11-08-2017, 08:27 PM | #1 |
Im real pressed.
104
Rep 203
Ughhhhhhhh...........
Got my 3 series back from the dealer yesterday. And to make a long story short im not happy with my car at all right now. So yesterday night I was pulling my 3 series out of the garage when all of a sudden all of the exterior and interior lighting shut off.....I tried to turn them back on by turning the switch that controls the light's to the manual mode and guess what???? They did not turn back on....So im thinking "I dont have time for this BS.." So I shut the car off and got out the car and locked it (Using Comfort Access this will come into play later on in the story). So I get back in (Once again using Comfort Access). Start the engine and the light's still dont turn on at all... So after about 5 minutes of me trying to get the light's to turn on I eventually give up and pull the car back inside of the garage. Go to shut the engine off and the car shut's down as normal except this time the radio wont go off(but the screen is black), the gauge cluster looks as if the engine is still running but it's not and the door handle light's won't turn off. So I go to turn the car back on it start's up and everything and I shut it right back off but as I stated above the radio was still playing and the gauge cluster looks as if the engine is still running and the door handle lighting wont shut off. So I give up once again and step out of the car and go to lock it but guess what comfort access isn't working at all. Can't lock the car or unlock the car unless I use the fob..... So now I have a CAR WITH LESS THAN 2k miles on it sitting in my garage that I can't drive at all. And to make matter's worse I have to disconnect the battery so the battery won't die because OHHHH!!! The radio won't turn off and the gauge cluster is still on as if the engine is running and the door handle lighting wont shut off. And the gauge cluster is Showing everything that should be on only when the engine is running. Glad I have other car's to fall back on though because if I didn't we would have a problem.
I forgot to mention that I called my dealer but they tell me that they can't look at the car until next week.......
Current Lineup: 2017 Tesla Model S 100D/2017 340i Xdrive/2015 Audi Q5 Prestige Quattro/2017 Kia Optima SXL
11-08-2017, 08:31 PM | #2 |
Mike: Everyone's Pal
2042
Rep 2,972
Drives: F80 M3
maybe your FRM module
Alpine MSS Stage 2+ E30 tune|MST Intakes|VRSF Single Mid Pipe|Agency Power Intercooler|VTT Full solution crank hub fix |
11-13-2017, 07:53 AM | #3 | |
Rep 4,210
11-13-2017, 08:53 AM | #4 | |
Im real pressed.
104
Rep 203
They currently do have the car though and put me in another loaner. Im just ready for them to fix my car and give it back too me.Hopefully I get it back before Thanksgiving....And not after!
11-13-2017, 08:56 AM | #5 |
Rep 2,485
Drives: 340Xi MG 2017
Either that, and/or a battery that is acting up.
