11-13-2018, 09:59 PM | #1 |
Rep 91
n26 misfires with bootmod3
Hey all,
I've recently been getting rough idle when cold starting and engine misfires when going over 3k rpm. Car has 107k miles. It's a n26 motor. I first installed a JB4 and later an ER catted downpipe with no issues. For about a month I took off the JB4 and the car threw codes for catalyst and o2 sensor which would sometimes clear by themselves. I flashed bootmod3 and cleared codes and the car ran fine without any issues. About another 3 weeks later I started getting misfires (engine jerks) at WOT without any codes. From this point I started getting rough idles when starting the car in the mornings, it's gotten rougher as the days go by. I changed spark plugs, ignition coils, engine oil, and engine air filter. No improvements noticed. Now when I go above 3k rpm a little quickly I get misfires and CEL comes on with the drivetrain malfunction and the car basically goes into limp mode with huge loss of power and really shaky ride. Once I stop and turn off the engine and turn it back on the lights sometimes clear and it's no longer in limp mode or the CEL stays and is no longer in limp mode. These are the codes I see with the BM3 software. Any suggestions? I'm thinking the next thing is to clean the VANOS solenoids. If that doesn't work, then replacing o2 sensors. Not sure where else to go from there. I'm out of warranty so I'd prefer not to take it to BMW |
11-13-2018, 10:14 PM | #2 |
Rep 943
Drives: F30 328i Msport
Nothing to lose by trying to clean the MAF, some ppl had rough idles and after cleaning it was back to normal.
11-14-2018, 07:21 AM | #5 |
Rep 3,679
Cleaning the MAF isn't a bad idea, can't hurt to give that a shot, but it sounds like it's missing or leaning out really bad. Have you tried flashing back to stock to see if the issue persists?
11-14-2018, 03:55 PM | #6 |
Rep 96
First check and replace spark plugs if necessary. Make sure they're gapped properly.
Then I would look into injectors. |
CandyRedRC46242.00 |
11-14-2018, 04:37 PM | #7 |
Rep 91
rjdnyy224 yeah I'm flashed back to stock currently but same issues persist.
take1step I've replaced plugs and coils, but haven't done injectors yet so that's what I'll be doing this weekend. |
11-14-2018, 04:45 PM | #8 |
Rep 3,679
Gotcha, so definitely a mechanical issue. Could be injectors/HPFP too, or something along the fuel path. Interested to see what whoever you take it to for the second opinion says.
09-04-2019, 10:08 AM | #9 |
Rep 91
Late Update: it was fixed with spark plugs gapped properly and using 1 step colder plugs. Engine still shudders every now and then when cold starting and not fully at operational temp but nothing serious. CEL went away after I replaced the upstream O2 sensor for bank 1 sensor 1.
04-26-2020, 01:10 PM | #10 |
Rep 1
I have very similar misfire issues with my car. I am posting this so that the forum admin allows me to start a new thread. I am new to this forum.
04-26-2020, 11:10 PM | #11 |
Rep 384
hope your engine is not damaged
but, here's a story of mine, with blown N20 engine, with similar symptoms with you https://f30.bimmerpost.com/forums/sh...&postcount=737 https://f30.bimmerpost.com/forums/sh...&postcount=751 https://f30.bimmerpost.com/forums/sh...&postcount=777 i sold the car afterward, and now driving a B48 330i FBO with BM3 and no issue |
04-27-2020, 01:31 AM | #12 | ||
Rep 332
Drives: 2014 F32 428I Xdrive (N26)
04-27-2020, 10:56 AM | #13 | |
Rep 190,777
04-28-2020, 01:37 AM | #14 | ||
Rep 332
04-28-2020, 09:28 AM | #15 |
Rep 384
04-28-2020, 10:04 AM | #16 |
Rep 190,777
I recommend upgrading the charge pipe when car is tuned no matter what stage you run
04-28-2020, 09:53 PM | #17 |
Rep 332
Thanks for the info!
04-29-2020, 08:02 AM | #18 |
Rep 414
I’ve heard no reports of anyone blowing either charge pipe on an N20/26 whether stock, stage 1 or stage 2. Some of the fastest N20s on the quarter mile thread are running stock pipes.
05-02-2020, 04:06 PM | #19 |
Rep 332
Good
