BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > m performance electric steering v2 trim fitment
Studio RSR
      11-03-2019, 09:10 PM   #1
fondoo1287
Drives: F36
Anyone here having fitment issues with the m performance electric v2 steering wheel trim?
I'm trying to install the factory carbon fiber trim that came with the wheel and am having fitment issues.
      11-04-2019, 02:07 AM   #2
IK6SPEED
Drives: BMW M3 / AH3
Are all parts for a F3x vehicle?
      11-04-2019, 06:26 AM   #3
fondoo1287
Drives: F36
yes
      11-04-2019, 06:31 AM   #4
1QuikWS6
No 55mph
1QuikWS6's Avatar
1621
Drives: F32 435ix MSport
Are you trying to install the trim from the 1st (2) pics to the wheel in pic #4?
If so, that's your problem. The bottom of your electronic wheel is using the split/double spokes that are usually found on the M series cars - as per the split rear trim cover that you show installed
With that split rear trim you would need to use this split spoke front trim version:
Item 2 in following diagram:
https://www.realoem.com/bmw/enUS/sho...diagId=03_0098
Cover for steering wheel, Carbon M PERFORMANCE 32302345203
IK6SPEED4488.00
      11-04-2019, 06:33 AM   #5
1QuikWS6
No 55mph
1QuikWS6's Avatar
1621
-OR-
another cheaper option to be able to use the solid front trim you show is to buy the solid rear trim for use with paddle shifters - such as the trim that would normally come with a non M car
      11-04-2019, 07:29 AM   #6
fondoo1287
Drives: F36
thank you 1QuikWS6. I've been using the metal split v trim and i wanted the carbon fiber trim to match the interior trims but it just wont fit. i prefer the dry carbon fiber.
I might have to order this one:
https://www.ebay.com/itm/BMW-M-PERFO...L/323944874201
      11-04-2019, 07:31 AM   #7
1QuikWS6
No 55mph
1QuikWS6's Avatar
1621
Yup - that will work
That's what I'm using on my wheel
      11-04-2019, 11:01 AM   #8
IK6SPEED
yes
No you aren't. The trim with the open slit is from the F8x series, not the F3x series, as mentioned above.
