BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > n55 problems
      01-14-2021, 07:00 AM   #1
Widowmaker_f32
Lebanon
Drives: BMW 435I F32
n55 problems
Did anyone have any problem with there car after tuning them ? engine knocking/whole car shivering like crazy with the drivetrain message popping on the screen?
i have an odd problem with mine.
      01-14-2021, 08:03 AM   #2
AsianBill
Drives: 2017 M240i xDrive
I had this issue one time and it was the only time I left my car outside for the night, and it was cold out through the night and in the morning. Car started fine but shook (felt like someone was pushing the car back and forth) for a few seconds when I started driving and was under 10 mph. After a few seconds it went away and has not come back.
If you got a drivetrain message you may want to scan the car to see if there were any codes thrown. I've heard that bad gas can contribute to this, and I would assume bad spark plugs/coils can cause this as well.
2017 M240i
CD919 Custom E40/flex fuel tune | catless downpipe | TU Pump | XHP Stage 3 | MHD flexfuel kit
      01-14-2021, 10:53 AM   #3
thejeremyman9
thejeremyman9's Avatar
4357
Drives: 2015 BMW 335i
There's a million reasons you can have a drivetrain malfunction. The tune could have just exacerbated existing hardware problems. Scan for codes as mentioned above. You also didnt provide any context - miles, mods, last time plugs/coils were changed, did the problem go away after driving, did you try flashing back to stock, etc etc.
      01-14-2021, 06:50 PM   #4
Tpriest7893
Drives: Bmw 335i f30 N55 ( sold)
  [0.00]
2012 bmw 335  [0.00]
02 2002 m3 Vert  [0.00]
What tune
2012 bmw 335i sedan
VRSF catless DP
VRSF 5? HD IC
Stock intake(had open before and was sick of noise)
BMS CP
550i 351m rims with 275/245 set up.
No tune as of yet.
      01-14-2021, 09:45 PM   #5
harkes
harkes's Avatar
China
1075
Drives: M135i, E39 M5, NSX and AE86
First step is always to flash back to stock to check if tune is at fault.
(A Dane in China)
exE36M3487.50
      01-18-2021, 02:53 PM   #6
Widowmaker_f32
Lebanon
yes i did flash it back to stock.. no more problem flashed it back again to stage 2 the problem came back i have 90k miles on odo running on f82 one step colder spark plugs and delphi ignition coils..
changed them once i got the tune
mods :
downpipe
charge pipe
cts cold air intake
vrsf intercooler
      01-18-2021, 02:55 PM   #7
Widowmaker_f32
Lebanon
sadly i did flash it back to stock and it was a custom tune so we did another file with some mods too and the tuner rechecked if there's any thing wrong with the file but there was nothing.
      01-18-2021, 02:57 PM   #8
Widowmaker_f32
Lebanon
no it's everytime i'm in 4th gear high rpm and pressing that throttle i get backfire/shiver/ loss of power etc..
      01-18-2021, 03:08 PM   #9
Widowmaker_f32
Lebanon
last time i had the problem the car started shaking tried turning it on/off nothing happened scanned it for fault codes and gave me
140010 Combustion misfires, several cylinder: detected
140110 combustion misfire, cylinder 1 detected
140001 misfire, several cylinders: fuel injection is switched off
140101 misfiring cylinder 1: fuel injection is switched off
      01-18-2021, 03:23 PM   #10
Tpriest7893
  [0.00]
2012 bmw 335  [0.00]
I mean if your getting those codes and you said the only change besides tune was plugs and coils then problem could be there. Did you change yourself or get it all done somewhere?
2012 bmw 335i sedan
VRSF catless DP
VRSF 5? HD IC
BMS CP
No tune as of yet.
      01-18-2021, 03:39 PM   #11
Widowmaker_f32
Lebanon
at a workshop, i'll be changing the injector #1 next step.
      01-18-2021, 04:39 PM   #12
thejeremyman9
4357
If the problem seem to be with #1, you can try swapping the plug and coil from #1 to another cylinder and see if the problem follows the coil/plug. If it doesnt, then injector is likely.
      01-18-2021, 07:04 PM   #13
harkes
harkes's Avatar
China
1075
I got the exact same problem 5 days ago and is changing a coil today. Moved things around and I know for sure it is the coil (only 3500km on it). Only happens on boost at WOT.
(A Dane in China)
      01-18-2021, 07:08 PM   #14
harkes
harkes's Avatar
China
1075
My error messages from my faulty coil. Is it your mechanic that has diagnosed it as an injector?
(A Dane in China)
      01-18-2021, 11:46 PM   #15
Widowmaker_f32
Lebanon
we've tried 2 set of coils still..
i ordered a set of after market spark plugs and and ignition coils from NP BOOSTED waiting for them to arrive.. but i'll be swapping injectors once the lockdown is over here in Lebanon.
      01-19-2021, 12:52 AM   #16
Widowmaker_f32
Lebanon
i have 0 faults on stock plus i drove it for the last month having 0 problems and 0 fault codes. the problem happens to reappear everytime i flash it back to stage 2
it's frustrating tbh
i'll be checking for fault codes once i get in the car and update you guys.
      01-19-2021, 06:27 AM   #17
Widowmaker_f32
Lebanon
so here's an update, 0 faults DME And TCU
attached:
      01-19-2021, 12:27 PM   #18
Rolynyari620
Drives: 335I N55
Did changing the coil fix the problem for you?
      01-19-2021, 11:58 PM   #19
harkes
harkes's Avatar
China
1075
Yes
(A Dane in China)
      11-05-2022, 11:57 PM   #20
Jake17958
Drives: Bmw 535i Xdrive
Hello I'm new to the turbo bmw game. I'm looking at purchasing a 2012 bmw 335xi but it is throwing a few codes (p3149, p15b8, p3164, p0300, p0206) and they all seem to point to fuel injectors or a hpfp and I was wondering if im correct or if there would be something else causing these issues any help would be much appreciated thank you in advance.
      11-06-2022, 06:42 PM   #21
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
Don't buy it...
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
