12-21-2018, 04:12 AM | #23 |
Rep 1,846
Seems normal, a 20 mins drive around 15 miles sees mine full warmed - mind you thats motorway.
Its oil temp too not coolant by typically they warm up at about the same time. |
12-21-2018, 04:47 AM | #24 | |
Rep 13,043
Drives: BMW M340I G20
My 435d never reach full oil temp in the winter unless I did 40 odd miles. It made no difference to the heating though
Current car.M240i. Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci. |
12-21-2018, 04:51 AM | #25 |
Rep 724
12-21-2018, 05:28 AM | #26 | |
Rep 3,967
On my car once the oil temp has reached 100c on the gauge the coolant temp is usually averaging just above 100c too on the hidden menu. I believe coolant temp needs to be above 75c for the DPF to regenerate. |
12-21-2018, 07:08 AM | #27 | |
Rep 15,858
I'm surprised some of you diesel guys are seeing 100C + for the coolant, (ECT) in normal running. That is a fully open thermostat (BMW data) giving full radiator cooling. That's similar to typical ECT regeneration temperatures. Very surprising in winter time, (suppose it depends on what we call winter temperatures), many will find they barely run ~90C ECT, the bottom end range of an opening thermostat, which is calibrated to 87C/88C opening temperature. |
12-21-2018, 07:17 AM | #28 | |
Rep 15,858
If it is similar to the 5-series, you can view raw, oil and coolant temperatures on the same sub menu. Makes it easy to see the way oil temperature lags behind coolant, and in what situations they level out for normal running. As Watsey has said, you can also view/detect the exact temperature where the thermostat cracks open and the coolant circuit is introduced to cooling the engine block. |
12-21-2018, 08:55 AM | #29 | |
Rep 724
Excuse my ignorance or stupidity in most cases, whats this hidden area. I don't need a code to unlock, it just connects but If i press unlock it just says that i have already paid, is there any area to put in this code of your last four vin numbers added together ?? |
12-21-2018, 09:40 AM | #30 |
Rep 15,858
I'm simply talking of the car's built in hidden menu, opens in the dash display. Assessible from within the car, (no tools or software) using the odometer button and the VIN numbers 'unlock' code.
12-21-2018, 09:51 AM | #32 |
Rep 724
I've got to say never heard about this, you live and learn, so what is it you have to press ?
12-21-2018, 10:05 AM | #34 | |
Rep 15,858
I ran a oil/ECT temperature check this morning on my 535i, the procedure I follow… Hold odometer button down, while doing so press start button (no foot on brake), get initial wake up, ignition on only. Keep holding the odometer button down until the menu shows. Cycle to the unlock command. Press and hold until you get the code line. Then for me press 11 times (my code is 11), then press and hold until the hidden menu list appears. Cycle down until the temperature command shows. Press and hold until temperature window/display shows. Ready to start and get some real time readings. There are YouTube vid's showing the procedure. |
12-21-2018, 10:07 AM | #35 |
Rep 15,858
12-21-2018, 01:07 PM | #36 |
Rep 724
For any others with an F36, mine was the last 5 numbers, (37 thats a lot of pushing) and it was option 11 Temperature.
Many thanks for your help HighlandPete and Chelsea_Tractor |
12-21-2018, 02:04 PM | #37 | |
Rep 3,967
05-01-2021, 10:38 AM | #38 |
Rep 2
BMW 430xD coupe - 20 min for oil to reach operating temp
Hi All,
I have a coupe 430xD model from 2018, 3.0L 190kW Diesel engine. Since covid, I haven't been driving the car much, around ~10.000km in the past 12 months or so. I noticed lately is that it takes really long time for the temperature gauge to come to a normal operating position. Thanks to all of the posts here, I did some investigation in the matter and here is the summary: Driving condition: 1. outside temperature 14-15 degrees Celsius (not that cold) 2. driving in comfort mode with auto start/stop switched off 3. driving in the city, average speed ~42km/h and top speed up to 80km/h 4. no hard acceleration 5. summer sport tires Michelin 225/40r19 front and 255/35r19 rear Results: (see the attached table for details)
Car is under warranty still and BMW service staff member is assuring me that this is quite normal behavior. What is your experience with 3.0L diesel engines? Appreciate your feedback. Last edited by xrefa; 05-01-2021 at 10:41 AM.. Reason: grammar |
05-01-2021, 12:04 PM | #40 |
Rep 461
"Letting an engine idle actually does more damage to the engine than starting and stopping. Running an engine at idle causes twice the wear on internal parts compared to driving at highway speeds. Idling will increase maintenance cost and shorten the life of the engine."
cramsnik393.00 |
05-01-2021, 01:44 PM | #41 |
Rep 15,858
Besides the wear issues, a cold and idling diesel is generating lots of wet carbon matter. Not good news long term. Plus it is slower warming up than putting it to work immediately.
05-02-2021, 12:25 AM | #42 | |
Rep 452
Besides, it’s not doing a great deal for the environment is it, Greta wouldn’t be happy. |
05-02-2021, 06:37 AM | #43 | |
Enthusiast
47
Rep 98
Also, If your coolant temperature is staying at 90c+ once fully warmed up and not dropping back down when the engines on low load the thermostat is fine. |
xrefa0.00 |
05-07-2021, 06:22 AM | #44 |
Rep 2
anyone with 430d or 430xd to share their millage and temperature
My thought is that different models probably do have different cooling system implementation, position of radiators etc.
Anyone with 430d or 430xd to share their millage and time for the temperature to reach operating levels? |
