02-28-2015, 05:02 PM | #1 |
Rep 10,346
Brake pkgs explained.
Not sure if posted before but here you go. Interesting that the sweep area on the front rotors is the same for the 4/335i regardless of the brake pkg. The front brake pads are interchangeable.
http://www.turnermotorsport.com/t-br...fferences.aspx http://www.turnermotorsport.com/t-br...fferences.aspx Last edited by F32Fleet; 03-11-2015 at 07:02 AM.. |
02-28-2015, 05:21 PM | #2 |
Rep 410
Drives: One car with good steering ;)
Great find, that'll definitely answer some of the never-ending questions that occur in this sub-forum. Maybe it should even get sticky-ed.
03-02-2015, 01:21 PM | #4 |
Rep 418
Excellent. Please sticky. Also applies for 35d models and various others too. Portefield RS4 pads need adding in too though.
AP1656 AP1609 |
03-02-2015, 02:59 PM | #5 | |
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
http://www.turnermotorsport.com/t-br...fferences.aspx |
03-02-2015, 03:24 PM | #6 |
Rep 1,649
Props to TMS for putting this together. great resource.
One thing to note for 335 cars. while the "swept area" is the same size due to the pads being the same shape across base/m sport/ m perf; this does not mean all is equal. with the larger 370mm rotors you end up with more area of rotor surface that moves under the pad with each rotation of the wheel. this in theory would lead to better stopping power and cooling given the same pad compound. On the street, could one tell the difference 340 vs. 370 with the same pad compound and tires? probably not. But I am sure an experienced driver on track could. |
12-03-2015, 09:12 PM | #7 | |
Rep 4,323
12-07-2015, 12:06 PM | #8 |
Rep 4,979
Please sticky
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
12-07-2015, 01:57 PM | #9 | |
Rep 7,047
A larger rotor has the potential to have a greater sweep area, but that depends on the brake size, and where the pad is located from the center of the rotor. The 2 brakes in question use the same pad size, so that factor doesn't change. If the pad is located at the same distance from the center of the rotor on both the 340mm and 370mm rotor's, then the swept area is still the same for both rotors. For the 370mm rotor to get more rotor under the pad, it's pad needs to be located farther away from it's center. Is that true for the 370mm rotor compared to the 340mm rotor? IIRC, both brakes use the same calipers, brake pads, caliper mounting points. If that is true, then swept area would remain the same between the 2 rotors. If the pad is located at the same distance from the center of the rotor for both rotor sizes, then the larger rotor will simply have more surface area that will not be touched by the pad. A larger rotor does have a larger overall surface area that can help dissipate heat better. So on the track that can help keep the rotor color potentially leading to less brake fade. Last edited by RPM90; 12-07-2015 at 02:14 PM.. |
12-08-2015, 09:44 PM | #10 | |
Rep 1,649
Just for giggles I wanted to roughly see how much extra area my $600 for the M Sports got me on the front: area of a circle = pi r squared my crude measure of swept area is ~75mm so ((370 / 2 ) sq * 3.14)) - (((370 - 75) / 2 ) sq * 3.14) = ~39,151 sq mm vs. ((340 / 2 ) sq * 3.14)) - (((340 - 75) / 2 ) sq * 3.14) = ~35,619 sq mm so 3531 sq mm more swept area on the 370 mm rotor set up. |
12-21-2015, 12:09 PM | #11 | |
Rep 1,055
340mm x 30mm 370mm x 30mm Part Numbers for Reference: 340mm equipped F30: http://www.realoem.com/bmw/enUS/show...diagId=34_2312 370mm equipped F30: http://www.realoem.com/bmw/enUS/show...diagId=34_2312
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch |
