03-04-2021, 04:36 AM | #1 |
Rep 102
340i RWD Adaptive M suspension+ M LCA/TS + Eibach Prokit
Hey guys, last and final question.
I've got the M LCA/TA not installed yet just sitting in my trunk. Im waiting for the eibach springs to come in and give to my mechanic to install everything. I told him to replace the M TS bushings with Oem f30 bushings I've read somewhere that if you do that you don't need spacers? But anyways, can someone lead me in the right direction of what's the best route to take so there is no tire rub or anything. |
03-04-2021, 08:50 AM | #2 |
Rep 3,189
If you replace the M TS with stock bushings then I don't see the reason to have bought the M arms. Just to get -0.3° more camber and a higher chance of rubbing the fender liner? The reason you upgrade is for the bushings.
Looks like this is the same as with the M springs. What are you trying to do/gain? |
03-04-2021, 09:17 AM | #3 | |
Rep 102
So do you suggest me leaving the f80 bushings in and doing spacers? If so would 10mm spacers be sufficient? |
03-04-2021, 02:31 PM | #4 |
Rep 3,189
The spacers would depend on what wheels you are running. If you only wanted the feel it would have been better to replace the bushings in the stock arms.
03-04-2021, 02:37 PM | #5 | |
Rep 102
And well I already have the entire kit so do you recommend going with spacers? |
03-04-2021, 09:21 PM | #6 |
Rep 3,189
