BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > BIMMERPOST Universal Forums > General BMW News and Cars Discussion > BMW Motorrad Concept Vehicle BMW E-Scooter.
proTUNING Freaks
      07-03-2011, 10:36 AM   #1
Mark
Administrator
Mark's Avatar
6731
Drives: 1M
BIMMERPOST NEWS
COMMENTS
Space is becoming increasingly scarce in the major conurbation centres and traffic density is growing continuously. Political and social conditions are changing. All these factors coalesce in increasing demands in terms of
private transportation. The concept vehicle BMW E-Scooter with electric drive provides an innovative look at changing urban mobility needs.
While the currently available, purely electrically-powered scooters have been almost exclusively used inside towns and cities to date due to their performance and range, which makes them suitable for short distances only, the concept vehicle BMW E-Scooter offers a much broader spectrum of use.
High range and excellent performance figures.
Since it was conceived as a future-oriented vehicle for commuting between urban areas and the city centre, therefore attracting funding from the German Federal Ministry of Transport, Building and Urban Development, there were two main requirements for its development: dynamic figures comparable to those of a maxi scooter with a combustion engine and a high range in realistic conditions of use.
The concept vehicle BMW E-Scooter provides the necessary sustained output and maximum speed for safe and reliable overtaking on urban motorways and also when carrying two people. It is also easily capable of managing hill starts on steep slopes with a pillion passenger.
The development study also has the necessary maximum output to be able to achieve acceleration figures within the important 0 - 60 km/h range, which are at the level of current maxi scooters powered by a 600 cc combustion engine.
The high storage capacity of the battery allows a daily driving range of over 100 kilometres. In this way, the BMW E-Scooter concept vehicle provides a long-term, zero-emissions urban and suburban travel option which is suitable for everyday use.
Fast charging at conventional power sockets.
The E-Scooter concept vehicle's battery is charged at regular household power sockets as found in Europe, the USA, Canada and Japan, so no special charging station is required. When the battery is completely flat, the charging period is less than three hours. However, practical experience has shown that the battery rarely runs out completely, so charging times are generally shorter.
Frame.
Unlike existing maxi scooters with combustion engines, the concept vehicle does not have a main frame. Instead, the aluminium battery casing — which also contains the electronic system required for battery cell monitoring —takes over the function of the frame. The steering head support is connected to it, as is the rear frame and the left-hand mounted single swing arm with directly hinged, horizontally installed shock absorber.
Electric machine, power electronics and charging device.
Due to its high output, the BMW Motorrad development study has no hub motor with direct drive or planetary gearbox. Instead, the high-performance electric machine is mounted behind the battery casing. The secondary drive consists of a toothed belt from the electric machine to the belt pulley mounted coaxially on the swinging fork pivot with drive pinion. From here, power transmission occurs via roller chain to the rear wheel. When the E-Scooter is decelerated in trailing throttle or when braking, the energy released is recuperated, thereby increasing the vehicle's range by between 10 and 20 per cent depending on driving profile.
The electrical components required for the electric drive are installed on the top of the battery casing. The external battery electronics system permanently collects and monitors data such as the temperature and voltage of the battery cells, both during travel and while charging. The power electronics acts as a control system and controls the electric machine. The charging device includes a charge cable which allows the battery to be recharged at a conventional household power socket. In addition to the other components like an ISO insulation monitor, high-voltage indicator and a high-voltage distributor, a DC-DC converter is included. It is required to change high voltage to low voltage power to supply the 12 volt vehicle supply and especially for the control units.
Cooling system.
During travel, the electric machine and power electronics are liquid-cooled, as is the charging device during charging. An electric coolant pump ensures coolant circulation through the radiator. While a coolant is commonly used for the battery in electrically powered cars, the E-Scooter concept vehicle uses an air cooling system in order to save space.
Safety.
BMW Motorrad is one of the very few motorcycle manufacturers to be able to draw on its own experience and expertise in the automobile field in the development of electrically powered vehicles. Synergies are derived from the development of the BMW E-Scooter concept vehicle not just in the ready availability of technical components but also in the area of high voltage engineering and the associated safety requirements. Here for the first time, standards established by the leading automobile manufacturers relating to high voltage safety (> 60 volt) and functional reliability are being applied to a two-wheel vehicle with electric drive.
BMW E-Scooter
Videos
      07-03-2011, 11:36 AM   #2
ferrari6891
the original brown guy
ferrari6891's Avatar
Drives: '22 MBB/SO X5M Comp
2011.75 E90 M3  [7.66]
I lol'd when I saw the front page picture with camo
PREVIOUS
2019 G05 X5 M50 AG/BLK
2017 F15 X5 5.0 M Sport AW/BLK
2011 E90 ///M3 AW/FR
2008 E92 ///M3 IB/BLK
      07-03-2011, 12:02 PM   #3
Justin Spelman
Drives: Waiting on next M3
Camo!? Hah
      07-03-2011, 12:14 PM   #4
E90SLAM
Supreme Allied Commander
E90SLAM's Avatar
Hong Kong
1963
Drives: A BBS WHORE
Could've use a Vespa shell...LOL~
      07-03-2011, 12:51 PM   #5
Kiemyster
Bimmerpost Resident Marijuana Consultant
Kiemyster's Avatar
Trinidad_and_tobago
455
Drives: 320i, 325xi, 335Xi, 335i, M3
shits gonna be ill when it comes out. they are really going to make some awesome scooters -- and its about time someone makes scooters that dont have that "faggio" stigma stuck to it.
+1 for the only series of scooters that I would not make jokes about, and get cool points from me! I cant wait to see these zipping around NYC! YESSS! NYC already is flooded with BMW motorcycles, and I love it. They are great to look at, easy on the eyes, real eye candy IMHO.
"AMG What! S-Line Who? If you ain't got that M I got no respect for you!"
'06 Alpine Weiss E90 320i | '06 The Green Machine E90 325xi | '11 Alpine Weiss E90 M3 ZCP | '10 Silverstone X5M | '11 Alpine Weiss E90 335xi
      07-03-2011, 01:01 PM   #6
M5007
M5007's Avatar
Drives: 2014 M5 Competition Package
I love BMW bikes. Specially the new sport bikes. But this? I am not sure about. Maybe when all the camo is off?.... Nah!
      07-03-2011, 01:11 PM   #7
mPlasticDesign
mPlasticDesign's Avatar
684
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Is this BeemerPost now???
      07-03-2011, 09:53 PM   #8
hotrod182
hotrod182's Avatar
812
Drives: 2023 i4 M50
I would love to have one, but I bet it will be over $10,000.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra,
2008 Black 335i Sedan. 11.11@ 129.47 mph
2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds
2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy)
      07-04-2011, 12:05 PM   #9
kaishang
Drives: 2010 E90 330d
Excellent. It's good to see manufacturers finally developing fuel efficient bikes. My bike uses the same amount of fuel as my 3-litre BMW FFS, bikes are 20 years behind car technology.
