02-21-2024, 04:17 PM | #1 |
Rep 5,395
BM3 Performance: Static Map vs MultiMap?
Has anyone ever dyno’d a static BM3 map versus that same octane map within MultiMap to see if performance is identical?
I’m planning some dyno testing. If someone has already proven that they are identical, then I won’t waste my time/money repeating those dyno runs. Details below. Thanks! 335i N55 EWG 93 Octane in fuel tank BM3 Stage2 93 Versus Stage2 MultiMap set within to 93 BM3 Stage2+ 93 Versus Stage2+ MultiMap set within to 93 |
02-21-2024, 04:32 PM | #2 | |
Rep 4,161
Mods: Yes.
02-21-2024, 05:41 PM | #3 |
Rep 5,395
My mods that may matter for Stage2 93 testing are:
Fabspeed HJS Catted Downpipe BMW M Performance Exhaust MST Intake MST Turbo Inlet Pipe TurboSmart BOV, Plumb Back model MAD Race Intercooler For Stage2+ 93 testing: Dorch Stage2 HPFP For Stage2/2+ FlexFuel MultiMap w E85 Walbro/TIA Model 535 LPFP 3.5bar MAP Sensors Possibly M5 S63 Fuel Injectors |
02-21-2024, 05:52 PM | #4 |
1296
Rep 3,536
I remember seeing someone do it before and it was fairly close and within percentage of error etc.
02-21-2024, 05:56 PM | #5 |
Rep 5,395
Really!? That would be great news to me. If you happen to remember more details please let me know. I have enough questions that I’m trying to answer with these experiments. It would nice to not have to do this one too
02-21-2024, 05:59 PM | #6 |
1296
Rep 3,536
It was in one of the Facebook groups and I believe it was a 335 or 235. I dont remember beyond that.
02-21-2024, 06:09 PM | #8 |
1296
Rep 3,536
Not a bad idea.. just remember map changes need a full pulls to adapt etc
02-21-2024, 06:41 PM | #9 |
Rep 4,161
if it's on FB, it never happened. I hate those groups, because unless you have FB AND are a part of the group, you'll never see it.
Mods: Yes.
02-21-2024, 06:46 PM | #10 | |
1296
Rep 3,536
Did you post this question in the bm3 group too?
02-21-2024, 06:52 PM | #12 |
Rep 5,395
Can you please elaborate? I intend to do full WOT pulls while on the dyno. Are you saying that if I do a pull on the dyno. Then flash a different map. That then I have to do another full pull to get it to adapt before I can do another pull that will count?
02-21-2024, 07:05 PM | #13 |
1296
Rep 3,536
You have to remember that the air fuel target may change and the adaptions are reset so it usually takes a run or two before it figures things out etc
02-22-2024, 10:47 AM | #14 |
Rep 190,951
Looking forward to the results, I don't expect a big difference between the two under normal circumstances.
02-22-2024, 12:53 PM | #15 |
Rep 7,611
Does BM3 reset adaptations on a map change? I'm pretty sure MHD doesnt and their instructions specifically say its not needed to do so manually
02-22-2024, 12:57 PM | #16 |
1296
Rep 3,536
It's unclear but I do know that when I was going through the tuning process with my n55, I needed a few runs between flashes for the tune to properly setting with fueling changes..
02-22-2024, 03:28 PM | #17 |
Rep 5,395
I don’t know either about adaptations, but it’s an excellent question to ask. I’ve got messages into a few guys who should know for sure. I’ve attended a couple of dyno sessions where bootmod3 was definitely flashed in the middle of dyno runs. I don’t recall anything special being done, but I’ll find out. Also the dyno itself isn’t at a small shop. It’s at a major facility with a lot of experience so I’ll see what they say as well.
02-22-2024, 03:38 PM | #18 |
Rep 5,395
Yes, I agree. This static map vs MultiMap is really a side issue anyway. The study is really about stock N55 EWG turbo vs Pure500 with different fuels and tunes. I’m not doing to typical dyno for the highest horsepower number. I’m trying to demonstrate where the stock N55 EWG maxes out reliably, and then what the Pure500 adds to that. Several companies like the concept and have been offering help. I’m getting the fueling nailed down so the car doesn’t hit a fueling wall before the Pure500 capacity. Fun stuff!
02-22-2024, 07:50 PM | #19 |
Rep 7,611
If it does reset adaptations you will probably want to "drive" for a minute or two on the dyno doing through the gears at part throttle then maybe do one WOT pull before you do the 'real' WOT pull. You can log both but if the first one is an outlier consider it an adaptation period. Of course if time allows and its feasible you would want more than one pull for each test anyways to confirm repeatability
n55david1295.50 |
02-22-2024, 09:25 PM | #20 | |
Rep 5,395
02-22-2024, 09:33 PM | #21 |
Rep 4,161
You’ll just want to rent the dyno for “time” instead of pulls - it’s a better deal typically and you can get more runs in.
I’ve always known BMWs needing time to “adapt” to a new MAP, usually over the course of 1-2 WOT runs. But maybe it’s not a thing anymore. I’m interested in results - mostly how the HPFP effects a the EWG on pump. How is the IC holding up? Have you compared its logs (wgdc, IAT, etc) to your Evo 1? |
02-23-2024, 06:29 AM | #22 | |
Rep 5,395
I daily now with a FlexFuel Bootmod3 Stage2+ MultiMap tune with 93 to E85 in the tank depending on fuel availability and time of year since I live in a moderately cold climate near Philadelphia. So for the past year I have only been thinking in terms of dyno testing the stock turbo vs the Pure500 on full E85 to see where they both max out. But I got deeper into talking to about a dozen guys who have installed the Pure500, and talking to Pure about the types of customers buying the Pure500. Really two separate large distinct groups emerged based on fuel used. There are 93 Octane guys running Stage2, or Stage2+ if they have an upgraded HPFP. And there are FlexFuel guys running Stage2 or Stage2+ MultiMap, with E30 to E85, depending on their HPFP/LPFP upgrades. So there are a lot of questions being asked and I’m curious about many myself. So why not try to answer them with real data? It will be fun! I really like the MAD Race Intercooler. Most ICs get under pressure at high RPMs and their IATs creep up. The MAD Race really pushes them down. I did some logs last summer on a 98°F day and I was really impressed. I recommend the MAD Race to everyone. (There is no cutting during installation as some people mistakenly say.) I never really compared the MAD Race to my old Wagner EVO1 Competition. They are really designed for different configurations. I was really happy with the EVO1 when I was running BM3 Stage2 on 93 Octane, so probably 400hp or less. It was perfectly sized for that role. I did a lot of testing with it on sequential WOTs and it held up well before showing any signs of heat soak. But once I moved to ethanol and upgraded fuel pumps and ran higher ethanol, the MAD Race was really necessary. It’s been great. |
n55david1295.50 |
