09-03-2016, 03:05 PM | #1 |
Rep 114
Cruise control can't be activated
I can not activate cruise control. When I push cruise control button, cruise control mark goes to the 30km/h. And when I am trying to set the speed, pops out the warning that "cruise control can not be activated". Car does not show any faults. What could be wrong?
E92 M3 Silver Frozen Edition 2012
F90 M5 2018 |
09-04-2016, 06:10 AM | #4 |
Rep 603
Do you have active cruise control?
The one with the distance radar installed under the front bumper? If so, check if the radar surface is clean. I had this in heavy snow fall, that suddenly the cruise control stopped working. But it could also occur if there is a lot of dirt or roadkill bugs on the surface. Otherwise I don't know..
09-04-2016, 10:13 AM | #7 | |
Rep 311
02-23-2018, 02:47 PM | #13 |
Rep 765
Have u done any flashing of modules or recently retorfit anything? I heard of cruise control not working properly when flashed wit older or different psdzdata
02-25-2018, 02:59 AM | #14 |
Rep 1,805
This happened to me.
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
08-08-2018, 12:39 PM | #15 |
Rep 79
When you flash KOMBI ECU, you need also to check dependencies. Like FEM_GW must be also flashed with the same version as you flashed the KOMBI.
I don't know why people doesn't say what they've done first and errors they get after. We are here to help, not to judge you guys. So please, next time, tell everything, like I tried to flashed my KOMBI, everything finished with no errors but cruise control is not working, or I can't set the LIM speed if you also coded the SET button to be LIM. I tried to flash my kombi as I thought that is and I had the same, I flashed FEM_GW and back to normal, everything is working fine for me. So guys, do the same steps as you done the KOMBI for FEM_GW. |
08-09-2018, 04:41 AM | #16 |
Coding ECU's remotely
445
Rep 1,175
I've seen this too where a KOMBI has been flashed to a later i-level than the rest of the car.
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube |
08-09-2018, 09:01 AM | #17 | |
Rep 79
I flashed FEM_GW in less than 2 minutes and everything worked like a sharm. Wherever they got the instructions from, they've been told 100% to check the dependencies |
03-27-2019, 10:25 PM | #18 |
Rep 14
I got the same problem after coding a used cluster and coded to add cruise control
I think the i-level is different because I didn't find the same level when coding BKOMBI so I choose the later one FEM_GW doesn't show any coding options it doesn't have any green CAFD |
10-16-2019, 09:08 AM | #21 |
Rep 119
Hello people,
I suddenly got this error too - didn't flash or code anything - cruise control cannot be set, used to work perfectly... Is there any fix other than a dealer? I have a big trip planned for the weekend. Car is a 2017 330e Thank you! |
