02-07-2017, 12:34 PM | #23 | |
Rep 16
Is your panel shifting from white/amber or is always amber? |
03-17-2018, 12:36 PM | #25 |
Rep 58
Hello guys, I am interested about changing Ihka basis to ihka high display only.
I connected panel unit and almost everything work but i have some issues> The temp is always 16 degrees The wheel temperature doesnt work. The control panel is lci and my car is dated from 07/14. Do i need to install anything or only i must code the ihka and fem ecu Thanks. |
07-02-2018, 10:20 AM | #26 |
Rep 18
Hello I'm going to perform an exchange Klima basic on high. Need scheme cable
sensor AUC : 64119240180 - which pin cable ?? solar sensor : 61359293279 - which pin cable ?? larry_bml You have Connection diagram ? |
06-12-2019, 11:36 PM | #29 |
Rep 73
Is it possible to "update" the single-zone to two-zone climate? F30 LCI
I compared the part numbers such as, the heater - and they are the same as in cars with dual zone air conditioning ... In general, the F30 with single zone ceiling is a rarity ... I know that there were topics about older models like E90, but the heater was different there - unless, real parts are not the same as realoem.com shows..? What is different then? Probably amount of air conditioning factor is different but what is comes from? Europe version VIN - K686509 |
07-14-2019, 08:40 AM | #30 |
Rep 5
Hi guys, hi larry you did a very impressive work! Congrats! Since It's too much for me i would like to just change the control panel of my single zone with the one of the dual zone but I would like also to know if the single zone could provide the air flow to the rear seats if the proper pipes are added from the front to the rear under the tunnel. Could you help me? Do you know something about that?
Thanks in advance Rog |
07-14-2019, 09:12 AM | #31 |
Rep 325
Hello, NO, single zone can not deliver air in the back. And also, if you change only controllers , it I’m not sure that it will work.
07-18-2019, 06:32 PM | #32 | |
Rep 5
About the controller it seems that a guy in an other forum didi it with success. He posted also the few coding instructions that he applied. Thanks |
10-02-2019, 02:27 AM | #34 |
Rep 58
Hi everyone. I got all the hardware for retrofit my basic ihk to high IHKA. I only need to Know If I must drain air conditioning system before change heater box with new ecu. that is, do I need to take out all the gas from the air conditioner?
Thank you larry and others.
F33 420d, E34 525 tds
10-02-2019, 04:41 AM | #36 |
Rep 7
Hi guys.
I need to change my airbox (basic) in f31 2013. And i can get cheap another one but from f31 (high) 2016(facelift) Can i change and connect it plug and play ? Without any problems? |
11-03-2019, 10:18 AM | #37 |
Rep 58
yes you can. i am doing this retrofit right now. but you must change more pieces and use esys to Code and program.
11-03-2019, 10:30 AM | #38 |
Rep 58
Next step
the Next weekend i Will finish the retrofit (i Hope so). i must drain the f134 gas and change the Air and heater box. all wires are disconnected and all pins in FEM were installed and changed.
11-19-2019, 07:06 AM | #39 |
Rep 2
Hello Guys,
I am a happy owner of a 2016 f36 and would like to know what parts would i need to have a dual zone digital climate control working. Thanks a lot. |
11-20-2019, 02:33 PM | #41 |
Rep 58
the great problem is changing the klima box with f134 gas and antifreeze water. i can help anyone if needed.
12-13-2019, 11:58 AM | #43 |
Rep 14
