01-15-2021, 01:23 PM | #2509 | |
Rep 5
01-15-2021, 01:25 PM | #2510 | |
Rep 5
01-15-2021, 02:13 PM | #2511 |
Rep 3
Hi guys,
Can anyone help me with the configuration of my headunit? I have a snapdragon 625 with android 10, and i wish to autostart some apps when my head units starts, but kws software manage all headunit. thank you for reading. |
01-16-2021, 12:20 AM | #2512 |
Rep 550
Tasker / Automate / MacroDroid are APPS that will allow you to launch programs or settings tasks right after you start your Android unit
01-16-2021, 01:23 AM | #2513 | |
Rep 3
i already tried macrodroid, automate but seems like kws app dont let macrodroid or automate work when i need. can you let me if i need a special configuracion of these apps or if i need special configuration in the headunit? i usually use these apps on my phone and in others headunit without problems. Thank you. |
01-16-2021, 03:19 AM | #2514 |
Rep 550
Maybe you need to ROOT your unit for it to work, at least with TASKER (which I use) it does. In the first age of this thread, you have the method to ROOT your unit, then try to grant privileges for your chosen application, and restart the task.
01-16-2021, 03:56 AM | #2515 |
Rep 550
01-17-2021, 05:07 AM | #2517 | |
Rep 2
can you help with an activation cod rod something ? |
01-17-2021, 06:15 AM | #2518 | |
Rep 1,048
Kri |
01-17-2021, 09:19 AM | #2519 |
Rep 23
Hi again guys, I return with some more question
Anyone here using spotify in the HU too? Is there any way to make it run as a phone? In my old ford fiesta, the android HU is registered as a phone, that way the spotify can work in phone mode, with the visual short video clip played, and it can even integrate in the Google Maps and Waze interface (showing the title and next prev button in the maps interface) But in this F30 HU I guess the HU is registered as a tablet, that way the spotify interface is very basic, just showing the playlist and small "currently playing song" in the bottom left. And in the Gmaps and waze there is also nothing shown |
LittleSamurai4.50 |
01-17-2021, 12:55 PM | #2520 |
Rep 11
I upgrade latest Firmware version 2.6.3 but I cannot locate any "ID7_ALS" or "PEMP_ID7_UI" GUI. Any advice please?
LittleSamurai4.50 |
01-17-2021, 11:44 PM | #2521 | |
Rep 143
At a minimum, 2.6.1 and that factory file are needed for the UI you want to show up in the factory settings list, afaik. |
01-18-2021, 10:31 AM | #2522 |
Rep 53
hi guys
i know the sound quality isn't the best through these units especially if you have harm/kard so i was looking through bimmercode for aux coding and found these , has anyone tried switching some of them off apart from the AUX_HU of course ? |
LittleSamurai4.50 |
01-18-2021, 11:47 AM | #2523 |
Rep 22
Alexa Amazon in to Android 10 HU SD625
Hi guys, congratulations for the excellent, interesting and useful post for managing android in our BMW. As the title suggests, I wanted to install the Alexa App on my Android 10 updated to the latest version by following your guides, Alexa installs itself but when you start it it blocks saying that it is impossible to continue with the installation. This was also done in the original configuration upon purchase.
Anyone can give me some explanation I need to make some changes to the factory file? Thanks Pino |
01-18-2021, 03:20 PM | #2524 |
Rep 2
01-19-2021, 05:09 AM | #2525 | |
Rep 45
01-19-2021, 08:34 AM | #2526 |
Rep 1,048
new Hardware coming
It seems new Headunit Hardware did appear faster than thought.
For serval Mercedes and BMW cars there are now new Headunits available, spec so far known are:
In Terms of raw performance the new CPU seems to be around +30 ~ +100% faster than the Snapdragon 625 CPU. However as the SD625 CPU with 4GB ram does have not real performance issue at the moment its not sure yet what benefit that new hardware will have at all. On this upgrade the more important factor is the Software. The shops are still using images from Snapdragon 625 Headunits, so its also not known which Android Image is installed. As MTK processors are in general not used that much it likely may be that lots of the modification tools wont work. As of now there is also no BMW/MB MTK headunit known tha has been rooted successfully . So if someone already got such a new Hardware it would be cool if we could do some remote analyzing (Laptop+ Internet required) to see what that headunits are performing and what software is installed. I`ll update this post when new information is available. Kri |
01-19-2021, 08:35 AM | #2527 | |
Rep 39
to be set to US English |
01-19-2021, 09:02 AM | #2528 |
Rep 10
Finally got around to finishing my Avin install in my E82, however seems few steps forward, one step back. This what I have connected:
- Android Auto Dongle (working fine) - DAB+ (got it to work) - Rear parking camera (working when in reverse and at the moment without additional power) - Front DVR I have one USB dedicated to the Android Auto and the other using an aftermarket hub to connect the DAB+, its antennae and the front DVR. However with both DVR and DAB plugged in, neither will work. I've tried a different USB hub to no effect. Any ideas of how to get these all working harmoniously together or is this simply the limitation of this device i.e. can only have two full powered dongles attached at a time |
01-19-2021, 10:25 AM | #2530 |
Rep 22
