BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Fsc code Generator
European Auto Source (EAS)
      09-27-2014, 01:30 PM   #111
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Originally Posted by Badboy8813 View Post
Is a token required to run E-sys to grab the 1B or DE file?
Not needed.
      09-27-2014, 01:33 PM   #112
Badboy8813
Badboy8813's Avatar
23
Drives: F06 Frozen SS 2014 M6 CP
Originally Posted by shawnsheridan View Post
Not needed.
awesome, thanks!
'14 F10 CP M5 AW/Full Sakhir Orange, Gloss Black 343Ms, Black IND Cosmetic Package, M Performance CF Diffuser and Spoiler. - SOLD
      09-28-2014, 02:48 PM   #113
NoliX3
NoliX3's Avatar
Drives: X3 28i 2011
map upgrade
Just upgraded my map to 2015 and I'm very satisfied with it.
      10-03-2014, 08:47 AM   #114
alienranch
Drives: 2012 BMW 335i
Originally Posted by Aritaurus View Post
Just an FYI for those of you who have NBT or can't get SWID reader to work at all.
You can actually grab the 1B or DE file from E-sys by doing the following:
FSC Extended
Base variant 0x63 (For HU_CIC or HU_NBT)
Click Identify
Application ID 0x1B for (App ID 27 for CIC) 0xDE (App ID222 for NBT) <--- This is the App for your Nav enabler
Upgrade Index 0x1
Move Store FSC from the left to the right
Click Read
Click Save and name the file FXXXXXX_0001B001.fsc for CIC or FXXXXXX_000DE001.fsc for NBT where FXXXXXX is your VIN.
I've tried this method for both CIC and NBT and it works.
Trying Aritaurus method above with E-Sys, but am getting the following error:
"Base variant not determinable. Check diagnostic address. [G175]"
I'm using the following data for CIC:
- Diagnostic Address: 0x63
- Base Variant: HU_CIC
- Application number: 27
- Upgrade Index: 0x1
Any ideas what could be causing this?
      10-03-2014, 08:49 AM   #115
shawnsheridan
Use Application number: 0x1B.
      10-03-2014, 04:52 PM   #116
itwt
Drives: 316D
Would this method mean that you don't need a cable like this?
http://www.ebay.de/itm/171315561475?...84.m1497.l2649
      10-03-2014, 04:53 PM   #117
shawnsheridan
That is only for Activation of a Retrofitted Head Unit where Head Unit VIN & FSC Codes do not match car VIN.
      10-03-2014, 05:01 PM   #118
itwt
Drives: 316D
Yes, but being able to create whole new FSC codes to match one's VIN would replace the need in getting a cable like that, right? Or am I missing something?
I'm planning on doing a NBT Navi retrofit.
      10-03-2014, 05:27 PM   #119
shawnsheridan
There are many different FSC Codes in Head Unit, of which you can only generate one of them, thus for retrofitted Head Unit you still need the activation module.
      10-03-2014, 05:35 PM   #120
itwt
Drives: 316D
Ah, thanks for clearing that up.
      10-04-2014, 04:58 PM   #121
BiTeZ
Drives: 2011 BMW Z5 35i
help with a e89
Hi all, I've spent the last 5 to 6 hours reading all of the posts on obtaining the FSC but am having problems determining the exact procedure for my 2011 Z4, an E89.
Will someone kindly confirm if I should be buying the Enet cable or the k+dcan usb cable? I have not been able to find anywhere that has any specific reference to my car, so I'm hoping some generous soul will help me out.
Thanks in advance!
      10-04-2014, 07:49 PM   #122
shawnsheridan
Thanks in advance!
ENET Cable is for Fxx use only.
For normal coding and diagnosis of Exx cars, you would use a DCAN Cable. However, you cannot read 1B file from CIC with DCAN Cable. Instead you need an expensive ICOM Interface. And, you cannot use E-Sys to read it either. You would have to use a program called SWID Reader.
