01-18-2020, 04:16 AM | #1 |
Rep 2,053
Do I need to code my new seats?
Hello,
I purchased a new driver's seat for my F30, since it came with race seats. The donor car was a 2017 and my car is a 2013. Errors after plugging in the seat: Bolster adjustment is not working TPM light turns on Climate control stops working (has a delay) The rear view camera stops working Is this because of the newer module/seat? Has anyone swapped seats and coded them? Thanks
01-18-2020, 09:50 AM | #2 | |
Rep 10,473
As the KCAN run the length of the car, if this happened out of the blue, you could be looking at 10 hours of diagnostic time to track down the issue. As your car was operating normally prior, it's clearly an issue from the connections into the seats, which narrows it down. Obviously it's wired incorrectly or the module under the seat(s) is bad. |
01-18-2020, 01:07 PM | #3 | ||
Rep 2,053
I am just trying to see if anyone here swapped seats and everything worked fine. The seats came out of a LCI vehicle, and my car is non-LCI don't know if that matters though.
01-18-2020, 02:55 PM | #4 | |||
Rep 10,473
In my instance, the ECU under the driver seat in the LCI replacement was bad and shorting the KCAN to ground. Unfortunately I had also replaced the side mirrors at the same time (which are on the KCAN circuit) and another device so pointing to the seats wasn't as straight forward in my instance as the error code was a short on the circuit which runs the length of the car. Common sense would have been a bad wire shorting to ground, not a bad ECU shorting to ground. You do not list your error codes so that will be your starting point. |
01-19-2020, 12:57 AM | #5 | |
Rep 2,053
I am going to plug-in the seat tomorrow, hopefully I can find out the codes. That way I can list it on here. Thank you for the help
01-31-2020, 11:58 PM | #6 | ||
Rep 558
2017 F80 ZCP - Mineral Grey Metallic
02-02-2020, 10:14 AM | #7 |
Rep 69
Does anyone know if we have any sort of interchange matrix for seats and interior.
I just pass 200K mi last week and I'd like to swap in a newer/nicer interior. Before I start looking, it would be good to understand not only what will fit physically as well as what can be properly connected/coded for proper operation. I poked around a few of the other 'seat' threads but they all seem to be specific to each persons vehicle and seat combo.
Mods: Stoptech Sport Brakes, Injen Intake, BMS Catch Can, AFE Downpipe & 328i Sport Exhaust, Evolution Raceworks Chargepipes, VRSF intercooler, AFE tBody Spacer, MHI Big Turbo, BM3 Stage 2 93 Octane tune, Bilstein B8 Sport+ dampers, Dinan Perf Spring Set & Camber Plates
02-09-2020, 12:35 PM | #8 |
Rep 2,053
Forgot to mention earlier in the post, that I sold the original drivers side seat and replaced it with a race seat.
I found out the modules were actually completely different part numbers. Luckily I was able to find a module that matched my passenger side. Now everything is functioning in the car including heating option, bolster adjustment and so on. The only issue I have no is the "drivers restraint malfunction." I will check the codes today and post it, maybe someone has a solution to this. I tried resetting it, but it doesn't do anything.
02-10-2020, 07:05 AM | #9 | |
Rep 48
02-10-2020, 11:31 AM | #10 | ||
Rep 2,053
Here are the error codes: SMFA Seat Module, Driver: 802A00 SMFA: no current coding data stored 802A03 SMFA: control unit is not encoded for the vehicle 802A08 Personal profile porting restricted due to lack of calibration Airbag-ACSM Crash Safety Module: 930978 Driver's side airbag: Coding data do not match equipment
02-10-2020, 03:49 PM | #11 | |
Rep 464
The ACSM error may disappear once the SM errors are fix but you may have to run an ISTA utility to let the ACSM learn about the new SM module. Larry
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold |
02-12-2020, 12:04 AM | #12 | |
Rep 2,053
I was working with user @david51. He was able to figure out the solution by injecting the new CAFD file to the module. Everything works perfect now. Thanks everyone for helping me out with this issue, especially @david51. |
