04-24-2020, 09:56 AM | #353 |
Rep 30
04-24-2020, 01:31 PM | #354 |
Rep 50
Hi all. Can someone please put some basic instructions on to help me upgrade my unit from A9 to A10 please. I don't understand the ones at the head of the thread....there are a few different files on mega.nz where it says 'first_for_upgrade' with Ksw-P and Ksw-Q in the name.
Thanks in advance ...also it says about not upgrading package in the future.... Very confusing Last edited by adrian.k; 04-24-2020 at 01:42 PM.. Reason: Missed a bit out |
04-24-2020, 02:15 PM | #355 | |
Rep 86
after this is done you can update to the latest version which is 1.4.7 atm. (If you use tasker i would recommend going and staying at 1.3.0 for now, some people reported some issues with 1.4.5 with tasker). You cant downgrade to 9.0 anymore when u are at 10.0. Tbh. If your system is running fine right now, i wouldnt upgrade at all. In the whole update game (I've done pretty much every update since Android 9 2.3.8, the only big new feature was Steering Wheel system wide integration in 3.8.0 for me ) |
04-24-2020, 03:08 PM | #356 |
Rep 50
Thanks mate..mines not been right.... wouldn't open up into android... persisted to open up OEM even though settings selected to open android up at start. Speedo won't change to imperial...even though selected. I've rooted it previously added stuff and it's slow now so I just want to reset the lot... but might as well do the upgrade. Just wish the Bluetooth was better as apparently it will only connect to my phone and no other devices
04-24-2020, 03:20 PM | #357 | |
Rep 86
Its like that for all of us, doesnt matter which version you on. That speedometer isnt working could be a configuration error. You sure you selected the right CAN option? Otherwise i would really try to reset all settings first and do a clean setup. |
04-24-2020, 03:32 PM | #358 | |
Rep 50
04-24-2020, 03:59 PM | #359 |
Rep 1,048
A small appetizer for what is soon possible thanks to the awsome work of nicholaschum
This is still betatesting, please be patiend, it will be release when software and documentation is done as much as possible to minimize questions. Kri |
04-24-2020, 08:04 PM | #361 |
fishman
Rep 3
SIM Card in USA
I am going to install my new Navifly system tomorrow. I was curious if anyone uses a SIM card in their units? If you do what is the best value for a carrier. I appreciate your time and responses. I look forward to working through the install tomorrow. Hopefully, not too many issues.
Scfishman |
04-25-2020, 05:15 AM | #362 |
Rep 40
Wow looks really nice, can’t wait to install it. Good job guys
04-25-2020, 07:45 AM | #363 | |
Rep 9
04-25-2020, 02:18 PM | #365 |
Rep 1,048
If you want to gather pictures of your very specific Car there a two possibilities.
04-26-2020, 01:05 AM | #367 | |
Rep 1,048
In meanwhile you can already Download the KswPLauncher Package here and and try to edit the files as you like. The files you are looking for are found under "/resources/res/drawable-mdpi-v4" for 1280 resolution, and "/resources/res/drawable-hdpi-v4" for 1920 resolution. To edit them you need some software that supports Alpha-Channel (Transparency), lik e Adobe Photoshop, Corel Paint or GIMP. Microsoft Paint does not support Alpha-channel ! So try editing the files while waiting for the release does save you some time Kri Last edited by Kri; 04-26-2020 at 04:04 AM.. |
vigorio12.00 |
04-26-2020, 10:13 AM | #368 |
fishman
Rep 3
04-26-2020, 02:29 PM | #369 |
Rep 2,366
Drives: E63 645Ci
Kri posted a tutorial how to get images specific to our cars, but not all of us are lucky enough to have their cars supported through the Connected Drive app. To those with older E series cars I can share BMW's Accessories Configurator CD that was distributed in early 2000's. It's not 360 image of each car, but there are decent angles to choose from. Let me know if this would be of any interest to you guys.