      10-04-2014, 07:53 PM   #123
BiTeZ
Thanks Shawnsheridan. I appreciate your reply. I have the swid reader, and have watched videos on how to use it. Will I be able to access my cars FSC code by using the k+dcan wire?
      10-04-2014, 08:00 PM   #124
shawnsheridan
No, I don't think so. All Exx owners I have ever heard from cannot read it with DCAN, and those with ICOM can.
      10-07-2014, 10:44 PM   #125
wildcatcrazy
wildcatcrazy's Avatar
Drives: E90 335i
2009 335i  [0.00]
Originally Posted by Frogman View Post
It's 0xA8 0x06
You can check by looking in the Info_Map.imp file.
The region code is 2 bytes at offset 8, and the sequence number is the 2 bytes after that.
Maybe a crazy question, but what program do you use to open the Info_Map.imp file? I tried notepad and all I see is . - ZO %Road Map North America PREMIUM 2015-1
      10-08-2014, 12:00 AM   #126
shawnsheridan
Notepad++
You will some gibberish and then the map name.
      10-08-2014, 12:56 AM   #127
wildcatcrazy
Drives: E90 335i
2009 335i  [0.00]
Notepad++
I'm still not able to see the region code and region number in that file... Is there a setting in Notepad++ I need to change in order for it to display those characters?
      10-08-2014, 01:27 AM   #128
Frogman
Frogman's Avatar
Drives: 2012 F30 328i
You need a hex editor. I used HexEdit.
Notepad++ will do it if you enable the Hex Editor plugin.
      10-14-2014, 12:09 PM   #129
Frogman
Frogman's Avatar
Originally Posted by /////lpine View Post
hi guys! Achem can open the file INFO MAP.imp?
I've never heard of Achem and Google didn't help.
Are you saying that Achem is an alternative to open the binary image file, or are you asking a question?
      10-16-2014, 01:15 PM   #130
locque
Drives: F10 530xD
I have BMW F10 530xD (2013 year pre-facelift). Here are the steps I went through updating my map. I have professional navigation (NBT - next big thing). Originally the navigation had Road map Europe Next 2013. I downloaded Europe Next 2014-2, formatted 32 GB stick with FAT32 filesystem, copied the files and plugged into the usb port of the car. The car started transferring the contents to the internal hard drive and after one hour successfully updated the map. On the next restart of the car - it wanted the activation code. I wasn't able to extract it with SWID tool so I used Ariataurus method with the following settings into E-Sys (downloaded E-sys from http://rutracker.org/forum/viewtopic.php?t=4662346 ) - (there are installation instructions within the torrent):
- Base Variant: HU_NBT
- Application number: 0xDE
I successfully extracted the FSC code and saved it to a file - FDZ17056_000DE001.fsc.
Then downloaded BMW_CIC_NBT_FSC_Generator from https://mega.co.nz/#F!ugo0HB5L!TPCmejMKPBlRRkz2SDvg0Q. Extracted it and then went to NBT_fsc subdirectory. Then issued the command
fsc FDZ17056_000DE001.fsc 0xA9 0x05 last_seven_digits_of_you_vin_here
and got the correct activation code. The correct parameters for map Europe Next 2014-2 are 0xA9 and 0x05.
Thanks to everybody in this forum for their great posts.
      10-21-2014, 09:04 PM   #131
krsk
Drives: bmw 320xD
Good day!
I want to get the FSC code on your machine.
1) Connect - ok
2) Read VIN - ok
3) Read FSC - Total bytes: 0 !!!!
Why do I get this error ??
thanks in advance
my BMW - 320xD f30
      10-22-2014, 03:38 PM   #132
forillo111
Drives: F30
Thumbs up
Hello
I've read my FSC method with E-sys and Ariataurus, then I tested two versions
Post 110 kitster, OK
Post 133 by locque, OK
I get the same unlock code for all of the two methods
