01-16-2021, 08:18 AM | #1 |
Rep 2,357
Dirt cheap "Delphi" coils
Hey
Got a misfire, swapped things around and it is a coil. Put in 6 of these dirt cheap coils so apparently one tapped out after just 3500km https://item.taobao.com/item.htm?_u=...d=596667348131 I'll let you know how long before the next has had enough. Price / coil: USD16.2
(A Dane in China) Last edited by harkes; 01-18-2021 at 08:13 PM.. |
01-16-2021, 10:01 AM | #2 |
Car Hypochondriac
335
Rep 901
To be fair, I bought an entire kit from fcp euro that were legitimate, full-price Delphi - one failed in a month.
Replaced with the newer Eldor model and no issues since.
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
01-18-2021, 08:17 PM | #4 |
Rep 2,357
Got two new. Looks legit One for the trunk to join the obligatory quart of oil
(A Dane in China) |
01-18-2021, 08:19 PM | #5 |
Rep 2,357
I'd probably go with the Eldors also, but cannot seem to find them. Correct that these are not officially for the N55 but for some Mini Coopers and Rolls Royces?
(A Dane in China) |
01-18-2021, 09:19 PM | #6 | |
Rep 3,695
My understanding is BMW switched from Delphi to Eldor for its new engines & coils, and this fits many engines including the N55. FCP Euro sells an OE version (same part w/o the BMW stamp) for $32. |
01-19-2021, 01:28 PM | #7 |
Rep 643
what drove you to replace the original ones?
M235i rwd 6mt
01-19-2021, 02:25 PM | #8 |
Rep 3,695
I was having intermittent misfires issues under load that went away when I changed coils and went back to stock gap on my NGK’s.
Was it the plugs or coils, IDK, but my coils had a lot of hard track driving on them so went ahead and changed them. |
01-21-2021, 07:03 PM | #9 |
Rep 461
Will those eldors fit a f36? FCP says they wont. Which confuses me because they say they will fit an x5. Thought x5 and f36 had same motor.
Zm2, you are running them and you have n55 right? Last edited by 435gc; 01-21-2021 at 07:24 PM.. |
01-21-2021, 07:22 PM | #10 |
Rep 3,695
Their suggested fitment list isn’t complete, so IDK for sure. I gave them a shot bc there were lots of N55 guys in the product reviews saying they worked for their cars.
01-21-2021, 09:12 PM | #11 |
Rep 461
Thanks.
I had a couple misfires today while doing a pull getting my ps2 dialed in. Plugs are less than 5k miles, coil packs are 67k miles. Never an issue with the stock turbo at 22psi. Now misfire with ps2 at 22psi. Dont know if increased hp would exacerbate an old coil? Figure I'd start by swapping in new ones. Just ordered the eldors. Will report back on fitment. Last edited by 435gc; 01-22-2021 at 01:00 PM.. |
ZM22810.50 |
01-21-2021, 09:24 PM | #12 | |
Rep 3,695
To compare I’m not at your power level, but I’m running BM3 Stg 2+ E30 (20.6psi target) w/ Dinan turbo (442whp on a Dynojet). |
01-21-2021, 09:51 PM | #13 |
Rep 461
I'm not 100% but they are either .020 or .022.
What issues were you having with the .020 gap? Are you sure it was the gap if you changed the coils at the same time? I never had a misfire before the ps2 went in. I had always read that the narrower gap helped prevent misfires with higher hp/higher boost applications. Seemed to hold true until today. What gap are you running harkes? Last edited by 435gc; 01-21-2021 at 09:58 PM.. |
01-21-2021, 10:53 PM | #14 | |
Rep 7,606
If your misfires just started i would check for a code/shadow code for one cyl and see if you can swap a coil to see if it follows. If no codes and coils doesnt solve it, i would try a bigger gap or OEM plugs with OEM gap. |
01-21-2021, 10:56 PM | #15 |
Rep 3,695
I was getting little misfires under WOT when doing logs or dyno runs.
The eldor coils helped make it happen less often, but it would still appear every now and then and was annoying. A new set of NGK’s gapped wider to 0.026” solved it. We don’t think it was a single plug bc the little misfires would happen on different cylinders until the plugs & gap were changed. |
01-21-2021, 11:50 PM | #16 |
Rep 461
What do you mean by little misfires?
I got drive train malfunction with limp mode. Codes showed multiple misfires and injection switched off one of the cylinders. |
01-22-2021, 08:23 AM | #17 | |
Rep 3,695
Hopefully the coils fix it. Could as be an issue with the tune? |
01-22-2021, 10:57 AM | #18 |
Rep 461
Here is a log when the issue occurred.
https://datazap.me/u/435gc/ps2?log=0&data=1-3-4-10 I typically need to do 3rd gear pulls do to lack of location to get up to 4th gear speeds. Car was feeling great, pulling hard. I shift to 4th wait a second or two and take my foot off the gas and start to upshift and brake. That's when the drive train malfunction popped, as I was braking. Any insight would be appreciated. For reference when looking at JB4 logs. For the fuel pump values: each value represents 150 psi. So 15 is equivalent to 2250 psi. For trim values: 25 is 0% trims, 50 is +33% trims, 0 is -33% trims.
2015 435i XDrive Gran Coupe M Sport 8AT - Track Handling Package - M Brakes - PS2 - VRSF Charge Pipe - VRSF FMIC - BMS Intake - JB4 with MHD BEF - AA High Flow Catted DP - BMS Meth Kit 70% Meth - TurboSmart PB DV - MST V2 inlet - xHP Stage 3
01-22-2021, 11:40 AM | #19 | |
Rep 3,695
01-22-2021, 01:07 PM | #20 | |
Rep 7,606
I don't see anything in the log that would explain misfires. Timing looks fine and is reasonably conservative if you are spraying alot of meth. You do have a small throttle closure near the top of 3rd and im not sure why. Also don't know why fuel trims are positive if you are spraying meth, unless the BEF accounts for that or its because the ECU is seeing less PSI than you are actually targeting? |
01-22-2021, 01:25 PM | #21 | |
Rep 461
When I restarted the car it was still in limp mode and running rough. Codes still present. I cleared the codes and it ran fine after that. Guessing the injector cutoff was still in effect until the codes were cleared? Yeah this was the first time this has happened. I was guessing that the fuel trims may have been positive due to the high level of boost and that I may be reaching the limit of what fuel support the single #10 nozzle can provide? I have a dual set of #7 nozzles that I have been meaning to install. I am relieved that, from what I am hearing, the issue doesn't look to be an AFR issue? That I assume would be indicative of a much more expensive problem to fix like a compression leak? Oh and likely unrelated, I had a catless downpipe detected code present as well when I scanned after the limp mode event. Never got a CEL. Dunno if AA will honor a claim for no CEL but present on scan.
01-22-2021, 01:40 PM | #22 | |
Rep 7,606
I dont see AFR target in the log but the general trend (decreasing with increasing RPM) and values look reasonable. If shutting off the injectors was a response to the misfires it detected, then yeah, you might have needed to clear those codes before it thought the issue was gone and could resume normal operation. I don't know what you mean by compression "leak". If you mean low compression in a cylinder, that's unlikely. If that was the case it wouldnt be an intermittent problem. EDIT: what code specifically for the DP? I get shadow codes for cat efficiency sometimes with fabspeed but my catalyst monitor is READY. Thats what matters. |
