BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Stock Supra Keeping up with 440i Stage 2
      10-05-2019, 01:55 PM   #1
IMS-340C
IMS-340C's Avatar
Egypt
395
Drives: Self Tuned 340i 8AT RWD
Red face Stock Supra Keeping up with 440i Stage 2
Stock Supra keeping up with decatted Boot Mod3 Stage 2 aggressive mode 440i!!
How is that possible anybody seen that video of Vehicle Virgins ?
Jump to 6 minutes in the video for the runs.
      10-05-2019, 02:43 PM   #2
SRHosein
Trinidad_and_tobago
194
Drives: BMW 330e M-sport
Power to weight ratio (about 300lbs difference). Plus fuel system and other components are upgraded on supra.
      10-05-2019, 02:58 PM   #3
IMS-340C
IMS-340C's Avatar
Egypt
395
Stock Supra traps 108-110 mph in the 1/4 mile, my 340i MPPSK traps the same on 88 octane.
Decatted Boot Mod3 Stage 2 440i should trap close to 120 mph.
It shouldn't even be close.
      10-05-2019, 04:23 PM   #4
TreDirtyFive
Drives: X3 M40i
Isn’t the minimum octane on all Bxx applications 91 octane/95 ron?
      10-05-2019, 04:56 PM   #5
lens
lens's Avatar
2070
Drives: 2018 340i xDrive
errr that's a bit high for a stage 2 440i
They trap around 110-112mph on 91, 112-114mph on 93, and 115-117mph on E30.
a stock supra traps about 112-113mph in the 1/4 mile, so I can see why it kept up with the 440i, it's also lighter than the 440i.
      10-05-2019, 08:54 PM   #6
B58togo
Drives: M240i
I trapped 118-119 on E30 Stage 2 in average conditions. I’d guess the slightly heavier 440 on 93 would be a couple mph slower.
      10-05-2019, 10:09 PM   #7
lens
lens's Avatar
2070
M240i does not have the same DME and such as a normal 340/440i does, they make more power from the factory stock, and tuned they make more power which is why they always have been able to run much faster times that the 340/440i.
It's was the same thing with the M235i and 335i/435i.
If the guy in the video had a M240i instead of the 440i, he would have probably put a good 2 cars lengths or more.
ronanz1819.50
      10-05-2019, 10:19 PM   #8
B58togo
Drives: M240i
They might make an advertised 15 hp and 39 ft lbs more in stock form due to slightly higher boost tweaks from the factory, but they're identical engines and they share the same tunes across the platform. A tuned M240i makes no more power than a tuned 340/440. The only advantage the 2 Series has is a negligible weight advantage.
kern4174446.50
      10-05-2019, 11:04 PM   #9
lens
lens's Avatar
2070
Not true really, it takes a bit more to get the 340/440i into 11s, and m240i gets there with no effort at all.
      10-06-2019, 02:01 AM   #10
kriszty
kriszty's Avatar
329
Drives: B58 M240ix pureturbo800 dorch1
true
      10-06-2019, 06:04 AM   #11
IMS-340C
IMS-340C's Avatar
Egypt
395
Here's a stock Supra trapping 108 mph vs a tuned Supra.
Also the weight difference is only 150 lbs vs 440i.
      10-06-2019, 09:47 AM   #12
enemigo13
Drives: F32 LCI 440xi citrineblack
i trap 186.5km/h (116mph) with 340xi tune only (stock DP). fuel is 98 (93 us)
IMS-340C394.50
eluded3030.50
      10-06-2019, 10:05 AM   #13
B58togo
Drives: M240i
That's what you're basing it on? Not particularly scientific. The 240 gets into the 11's with no effort at all? Umm, ok. I could not get under 12.00 at one track the week before I broke into the 11's at a different track. On the other hand, there were 340i's running 12.00 back in 2017 with just an AA piggyback and catless DP.
Regardless, reach out to any of the tuners at PTF, MHD, Mission etc and they'll all tell you they share the same DME and end results are the same.
kern4174446.50
      10-06-2019, 11:01 AM   #14
IMS-340C
IMS-340C's Avatar
Egypt
395
That's a strong trap speed also considering it's xdrive.
Which tuner did you go for ?
      10-06-2019, 11:07 AM   #15
lens
lens's Avatar
2070
I will legit bet money, that if you put a 340i and a M240i with the same tune and mods next to each other, the m240i will pull away easily.
I've seen it happen and I know the m240i is faster than the 4 door counterparts tuned, same mods and fuel.
I can't explain why, I'm going to assume the transmission has no tq limiter compared to the 340/440i or something but the m235i/m240i has always made more power and ran faster 1/4 mile times than their counterparts.
Its kind of like the M135i and m140i.
      10-06-2019, 11:23 AM   #16
enemigo13
tuned myself. no dyno, but probably ~420 crank hp
IMS-340C394.50
      10-06-2019, 11:47 AM   #17
lens
lens's Avatar
2070
Realistically you'd want the temps to be in the 20s and DA between 1000-2000 to simulate real drag strip conditions.
Colder temps and negative DA is basically cheating
      10-06-2019, 12:08 PM   #18
enemigo13
I have another one with 18deg C, about DA : not every drag strip is high above sea level.
      10-06-2019, 01:13 PM   #19
lens
lens's Avatar
2070
Most of them are though, so I usually use it as a standard that if you can put down a good time at that high of a DA, then you can put that time down anywhere.
For example, the nearest drag strip is about 2 hours from me and has a DA of between 1300-1800.
Where I live, the DA is between 600-1600 depending on temperature and humidity, and about 0 to -1000 in the autumn/winter, I run about 0.2-0.3 seconds faster and trap 2mph higher in the negative DA then I do in the summer.
Of course I only have 91 octane available to me.
      10-06-2019, 11:46 PM   #20
enemigo13
I see you’re running PS2 F30 xdrive, what’s your 100-200 time?
      10-07-2019, 12:26 AM   #21
lens
lens's Avatar
2070
10 seconds flat
      10-07-2019, 12:40 AM   #22
enemigo13
10 seconds flat
slope, temperature, DA?
