03-15-2019, 08:11 PM | #1 |
Rep 565
Drives: 11 MW E92 M3
Hi all,
I finally retrofitted and got my NBT EVO unit coded to my VIN. Install went fine and the system is awesome. The only disappointing thing so far is that when using the reverse camera or top down view, the car marks 4 corners around the car as if it there is something there when there isn't. Is it normal? The functionality itself works fine and it does not beep until I actually get close to something. I have attached a picture of what I see. PS. During that picture I do have a car on the left top corner and a piece of a car on the bottom left corner, hence why the sensors is catching a bigger area. Thanks |
07-04-2019, 04:23 AM | #3 |
Rep 464
CAFD PDC Sensor settings
Confirm your EVO CAFD file settings for the number of front and rear PDC sensors are set to four sensors:
3001 EXBOX --> PDC_SENSOR_VORN --> 4_sensoren (Werte=01) 3001 EXBOX --> PDC_SENSOR_HINTEN --> 4_sensoren (Werte=01) Larry
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold |
07-07-2019, 01:27 PM | #5 |
Rep 41
So i have new information.
I have the park assist. The 4 sensors in front/back are for the pdc and the additional 2 sensors are for the park assist „flankenschutz“ My current config are: 3001 exbox > communication_parkmaster > gen2 0x02 3001 exbox > macro_pma_einparken > gen2_ohne_konf 0x03 3001 exbox > auto_pdc > aktiv 0x01 3001 exbox > pdc_flankenschutz > aktiv 0x01 3001 exbox > pdc_generation > gen2 0x01 3001 exbox > pdc_sensor_hinten > 4_sensoren 0x01 3001 exbox > pdc_sensor_vorn > 4_sensoren 0x01 So looks my pdc, the beep works, but no sensor lines only the 4 corners... |
07-07-2019, 02:38 PM | #6 | |
Rep 464
3001 exbox > pdc_generation > gen1 0x00
07-08-2019, 03:32 AM | #8 |
Rep 1,976
Drives: 2020 G20 320i M Sport
Do you have option 5DP for Parking Assist? This issue only seems to affect vehicles with that specific option since it has the all around PDC.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
07-08-2019, 05:06 AM | #10 | |
Rep 464
3001 EXBOX MACRO_PDC aktiv 0x01 3001 EXBOX PDC_ABSTAENDE_VERSION alt 0x00 3001 EXBOX PDC_DIRECTION vertikal 0x00 3001 EXBOX PDC_3D nicht_aktiv 0x00 3001 EXBOX ACTIVE_PDC_FLANKENBREMSUNG nicht_aktiv 0x00 3001 EXBOX ACTIVE_PDC_DEFAULT_ON nicht_aktiv 0x00 3001 EXBOX ACTIVE_PDC nicht_aktiv 0x00 3001 EXBOX PDC_DARSTELLUNG_V2 aktiv 0x01 3005 DISPLAY_PIP_CONFIG ZIN_SEMI_PERMANENT_DISPLAYS_PDC_PMA nicht_activ 0x00 3000 HMI CURSORPOSITION_PMA_AUSRICHTUNG laengs 0x00 3000 HMI PMALQ_BEDIENUNG mit_Dauerdruck 0x01 3001 EXBOX MACRO_PMA_AUSPARKEN nicht_aktiv 0x00
07-08-2019, 06:39 AM | #11 |
Rep 41
thank you.
