702-494-9435
