BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Delete
      11-07-2018, 01:52 AM   #1
Blueeyesredpanda
Blueeyesredpanda's Avatar
Drives: E90 / F30
Delete
Delete
      11-08-2018, 01:37 PM   #2
loggin
Drives: f30
Originally Posted by Blueeyesredpanda View Post
Found a oil leak on this cooler, when I looked into the diagram, it is a transmission oil cooler. According the leaking location, I assume one of the hose is leaking.
Can anymore confirm the part# of this hose or which hose would this be on realoem
I believe that is the transmission oil cooler.. You definitely do not want to be low on transmission fluid.. I would get that checked asap!!
You would need to put in the particulars of your car, ie: year, engine, etc.. and the right part number will be listed.. The following is an example of the part you are referring to: http://www.realoem.com/bmw/enUS/show...diagId=17_0638
