04-08-2020, 11:39 AM | #1 |
Rep 20
2016 340i Crank No Start
Hello all! I have a 2016 340i Msport. JB4 and BMS intake installed. I pulled the spark plugs to check the gap and I did not disconnect the battery. After putting everything back together the car will crank but will not fire. I pulled cyl 1 plug and checked for spark during cranking. I then retraced my steps and checked all electrical connections and grounds. Everything looked good.
I still have no spark. I can smell fuel but the spark plugs are not getting power. I have searched high and low, pulled every single fuse (to check) as I could not find a specific diagram for the fuses other than the one in the trunk. I pulled the JB4 out and the vehicle is on the way to the dealer, So I will let every one know of what the outcome is if anyone has experienced this issue and could not find a resolution. Is there a specific fuse for the ignition coils? Last edited by SlowMsport; 04-09-2020 at 12:18 AM.. |
04-08-2020, 02:17 PM | #2 |
Rep 16,054
It's not necessary to disconnect the battery when changing plugs, so whatever the problem is it's not related to that.
SlowMsport16.00 |
04-08-2020, 02:28 PM | #3 |
Rep 20
04-08-2020, 07:32 PM | #4 |
Car Hypochondriac
335
Rep 901
If you moved the positive tie by the strut tower while the battery was connected you could have shorted something. I would check over all fuses. There's also a small chance your DME could have been damaged, but I'm not confident on that.
04-09-2020, 12:17 AM | #5 | |
Rep 20
Latest update is they are reprogramming the vehicle over night. I will have more info in the morning. I am disappointed I couldn't figure this one out. I will post the solution once it is known. |
04-09-2020, 12:19 AM | #6 |
Rep 20
That was what I was thinking but couldn't confirm. I did remove the coils completely but ensured they were numbered and went back into the original cylinder.
04-09-2020, 04:14 PM | #7 |
Rep 283
Think the camshaft position sensor is near one of the coils towards the front on the B58, is it possible it got disconnected or the multiplug damaged, no spark if that's the case.
Just a thought. |
04-10-2020, 03:44 PM | #8 |
Car Hypochondriac
335
Rep 901
Any update with this? Very curious what the issue is.
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
04-12-2020, 10:45 PM | #9 |
Rep 20
Just got the car back. I have no idea what the resolution was.
The dealer reprogrammed the car over night, put new plugs in it, and still had a crank no start issue. I was then informed by the dealer that it was suspected that diesel was in the gas tank. I got my last fuel receipt and showed them that I did indeed put 93 in it (13.5 gal). At this point, I showed up at the dealer. They showed me the vehicle fired up with brake cleaner. I asked them if we had fuel pressure and we then verified spark. I asked them to put the car back together so we could see if it started, it fired right up. They kept it for a few hours to let it sit and test drive it. I picked it up at the end of the day. I have driven the vehicle through one full tank of gas and have had no issues. The dealer also doesn't know what happened. To their credit, they wanted to know just as badly as I did. The only thing I can assume is reprograming the car fixed it. They did do a ton of diag, even checked compression and did a leak down test. The car passed with flying colors so at least I have brand new plugs and I know my motor is healthy. Sorry I didn't have a definitive answer on this one. I will scan and post the dealer comments in a following post. I still wish I knew what would cause the car to not have spark but have fuel pressure. |
05-11-2020, 11:33 AM | #11 | |
Rep 7,591
Then depends on the dealer and the magnitude of the repair (typically in $). If minor, they probably wont investigate. If major (engine, transmission, etc), BMW will probably be notified and tune can be detected and a means to deny warranty claim. |
05-11-2020, 12:29 PM | #12 | |
Rep 10,249
