10-01-2019, 11:27 AM | #1 |
Rep 166
BMW F30 Microphone issue
Hi guys,
I was helping a mate out installing a HU_Entrynav business navigation headunit in his car. His car is a 2012 F30 - 316D .. Previously it had no center USB, no navigation, no bluetooth or anything... Combox is not present either. So i did the retrofit for him, did a bit of coding - not much though. Just made the new display work etc... Enhanced bluetooth works - music streaming and calling navigation works perfectly. center usb works too. problem is the microphone doesn't work. Now for the navigation to work properly i had to use an emulator, which means there's a harness between the OEM quadlock and the headunit. i installed the wires for the microphone in pin 22 and 17 on the oem quadlock as i figured all the others wires were going directly into the oem quadlock and signal was passed through the emulator harness into the headunit .. So my question is: what did i do wrong? is it just a matter of coding? i did code a few things on the microphone part after having read through some online forums including this one. coding for the microphone is as below: MICROPHONE_POSITION: wert_01 (Ceiling) MICROPHONE_PARAMETER: wert_01 (not sure what this does) MICROPHONE_NUMBER: wert_1 (single microphone) MICROPHONE_SENSITIVITY: L4_mic REFERENCE_CHANNEL_TEL: aktiv REFERENCE_CHANNEL_TEL_MODE: wert_01 Please help me |
10-03-2019, 11:52 AM | #3 | |
Rep 166
Will try to swap them Any good advice on how to get the wire out of the quad lock ? |
05-14-2020, 02:12 PM | #4 |
Rep 12
Hi , im currently with the same issue on a HU retrofit. how did yours came out? where you able to figure it out ??
Gutxi
05-14-2020, 03:00 PM | #5 | |
Rep 166
05-14-2020, 03:08 PM | #6 | ||||
Rep 12
Nice , I'll let you know how mine comes out
Gutxi
05-17-2020, 02:03 AM | #7 | |||||
Rep 166
Trying to get a voltmeter to test the wire ... everything works except for mic input ... |
05-17-2020, 09:01 AM | #8 | ||||||
Rep 12
Scroll down till' "NBT HU pin out description" I noticed two more microphone inputs.
Gutxi
05-17-2020, 11:33 PM | #9 | |||||||
Rep 166
05-20-2020, 12:12 AM | #10 | |||||||
Rep 166
