01-08-2021, 06:49 PM | #1 |
Rep 6
hoping to not have EDC
Hey guys, just joined this forum and loved it. I was looking around for kw suspensions for the upgrade and not sure if I got the EDC system or not (hopefully not). I do get the code S2VF saying the Adaptive M chassis. I've read through few threads saying that if you get the S2VF code, you have the EDC, which is qutie confusing. I have attached a pic of my front strut, and hope someone can clearify this.
01-08-2021, 07:47 PM | #2 |
Rep 3,539
You have EDC your pic is showing the front sensor. On the other side of the strut there should be a protrusion coming off of the strut with another cable going to it (that's the solenoid valve).
01-08-2021, 08:28 PM | #3 |
Rep 10,256
It is very likely that your vehicle has Adaptive M suspension, or EDC (Electronic Damper Control) shocks.
Another verification alternative: does the suspension get stiffer when selecting Sport mode? What's the primary reason for replacing OEM suspension? What specific suspension behavior do you want to gain? |
01-08-2021, 10:45 PM | #4 |
Rep 6
Yeah, I did check the other side, and there is a protrusion conencting to the struct. So sad, I think I'll get the EDC blocker then.
01-08-2021, 10:51 PM | #5 | |
Rep 6
I just want a more comfortable rebound and more stable when driving corners. |
01-09-2021, 03:31 AM | #6 | ||
Rep 10,256
01-09-2021, 08:29 PM | #7 | |||
Rep 6
01-10-2021, 01:42 AM | #8 |
Rep 10,256
Congratulations. KW V3 coilovers provide independent compression and rebound controls - one of the best features. The lowering range is a bit low for my preferences but could be perfect for you.
Highly recommend 4 wheel alignment after installation. |
01-10-2021, 05:19 PM | #9 |
Rep 6
Cheers m8. Thank you for your advice.
01-11-2021, 05:19 PM | #10 |
Rep 1,934
Someone on the forums was able to code out EDC and forgo spending extra on a cancellation kit. I believe it's possible using BimmerCode and the like.