This is my custom boot animation created using picture of my car from Accessories Configurator. |
04-26-2020, 03:55 PM | #370 |
Rep 2,366
Drives: E63 645Ci
BMW Accessories Configurator for all cars from 2000-2010 era
https://mega.nz/folder/SMBxjYqa#UN-zJavqT85U4dqK6iPaQg Last edited by RedErik; 05-11-2020 at 04:28 PM.. |
04-26-2020, 04:13 PM | #371 | |
Rep 143
Download your car's images with JDownloader
Code:
https://connecteddrive.bmwusa.com/api/vehicle/image/v1/ENTERYOURVIN?startAngle=10&stepAngle=10&width=1280
You will then get 36 separate cosySec.png files. (If you get only one, you missed the step to rename them during download) It may seem like it will end up taking just as much time as copying each of the 36 links and downloading them individually if you don't already use JDownloader, which could be the case. For me, however, JDownloader always saves me time. If you do it right, you should end up with a folder that looks something like this: Good luck! |
Kri1083.50 |
04-27-2020, 01:24 AM | #372 |
Android Developer
47
Rep 14
KswOverlay
KswOverlay
Hi all, I know a lot of you have been waiting for this announcement. KswOverlay is an automated compiler that aids you in creating "overlays" for your device. To explain what an overlay is, it is an APK file that gets read when a core app calls resources. For example, when an app wants to read an icon that is stored within the app, it reads this overlay APK first, before falling back to the resources in the base APK file. Wow, that was a mouthful, most people probably don't understand. That's okay, just need to remember a few things: - This does not need active root, only one call required to move an APK to system/app - This does not replace the launcher APK signed by TeamKsw - This method does not get outdated when the system is updated. - This does not rely on Magisk or Xposed - You can change any text and any picture. Remember, our Discord is open to everyone! https://discordapp.com/invite/Cfphs4S Alright, where do I start?
Automated script: https://f30.bimmerpost.com/forums/sh...45&postcount=8 NOTE: If this doesn't work, then the manual instructions are below for a more technical install. Then follow these instructions: (Initial setup)
You have thus completed initial setup. This will be the only time root will be invoked. Further updates to this overlay can be done in a File Explorer from now on. You will have to repeat the above when you flash a new update. You can always disable the overlay using this code: Code:
adb connect IP:port adb shell cmd overlay disable ksw.overlay Let's start theming: For those of you who'd like to customize your own theme, follow the steps below. If not and you have a prebuilt theme by one of our testers, just update the existing APK in the file browser. I've also made a video for those who would prefer to follow a visual guide for theming.
ATTENTION:
For your reference: 1024x600 (sw600-mdpi) devices uses drawable-sw600-mdpi-v4 1280x480 (mdpi) devices uses drawable-mdpi-v4, mipmap-mdpi-v4 1920x720 (hdpi) devices uses drawable-mdpi-v4, drawable-hdpi-v4 (default), mipmap-mdpi-v4 and mipmap-hdpi-v4 (default) I'd like to thank Kri for being my tester, and being the first designer other than myself using this system. We have also compiled a bunch of resources in different repositories for your references. Kri has added GIMP-ready templates for you all BMW owners to make your lives easier. You can find these templates in the KswTheme repository listed below. KswOverlay: https://github.com/KswCarProject/KswOverlay KswTheme: https://github.com/KswCarProject/KswTheme KswStrings: https://github.com/KswCarProject/KswStrings KswPLauncher: https://github.com/KswCarProject/KswPLauncher Please note, I have created a signing key for you guys so everyone will have the same signing key. This means that kswoverlay.apk is shareable for those who would like to share their themes to other members on the forum. Good luck, and have fun! Tag me on your next creation! Last edited by nicholaschum; 06-06-2020 at 12:09 AM.. |
04-27-2020, 01:29 AM | #373 |
Rep 1,048
This guide is for Changing GUI for Snapdragon Units with Android 10 Systems, Android 9 Systems should also work as they have the same naming shema.
Other Android 8.1 an 9 PX Units are untested yet, so you maybe need to check if the naming shema is the same before changing the pictures. EDIT: PX6 Unit`S do have a different Folder structure, so unfortunateley the Templates do only work for Snapdragon Units ! How to handle the ID6_1280.xcf Template from gimp which can be found here. How to handle ID6_GS GUI There is no High Resolution version for this GUI Kri Last edited by Kri; 06-08-2020 at 02:24 AM.. |
04-27-2020, 02:11 AM | #374 |
Rep 1
PDC stays active
Hi,
installed my 10.25" Android 10 device at the weekend and faced an issue with the pdc as it doesn't switch off when shifting out of reverse. Any idea what my cause this? Thanks. |
