08-05-2018, 06:27 PM | #23 | |
Rep 5,457
Drives: F30
Although- BMW explicitly states to not add any additives whatsoever to engine oil because it may result in engine damage. |
08-05-2018, 06:29 PM | #24 |
Rep 1,615
I had noted in another thread somewhere that I have used dealer 5W30, indy Mobil 0W40 and more recently dealer 0W30 in my car with no issues/leaks whatsoever. Currently standing at a little over 78k miles.
2020 M550i (G30) | Carbon Black/Black Nappa | DHP | DAP | Executive | Luxury Seating | Park Asst | Ceramic Controls | Front/Rear Heated Seats | 20" 668M wheels
2021 X3 (G02) | Dark Graphite Metallic/Cognac | Premium | DAP | Front/Rear Heated Seats Sold/Retired: 2012 328i (F30) |
08-05-2018, 06:31 PM | #25 |
Rep 1,615
If you are changing it out every 7-8k miles (which you seem to be doing), how does LL01 matter? If you are doing 15k miles that's another story.
sspade2464.50 |
08-05-2018, 06:59 PM | #26 | |
Rep 5,088
The new car warranty has since expired, but there is still factory TC ELW, plus PZEV warranty, on my N26. |
08-05-2018, 07:02 PM | #27 | |
Rep 5,088
Is your suggestion to ignore LL01 with 7k to 8k miles OCI? |
08-05-2018, 08:43 PM | #28 | |
Rep 16,075
As for LiquiMoly, I use MolyGen oil and Ceratec additive. Since using those my gas mileage has gone up by 2 MPG in all around driving. |
08-05-2018, 08:56 PM | #29 |
Rep 1,615
I ignored it - other than the dealer, neither of the oils I used have been LL01 yet my car is as good as ever. Since my free maintenance expired at 50k miles, I have been doing 7.5k mile changes. Over the past 30k miles, I have done 4 oil changes of which only one has been at the dealer (LL01).
bavarianride1506.50 |
08-05-2018, 09:29 PM | #30 | |
Rep 5,088
One thought is that starting 5w40 early may prevent some of these leaks from developing. From another angle thugh, BMW is using 0w30, or even 0w20, both of which should benefit timing chain at cold start, right? |
08-05-2018, 10:01 PM | #31 |
Rep 16,075
5W40 won't stop leaks. All that differs in different weights is viscosity at different temperatures. The first number is how easily it flows when cold, the second how thick it remains at high temperatures. Leaks are caused by gaskets and seals that age. The weight of the oil won't affect that. The main reason for BMW, and everyone else, going to lighter weight oils is fuel economy.
08-05-2018, 11:34 PM | #32 | |
Rep 5,088
My warranty booklet does not list 0w20, will BMW 0w20 (LL14FE) still be safe to use on a 2013 N26? |
08-06-2018, 10:10 AM | #33 |
Rep 16,075
It's safe to use any oil that meets BMW requirements, some just work better than others under different conditions. 0W-20, for instance, is a cold weather grade, probably best used only when ambient temperatures are at freezing or below. Back when all you had was mineral oil that you changed every 3-4,000 miles it was common to use a winter oil and a summer oil. With synthetics there's a lot more grade leeway, and if you only change yearly you can use a 5W-30 in most climates.
08-06-2018, 11:07 AM | #34 | |
Rep 5,088
08-06-2018, 12:02 PM | #35 |
Rep 3,439
There's no difference in recommendations for different years' engines. The recommendation itself changed in 2016 with the release of new oils and LL-14 standard. That new recommendation was primarily targeted at the newly introduced B series engines, however, it also applied to _all_ N2x engines regardless of their year of production, though no other N or S engines.
08-06-2018, 12:33 PM | #36 | |
Rep 5,088
1. F3* up to 2016(no B engine) is LL01 Twinpower 5w30 2. N20/B46/B58 2016 and on is LL14FE+ 0w20 3. N26 2016 and on is LL01FE 0w30. The newtis link(updated 7/2016) in your post does say LL14FE+ also works for N20 and N26 alike. |
08-07-2018, 07:33 AM | #37 |
Rep 16,075
The recommendations from suppliers are based on what BMW called for in the manuals for the various models and engines when they were produced. When they make a change it may very well be retroactively applicable to older engines, but suppliers aren't going to make that assumption. For instance, a better formulation of 0W-20 might work just as well as an older formulation of 5W-30 in hot conditions, so BMW may go to it for better mileage. But a supplier won't say that it's OK to use the newer formulation in older engines unless BMW specifically says so, lest they get blamed if you have an engine failure.
08-08-2018, 11:40 AM | #38 |
Rep 5,088
Is non-BMW Mann filter just as good? My mind always has this idea that parts with BMW logo(even from same manufacturer) is better quality than the non-logo one, as Mann sorts its parts so that only those that narrowly fit BMW specs will be stamped with BMW logo. Myth or truth?
08-08-2018, 12:28 PM | #39 | |
Rep 5,457
Drives: F30
So far Ive only used BMW plug and filter but Id be open to saving a few bucks if the MANN was equal quality and spec. Does the MANN unit come with a new drain plug? |
08-08-2018, 12:57 PM | #40 |
Rep 16,075
I've only used Mann, which does include gaskets but not a drain plug. My GT doesn't have a plastic pan, so it doesn't required a new plug with every oil change. I did replace the OEM plug with a magnetic plug.
11-01-2018, 06:14 PM | #41 |
Rep 369
I believe a Mann kit does come with gaskets & a drain plug, ~$15 -
MANN OIL FILTER HU816z KIT for 2wd - has a new plastic plug or MANN OIL FILTER HU816x KIT for x-drive - has a new metal plug At least for F30 N20 328i. |
11-01-2018, 07:01 PM | #42 |
Rep 1,045
nope, I only use 5W-40 with BMW LL-01 approved oil like these:
I used 5W-40 on my E60 for 3 years, my E92 for 5 years, and now my F32, all ran smooth as butter and quiet as a mouse after i put this stuff in. 5W-40 is not too heavy, and actually offers more protection for me. My city never gets below -10°C (14°F), why would I use 5W-30 and waste half of the bottom end range down to -25°C that never occurs, I rather have more oil protection at the high end of 35°C (95ºF) with 5W-40. Only time I would consider a lighter weight oil is high mileage BMWs, the light weight may help the worn engine to work better. For newer, lower mileage engines, heavier weight oil will offer more protection against wear, the OP's shop is correct in advising this. Last edited by Zanity; 11-01-2018 at 08:12 PM.. |
11-01-2018, 08:19 PM | #43 |
Rep 2,197
Fixed that for you!
11-02-2018, 03:10 PM | #44 |
Rep 126