this 2 values i dont' have 3001 EXBOX ACTIVE_PDC_FLANKENBREMSUNG nicht_aktiv 0x00 3001 EXBOX ACTIVE_PDC_DEFAULT_ON nicht_aktiv 0x00 but i try with 3001 exbox > pdc_flankenschutz > nicht_aktiv 0x00 and now i think it looks good, but i dont know how the park assist works without Flankenschutz. do you have the value "pdc_flankenschutz"? |
07-08-2019, 04:20 PM | #12 | |
Rep 464
Regarding "pdc_flankenschutz", yes I do have this parameter set to aktiv 0x01. Since I have responded incrementally on my setting over 2 posts, I will summarize my PDC/PMA related settings below: 3001 exbox > communication_parkmaster > gen2 0x02 3001 exbox > macro_pma_einparken > gen2_ohne_konf 0x03 3001 exbox > auto_pdc > aktiv 0x01 3001 exbox > pdc_flankenschutz > aktiv 0x01 3001 exbox > pdc_generation > gen1 0x00 3001 exbox > pdc_sensor_hinten > 4_sensoren 0x01 3001 exbox > pdc_sensor_vorn > 4_sensoren 0x01 3001 EXBOX MACRO_PDC aktiv 0x01 3001 EXBOX PDC_ABSTAENDE_VERSION alt 0x00 3001 EXBOX PDC_DIRECTION vertikal 0x00 3001 EXBOX PDC_3D nicht_aktiv 0x00 3001 EXBOX ACTIVE_PDC_FLANKENBREMSUNG nicht_aktiv 0x00 3001 EXBOX ACTIVE_PDC_DEFAULT_ON nicht_aktiv 0x00 3001 EXBOX ACTIVE_PDC nicht_aktiv 0x00 3001 EXBOX PDC_DARSTELLUNG_V2 aktiv 0x01 3005 DISPLAY_PIP_CONFIG ZIN_SEMI_PERMANENT_DISPLAYS_PDC_PMA nicht_activ 0x00 3000 HMI CURSORPOSITION_PMA_AUSRICHTUNG laengs 0x00 3000 HMI PMALQ_BEDIENUNG mit_Dauerdruck 0x01 3001 EXBOX MACRO_PMA_AUSPARKEN nicht_aktiv 0x00 If you wish to compare CAFD files, please PM a email address and I will send to you my CAFD file. Larry
07-10-2019, 03:32 PM | #13 |
Rep 565
Hi everyone, I'm not sure why I didn't get notified, but I actually gave up and now it looks like there may be a fix?
@gecko.ch - I know you mentioned that you don't know whether park assist work now. Does it? Can you attach a picture on how the graphics look on the idrive? |
07-11-2019, 03:53 AM | #14 |
Rep 41
hi at all
i have compared all settings from Larry, but no luck. it looks like my Pictures above. i played with the gatewytable setting, standard is table_1, i tried every table but no luck. with table 3-5 the graphic looks better, but the park assist don't work. |
07-12-2019, 11:30 AM | #15 |
Rep 235
I'm speaking on the F30 here as I do not know if it is the same case for the F20, but anyways the PMA module hardware changed between the Pre-LCI and LCI, as well as the PDC setup. In order for to VO coding to work as-is with the newer build date for the EVO, you need to get the newer part # PMA module as well as add two additional PDC type sensors to the rear (total of 6 front and 6 rear). Otherwise, you need to code the following on the EVO in order for it to work with the older PMA module:
MACRO_PMA_EINPARKEN > gen1_ohne_konf PDC_FLANKENSCHUTZ > nicht_aktiv AUTO_PDC > nicht_aktiv COMMUNICATION_PARKMASTER > gen1 |
07-13-2019, 10:40 AM | #16 |
Rep 41
I have a F20 LCI BY 7/2015 with factory fitted park assist. 6 sensors in front/rear. I have replaced my evo id4 unit with a new id6 unit and now i have this pdc issue.
07-14-2019, 12:34 PM | #17 | |
Rep 464
But first, try FDL editing/coding PMA2 with the following change: 3030 PdcHMI --> IDX_DARSTELLUNGS_VARIANTE --> ID5 (0x05) Larry
gecko.ch17.00 |
07-30-2019, 06:01 AM | #18 | |
Rep 41
Sorry for my late Response. i had Problems with my e-sys, meanwhileit runs and coded the pma2 ecu with this 3030 PdcHMI --> IDX_DARSTELLUNGS_VARIANTE --> ID5 (0x05) and seems looks good...but...my Picture took i in my garage and in the back/right corner is a pillar, with my id4 unit it was all red in my pdc grafik and with my id5 not? |
07-31-2019, 07:17 PM | #20 | |
Rep 464
The pic in your previous post did not look right. Pic of my pdc/pma2... Larry
10-06-2019, 04:27 AM | #22 |
Rep 41
