04-05-2020, 04:20 PM | #1 |
Rep 72
Fuel injectors upgrade ?
Does anyone knows what is the limit of the stock injectors on n55. I am going to build full bolt on car with garret 3582 and i wanna know where is going to be my limit on fuelling. And also read about an fuel injector upgrade in the s55 from m5. Is it possible in the n55 this upgrade or port injection is the only way to add additional fuel.
04-05-2020, 05:31 PM | #2 |
Rep 7,622
Ive seen mid 500whp with stock injectors, no PI or LPFP, just HPFP. Not sure how much further you can go beyond that, but at about 700 you are going to be nearing the limit of the stock bottom end anyways; how far do you want to push it?
04-06-2020, 12:55 PM | #3 | |
Rep 176
Not sure if the ethanol was a contributing factor, but upgraded injectors may add a little more head room for reliability? |
04-06-2020, 01:46 PM | #4 |
Rep 72
I am planning to go beyond 600whp on fully build motor. How about this HPFP from xdi is it possible to run it with custom flash ? I mean different than the mhd and bootmod3 ?
04-06-2020, 02:01 PM | #5 |
Rep 7,622
You should be able to run any HPFP with a custom tune. I believe XDI and Dorch are already pre-configured in OTS maps, but spool is not. The tuner should be able to make any of them work though.
04-06-2020, 02:11 PM | #7 | ||
Rep 72
So no one didn't try injector upgrade from M5 on N55 ?
04-06-2020, 02:53 PM | #9 |
Rep 72
Can you share what dyno results you have with this setup and what time do you have 100-200 ?
04-06-2020, 03:54 PM | #10 |
Rep 1,105
04-06-2020, 05:04 PM | #11 |
Rep 176
My results on e50. I'm xdrive.
07-23-2020, 03:55 PM | #13 |
Rep 7
Does this go to OEM injectors as only? What if its Bosch? I mean both are being manufactured by Bosch, but one is officially from BMW, do they both have the same limits? I know on none tuned cars they work the same way...
07-23-2020, 03:57 PM | #14 | |
Rep 7
