01-17-2022, 02:03 PM | #1 |
Capable
Rep 111
FS: N55 PWGPS2, DP, Intake, PI kit, PR coils, IC
Hello all,
Recently started to part out. I will have more parts coming down the road (likely Ohlin R&T coils and HRE wheels w new ps4s). Knocking 30 percent off the price clear across unless something wrong with the parts, and no need to trade your stock parts. https://drive.google.com/drive/folde...UP?usp=sharing Pure turbo for 2013 PWG N55. $2000. Comes with GFB+ installed, turbo has maybe 15k mainly from driving to and from work. No shaft play, and everything is in working order. left on the manifold. I do not need an exchange/core so that saves a good amount of money. Comes with the inlet pipe and will include a turbo to intercooler pipe as well. Wagner Evo comp 2 Intercooler. Black $550. See photos, fins are in good condition and i will clean it prior to pick up. These are all fresh of the car photos. Thing kept air cool like a champ, even running 22 lbs. Fuel-it Port injection kit, split second controller, and new set of 550 injectors. $1000. Comes with hardware required, worked good with 100 percent ethanol but including new injectors to relieve any concern. ER Downpipe. $300 Has been coated black hi temp ceramic by myself to maintain stealth look. BMS Intake, blue 160. BMS Catch can. 100. a little scratched but everything there. Other parts not in the drive, Light single mass flywheel and stage 3+ clutch from Spec. About 10k on it. It'll handle all the power, but man its grippy. might be best to pair this with a steel single mass instead of aluminum. You can take it all for 500. Will try to check this thread daily, Thanks for looking. |
01-29-2022, 10:01 PM | #6 |
Rep 1,934
Rwd?
02-07-2022, 02:34 PM | #9 |
Capable
Rep 111
02-09-2022, 01:39 AM | #10 |
Rep 22
02-10-2022, 01:30 PM | #11 |
Capable
Rep 111
