01-13-2022, 03:30 PM | #881 |
Rep 2,366
Drives: E63 645Ci
You don't, Android doesn't know where or even what the red line is. You make your own graphic, compile your overlay and that's it.
01-14-2022, 09:01 AM | #882 |
Rep 10
Okey but how the pointer knows where ends the red line? If i want to put it at the end of the red line and at the end of the dial, or maybe i cant do that? maybe it can only finish the dial in the actual 6000 rpm
01-14-2022, 10:10 AM | #883 | |
Rep 2,366
Drives: E63 645Ci
It's up to you to draw the red line where you want it. What you need to do however is to keep the current scale i.e. you need to keep the same distance between dividers as it is right now. |
01-28-2022, 05:19 AM | #884 |
Rep 40
How can we change the side bar
Is there any way to change this sidebar we get with the CIC half screen?
Any advice, guide would be greatly appreciated, Thanks! |
01-28-2022, 06:42 AM | #885 | |
Rep 2,366
Drives: E63 645Ci
01-29-2022, 10:12 AM | #886 |
Rep 44
Hello.
On my android unit sd625 andream ,in order to use carplay and android auto has sent me a box to connect to the screen and that works through an apk app. The thing is that I want that apk to open in the phone link tab of the menu, I already read how to do it but I can't do it, I'm not very clear about it. I've searched my drive for the redirects.xml file in /storage/emulated/0/ and can't find it. I have already read the post of kswredirect, and I am not clear, if anyone knows the steps to perform and the commands to write, I put the link of the apk file and could you tell me the steps to follow? https://mega.nz/file/eEAHnQqC#DJSKAm...7UbpXr__fjExuU Greetings and thanks in advance. |
01-31-2022, 03:51 AM | #887 |
Rep 6
Hi guys, I've recently bought an android 10.0 10.25 head unit from Euroactive retrofits and I'm having an issue of media pausing every time I don't open up the Bluetooth media app and if I stay off of the app for too long my media pauses again
01-31-2022, 03:52 AM | #888 |
Rep 6
Also having the issue of being unable to set default apps for my media
01-31-2022, 03:52 AM | #889 |
Rep 40
I had the same issue, then I set the "Aux Switch" from Auto to Manual in the Factory Settings section and it fixed then.
01-31-2022, 04:08 AM | #890 | |
Rep 2,366
Drives: E63 645Ci
Well first of all I doubt this is Android 10, this looks to me like one of these fake units. It might be as well an actual A10, but definitely not a KSW Snapdragon, so there is not a lot info on these. Second, you're having technical issue and that is a theming thread. Usually you cannot change default apps (yay Chinese devs!). You should be able to change your nav app, but other apps are usally predefined and you can only launch your chosen media app from the app drawer. |
01-31-2022, 04:11 AM | #891 |
Rep 2,366
Drives: E63 645Ci
01-31-2022, 04:24 AM | #892 | |
Rep 6
01-31-2022, 04:33 AM | #893 |
Rep 2,366
Drives: E63 645Ci
Your seller has mixed up images of two different units. I would download Device Info app for Play Store and check what API level your device is. API level directly corresponds to Android version. You see Android version number displayed in settings is very easy to change - it's just a text and you could put there iOS 79 or your Granny's birthday. What you cannot change (easily at least) is the API level. So check that first, if it's anything other than API 29 then you have a fake unit and good grounds for your claim.
01-31-2022, 04:44 AM | #894 | |
Rep 6
01-31-2022, 08:17 AM | #895 | |
Rep 40
I recently bought 2 Android 10 devices one for E90 and another one for F10. Before I purchased I personally contacted the seller and asked as much as real pics of the device he can provide and check everything is as I wanted. As a result, I got a legit device for E90 but still, they have scammed me for F10 one. I ordered a 4GB/64GB variant but they have sent an 8GB device instead and I'm really doubtful it and it shows the Android version as v11. On that device, I can't change the default apps, and has very limited options. |
01-31-2022, 10:26 AM | #896 |
Rep 4
Hi All,
I Bought me an android unit ass well... but the experience not good at this moment... The default launcher is unstable and and does not remember my "custom apps". It was sold as "Android 11" But the Api level is 28 so it is Android 9.... Hope you guys can help me out! The first issue I walked into is that my device in not configured as a tablet so I cant download the "Drive Keyboard" for example. I know this has to do with the DPI settings so I thought lets root it... There is my second issue The only way to ADB into this device is over WiFi and then I get: Code:
adb root cxj said not suport, 88 Code:
adb shell su su: not allowed So I am a kind of stuck here... This is the unit i Bought: https://www.aliexpress.com/item/1005003652435744.html My Car is a E61 with a CCC Here are some system specs added as attachment below: RedErik I'm the one who emailed you thanks being help full, lets continue here Thanks Last edited by Dixi83; 01-31-2022 at 11:02 AM.. |
01-31-2022, 10:58 AM | #897 | |
Rep 2,366
Drives: E63 645Ci
Unless you can rewrite your software (part that communicates with the MCU) and make it broadcast button states in a form understandable to Android for all apps to see, then there is nothing you can do to sort it out. |
01-31-2022, 11:43 AM | #898 |
Rep 6
As expected they've sold me a fake unit and it's running android 9 and not 10, any advice on what to do?
01-31-2022, 12:06 PM | #899 | |
Rep 2,366
Drives: E63 645Ci
If however you bought that from Chinese direct then it's a bit more complicated. You can contact your seller and explain all of the above, but from what we've seen so far, they will say that "only Snapdragon units are true Android 10 and this is normal, friend". That leaves you with AliExpress dispute or, again, your banking institution. Last option will guarantee that your AliExpress account gets banned and you won't be able to buy anything on thier platform anymore (which to me is not a penalty at all). |
01-31-2022, 01:48 PM | #900 | |
Rep 6
02-01-2022, 12:14 AM | #901 | |
Rep 4
In the meantime I'm in contact with the seller. He says that he has an update fro the i-drive controller... I think it is an illusion that we get an update to android 11 but he seems to have a good will. (see attachment). But in reality I think we end up sending the device back (it came from France) and buy a device with a Snapdragon CPU. I'll keep you guys posted. |
02-08-2022, 01:28 AM | #902 |
Rep 23
I am interested in the ID7 Launcher by Jellepepe.
1. Anyone have a detailed video of running the interface with the launcher? All I see in this thread is just a bit of the home screenshot or just a few second video. I want to see more of the interface first before deciding to purchase it from the playstore. 2. I only found the ID7 launcher apps when using the playstore from PC. But when I tried to browse it from the HU playstore, it didn't show up from the search result. |
