07-18-2019, 03:55 PM | #1 |
Rep 8
Coding being saved but not working
I have a 2016 F36 (428i Gran Coupe) and purchased cable and image, USING eSYS. I have successfully connected and verified that all 3 versions reported in I-step are same (last, current, shipped).
I did the coding with the car running(engine on). I started with 4 settings and they do not work. When I restart and reconnect and re-pull it says they are aktiv... The 4 settings are for comfort access mirrorunfold/fold and the key fob KOMFORTOEFFNUNG_FB KOMFORTSCHLIESSUNG_FB ASP_AUSKLAPPEN_NACH_KOMFORTSCHLISSEN ASP_BEIKLAPPEN_BEI_KOMFORTSCHLISSEN Help, guidance appreciated. Thanks |
07-18-2019, 04:30 PM | #2 |
A family of bimmers
2747
Rep 7,742
Did you hold the keyfob to lock and then a sec delay the mirrors fold? I just did this exact coding last night and it worked just fine
07-18-2019, 05:22 PM | #3 | |
Rep 10,473
07-18-2019, 05:40 PM | #4 |
Rep 8
07-18-2019, 05:43 PM | #5 | |
Rep 10,473
07-18-2019, 09:58 PM | #7 | |
Rep 1,659
Drives: 2022 WRX World Rally Blue
Could it be as simple as not executing the "CODE FDL" button? I know someone who has done this. I'm not naming names though.
Rick
07-19-2019, 02:55 AM | #8 | |
Rep 2,302
Are they still active? And like Rick4345 already asked, did you hit the button „FDL coding“? |
07-19-2019, 06:34 AM | #9 |
Rep 8
When I read it again it is set to aktiv nd yes hit the code fdl. I have the new psdzdata and will try again today I guess
07-19-2019, 09:03 AM | #10 |
Rep 8
OK Re-coded and it is working, also threw in the unlock on at ignition shutoff but that one does not work (CLM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK) is it a different setting or do you actually have to drive let it autolock and then it works...
Nevermind got back from a drive and it worked. Thanks all, seems like stepping thru all this again and it is all working this time. Last question is there any way to set mode to sport as default? Last edited by psciandra; 07-19-2019 at 11:51 AM.. |
