05-19-2015, 03:24 PM | #1 |
Rep 2,348
Drives: TT Flat Six
FS: MINT / OEM BMW / #400M wheels / Blizzak WINTER / 2015+ TPMS
solddd. Last edited by 05Mdriver; 11-04-2015 at 07:26 PM.. |
05-29-2015, 09:13 AM | #2 |
Rep 518
Even with the narrower tires, are these offsets too aggressive for a non-M F30?
2003 M3 | SMG | KW V1 | Apex ARC-8s | 3.85 LSD | Cobra Nogaro | S2R Tuning Sunroof Delete | Billy Boat Section 3
10-08-2015, 10:31 PM | #7 | |
Rep 765
i researched Blizzak WS80, apparently they are recommended by manufacturer to be installed as a set of 4 tires:
Are the 4 tires from a full set? since you said 2 tires are 99% tread and 2 at 90% |
10-13-2015, 06:59 AM | #8 | |
Rep 2,348
Drives: TT Flat Six
The set is fully square, meaning all identical size, so you could put the 2 with 99% on the rears.. or continue to use them on the front. By tirerack recommending them to be installed as a full set of 4... they mean you should not run 2 winter tires and 2 summer tires together. |
10-17-2015, 11:31 PM | #11 |
Rep 278
