09-13-2018, 02:24 PM | #1211 | |
Rep 606
Ive updated the unit trough factory settings and I got a " upload successfull" screen that I did not get before. I will compare the two files just to see what the difference was... |
09-13-2018, 02:38 PM | #1212 | ||
Rep 207
Have you ever experienced any disconnects and restarts with this dongle? On low iphone battery?
09-13-2018, 02:43 PM | #1213 |
Rep 132
Thanks guys.
The annoying usb permission request: It looks like we can solve the problem with Tasker + Autoinput plugin The idea is to let Tasker click on "OK" automatically when usb permission request pop up. Who has Tasker and can try it? See tutorial here: |
09-13-2018, 02:46 PM | #1214 |
Rep 606
will do tomorrow morning!
it's with a shortcut I see but I think it's possible to trigger it by means of opening the dab app itself, but just only at first start. should be possible.... |
09-13-2018, 03:23 PM | #1215 | |
Rep 132
Problem: menu tiles are bound to stock apps. Solution: e.g. Music menu tile will open stock music player. 1. Create Tasker Profile for stock music app 2. Create Task 1: open spotify 3. Create Task 2: close stock music app life is so simple with Tasker on the whitelist |
09-13-2018, 03:41 PM | #1216 |
Rep 121
09-13-2018, 04:24 PM | #1218 | |
Rep 93
09-13-2018, 04:34 PM | #1219 | ||
Rep 201
09-13-2018, 06:07 PM | #1220 |
Rep 121
09-14-2018, 02:13 AM | #1221 |
Rep 132
Well, I use native functionality of the unit all the time. But no crash or reboots with latest android update.
What is the difference between Autoplay and Autokit? Can iDrive knob and select be used with both Apps? |
09-14-2018, 05:41 AM | #1223 |
Rep 132
Yes, on iPad
https://support.apple.com/en-us/HT207582 |
09-14-2018, 06:24 AM | #1224 |
Rep 606
I havent tested the Tasker addon since you only get the popup once and I did something wrong.
It should be possible though. Will try at the end of the day |
09-14-2018, 09:10 AM | #1225 |
Rep 36
hi guys, is this update file compatible with the android 7.1 display made for E84 (like this one i'm buying)?
I could need some help editing some italian words that I know were written wrong or not translated... |
09-14-2018, 09:58 AM | #1226 | |
Rep 106
I have it set up to:
So, when I say it sort of works, here are the issues:
I feel so close to the experience I want and somehow still far away. At this point, if I could 1) speed loading way up, and 2) get Android to simply preserve the settings I'm setting, I'd be golden. Suffice it to say, this is preliminary findings. I'm going to keep fiddling with it. [RANT]This unit is my first real foray with Android, so I don't know how representative it is of the Android experience, in general, but I find the "we'll protect you from yourself" stuff like the USB permission dialogs and the disabling of Accessibility settings and re-enabling of things like Google Play really irritating.[/RANT] |
09-14-2018, 10:03 AM | #1227 |
Rep 606
I just wanted to post the exact same experience with accessibility options with trying the dab pop-up for permission. I saw something about creating a hardware-allowed whitelist on android side but I'm way too noob to perform such programming...
09-14-2018, 03:12 PM | #1228 |
Rep 132
Thanks toddyus DRuw for sharing your experience.
I think we are really close to the solution. Together we can make it. Just think where we were a month ago... (dealing with crash, no signal at boot and service killer) |
09-14-2018, 04:53 PM | #1229 |
Rep 93
Has anybody else noticed this difference in software between Autoplay and Autokit you can change Oem icon to the make of your car in Autokit apk settings which you can't do in Autoplay apk
09-14-2018, 08:55 PM | #1230 |
Rep 82
I have an F32 with HK & combox like yours and my sound in the android side is pretty much the same as Bmw side. I adjusted the aux output to 2 bars above half. And it sounds great. I adjusted the equalizer to even sound better. What I noticed was that if your sound is rally bad with aux sometimes its the cable. It happened to me one time when I was still using aux to play music with my iphone at first it sounded really bad until I tried wiggling the cable input and eventually just replaced it with a better cable
09-15-2018, 06:00 AM | #1232 |
Rep 118
