01-18-2021, 01:22 AM | #1 |
bt5000
Rep 45
Light weight 18 inch wheels
I would like some recommendations on lighter weight 18 inch wheels to replace my F30.
F: 18x9 ET30/31 R: 18x9.5 ET43/45 What is the lightest Front: 18x9" ET30/31 Rear: 18x9.5" ET43/45 wheels? Last edited by me06305; 01-26-2021 at 08:24 AM.. Reason: typo erro |
01-18-2021, 01:58 AM | #2 |
David
786
Rep 2,010
Apex, Rays
01-18-2021, 01:25 PM | #4 |
Rep 1,079
02-06-2021, 03:13 AM | #8 |
Rep 341
Curious, why does everyone always go for a lighter wheel and tire combination? Seriously, just a thought? My logic being, does it really make your car 0.01 second faster, those extra 3lbs per wheel? Can it really be that noticeable? Since you are effectively adding weight and distributing it equally on all 4 corners of your car. Does it really make your car feel any different? Because, unless you are adding the equivalent of an extra person, not evenly distributed equally, how much difference can it actually make? Again, for the trolls...Just a question...I have no desire to be flamed or banned on this forum.
02-06-2021, 04:09 AM | #9 |
Rep 596
Google "unsprung weight reduction" and learn more than you could ever want to know. Another vote for Apex wheels; I have EC-7R 18's.
2020 X3 M40 Alpine White over Cognac • 20" BBS CC-R • Cerium delete
2017 440xi Estoril over Saddle Brown • 6-speed • Every stinkin' option |
02-06-2021, 09:20 AM | #11 | |
Rep 4,314
https://f30.bimmerpost.com/forums/sh...20&postcount=1 255/40/18, 285/35/18 is widest you can put on 513M while i also think Apex forged iterations are an excellent choice, since the OP is in Thailand, shipping from the US would increase cost considerably. OP likely has easier access to wheels, from Rays, Advan, BC Racing, BBS, etc. . Last edited by alohasurftoad; 02-06-2021 at 10:06 AM.. |
02-06-2021, 09:10 PM | #12 | |
Rep 341
At most you are losing 6lbs per corner...0.001mph maybe .025g's or about 1mph on a skidpad tops, which can be over ridden by better tires... Let me put it to you another way, the 428/430 has a 0 to 60 time of around 5.7 to 6.1 depending on your test conditions. the 435/440 has a 0 to 60 time of about 4.7 to 5.0, again depending on the actual test conditions...Everyone would agree, that there is definitely a 140HP difference but also more than 100lbs difference as well...yet it only nets you a 1.5 second advantage, more or less... I ask again, can such a small weight reduction really make the car feel different?? |
02-07-2021, 02:44 AM | #13 |
Rep 532
quote
Reducing unsprung weight allows your springs and shock absorbers a greater ability to controll body movement because there is less mass for them to decelerate and accelerate when you hit a bump. This is what results in better handling. As far as acceleration we all know that with the same power, making your car lighter WILL make it faster. So 5 lbs per wheel x 4 wheels is 20 lbs savings from the car right? WRONG. Wheels are not sprung weight so the car not only has to accelerate the weight of the wheel but also has to over come the rotational inertia. This means that removing 1lb of wheel weight is equivilent to removing 10lbs of sprung vehicle weight. 5lbs x 4 corners x 10 = equivelent 200lb savings. So think of it like this, is your car noticablly slower with a 200lb passenger nexto you? Now it also gets a little fuzzy here because of MOI or moment of inertia. The closer the mass is to the center of rotation the less energy required to turn it. So you can actually have a heavy 16" wheel that has a smaller MOI than a lighter 18" wheel just because the mass is closer to the center. Its a street car so buy the pretty wheels you like the most. Or if you really care get some lightweight 17" wheels like RPF1's Last edited by kriszty; 02-07-2021 at 02:50 AM.. |
Poochie9103.00 |
02-07-2021, 05:50 AM | #14 |
¯\_(ツ)_/¯
945
Rep 1,762
+1 on Apex. Running SM-10's
02-07-2021, 07:34 AM | #15 | |
bt5000
Rep 45
alohasurftoad3067.50 |
02-07-2021, 12:30 PM | #16 |
Member
106
Rep 151
I just put 18x8.5 Apex ARC-8's on my car. Between the new wheels and lighter tires (General G-MAX RS) I'm now 14lb lighter per corner or a total reduction of 56lb unsprung weight. Even on my car with over 400WHP the difference is very noticeable.
02-07-2021, 11:11 PM | #17 |
Rep 1,496
