BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > CIC/NBT FSC Generator - Windows/Linux/OSX
Studio RSR
      06-21-2019, 12:57 PM   #199
alcetus
Drives: bmw F32
Codes don't work for me
North America NEXT 2019-2
2013.10.24 Build date
Vin K186617
I tried date per vin and got a code but it did not work for me. I would like a Lifetime code if possible please.
When I punch OTDLQMTY7EFQ4AFIAD7Qthese into my nav, it says it is incorrect...
      06-25-2019, 04:46 PM   #200
sonda
Drives: BMW F31
Hello,
I have tried many times to download 1b file and generate fsc code but unsuccessful.
I have locked also my olde 2013 navigation.
Can somebody try to generate for me activation code?
VIN: F822270
Prod. date: 28.2.2013
for Road Map Europe MOVE 2013 and Road Map Europe MOVE 2018-1
Thank you for your help.
      06-27-2019, 12:37 AM   #201
sonda
Drives: BMW F31
Originally Posted by sonda View Post
Hello,
VIN: F822270
I do not need anymore code.
Successfully updated.
      07-02-2019, 08:59 AM   #202
fifthelement89
Drives: BMW E90 320d
How you did it?
I tried it too and it didn't work. Tried 3 codes.
Code was for road map europe next 2019-01
VIN : J560982
Production date - 2014-10-09
Can someone help?
      07-08-2019, 06:39 PM   #203
TexasBruiser
Drives: BMW 750i xDrive
Step-by-Step instruction request
I've downloaded your CIC-FSC Generator successfully. I have also downloaded the 2019-2 North America map of 21.3Gb. My system is a NBT EVO ID4 (2016 750i xDrive). I saw some discussion where people were buying an ESys hardware and doing some coding.
What I am looking for, and may simply have overlooked it, is a step-by-step for doing this from a properly formatted 32Gb USB stick into the glove box USB port.
I'd appreciate a repost of the instructions - or a link to it; or new instructions. Thanks!
      07-11-2019, 03:33 PM   #204
GoldmanZ
Drives: BMW E60
Hi guys,
I downloaded Europe East Premium 2019-2 (USB).
I have tried also many times to download 1b file and generate FSC code but unsuccessful. Tried with 4 USB Sticks.
I tried some code with VIN, no luck.
When I enter my calculated code into my nav, it says it is incorrect...
Can somebody try to generate for me activation lifetime code?
- My car VIN is C656484
- Production date 2011-01-28
- CIC
Generated Lifetime Code: 4Q4SYZPXGAS6OABIAD7Q
Generated Normal Code: TC7NKD2GXWATIABIAA7A
Thank you very much for your help.
      07-11-2019, 04:15 PM   #205
M3NickM3
Drives: E92 M3 2011
Just trying this out, I have just installed a second hand CIC.
My navigation is greyed out, and I am told its cause I need to generate and fsc code to match my vin for the sat nav to work.
Is this just to update maps?
What can I do to activate the navigation system?
      07-15-2019, 08:35 AM   #206
patrofan
Drives: bmw 1 series f20
screwed
Can anyone help me? I tried to use the codes from the generator but nothing worked.
My car vin is: P694301
Car date is: 10/07/2014
MAPS: Europe next 2019-1
I tried the following dates: 201407291230, 201407232114, 201406300629, 201406241307
None of the codes work.
The problem is this: I cant use the navi now in my car. It keeps saying I need the code! I'm massively screwed.. I need the gps for work
      07-17-2019, 11:31 AM   #207
Oreocookies
Drives: BMW 435i
Newbie Help
Hey Guys,
Could someone help me i am trying to get a FSC lifetime code for a NBT EVO ID4 unit im new to the F platform and struggling a little bit.
VIN: K409009
      07-17-2019, 01:19 PM   #208
UnKnOwN
UnKnOwN
UnKnOwN's Avatar
Drives: 2013 F30 BMW 328I N20
hi
links are expired.
Could someone give me new link for windows version?
thank you
      07-18-2019, 06:49 AM   #209
Jagaer
Drives: 2011 E91 328xi 6MT
Links Updated
      07-18-2019, 05:54 PM   #210
smumustang
Drives: 16 BMW M6 Convertible (F13)
Originally Posted by Jagaer View Post
Links Updated
Thanks!
      07-21-2019, 04:03 PM   #211
marcospoffo
marcospoffo's Avatar
Brazil
17
Drives: 320 F30 - 2013
      07-23-2019, 07:14 AM   #212
sonda
Drives: BMW F31
Originally Posted by fifthelement89 View Post
How you did it?
VIN : J560982
Can someone help?
I downloaded fsc code with E-SYS cable and than generate with this fsc code serial code for navigation activation.
      07-24-2019, 12:51 PM   #213
Tiny The Devil
Drives: BMW F10
Hello guys
My bimmer is a f10 from 2015 and all codes that can be found on this thread ar up to 2014 can I please get some help with updating my maps.
      07-27-2019, 05:01 AM   #214
Spitfire555
Drives: E87 N52B30
Great program!
I've some FSC (incl. VIN) for you, just wait for activating PM into this board. Then, I can send them to you.
      08-02-2019, 01:48 PM   #215
bmw5er
Drives: 535 xi
I have a 2016 F10 NBT, tried using the app and when I try to update the nav software it says the FSC code is not correct. I generated the code by date.
      08-03-2019, 12:21 PM   #216
goral17
Poland
Drives: BMW M6
Road Map
Hello "Insumy", can You help me and tell how You sort out problem with update Road Map Evo ? I got same problem with my car now...
Regards, Greg
      08-03-2019, 01:52 PM   #217
lordsixel
Drives: 328i Sedan 2010
Guys if you have Enet for F series cable or Kdcan for mini cooper R and E series, I can give you a hand.
      08-03-2019, 01:53 PM   #218
lordsixel
It never works dude, you need to generate it with E-sys, if you have enet cable I can give you a hand
      08-16-2019, 07:00 PM   #219
Kenny_G
Dilettante
Australia
Drives: F10 520D M Sport; F32 420D M
Aus maps update
Trying to update my other half's F32 but the generate by date is not working
VIN: F782232
Prod date: 2013-25-10
Anyone can help??
TIA
      08-17-2019, 03:38 PM   #220
jp1984
Drives: an E92
Hi friends,
Could anyone help with a code? I have tried at least 20 and seem to be messing it up each time
Last numbers of Vin are K221557
Pro Date is 2014-05-02
Maps are North America Next 2019-2
I have an NBT_G1 Unit.
Any help would be greatly appreciated!
